Which speakers for LOC line output converter - speaker level input
Discussion in 'Audio & Video' started by james33440, Sep 9, 2019.
  1. Sep 9, 2019 at 4:54 AM
    james33440
    james33440 [OP] New Member
    James
    2010 Tundra Double Cab
    Magnaflow Exhaust
    I have a 2nd Gen Tundra with a non-JBL navigation radio.
    My question for those of you using a line output converter, or an amp with speaker level inputs, did you tap into the front speakers or rear speakers for the signal?
    I know some vehicles have their rear speakers crossovered high to remove the bass.
  2. Jul 20, 2020 at 8:36 PM
    YotaFan05
    YotaFan05 New Member
    NE OH
    2011 Tundra Crewmax
    Did this ever get solved? Same question, 2nd gen non JBL. Where's the best location to tap into for a LOC ? Do I have to pull the headunit?
  3. Jul 23, 2020 at 11:53 AM
    YotaFan05
    NE OH
    2011 Tundra Crewmax
    There's got to be an easier place to access speaker wires than pulling the headunit. How about the passenger kick panel?
  4. Aug 1, 2020 at 3:21 AM
    james33440
    James
    Magnaflow Exhaust
    Sorry, I since changed out the head unit for an aftermarket and just added a 5 channel amp
  5. Aug 3, 2020 at 3:31 AM
    jwatt
    jwatt I heart men
    Jack
    Oregon
    Signal can also be amplified with high level inputs. Not what you want. From what I have read feeding amplified signal to an amp can cause problems. If you have them; RCA s give you what you need.
  6. Aug 3, 2020 at 5:45 AM
    purplenova
    purplenova Not a new member
    Tom
    Ohio
    2016 Tundra Crewmax SR5
    I have the LC7i and kenwood amp.
    I just ran a wire from the LOC "Remote out" to the amp and done!
  7. Aug 3, 2020 at 5:53 AM
    ezdog
    ezdog New Member
    Gateway To The West
    Speaker level audio has already been amplified once from line level up to speaker level.
    Anytime you amplify a signal that much you are already amplifying any noise and distortion in the signal like crazy.
    Thoat sound is already in there then before putting it into the converter.
    So then just padding that signal down to re-amplify it will never sound as good as just amplifying it once.
    If all head units had line level outputs there would be no need for LOC at all.
