Which Sparks Plugs do you recommend?
Discussion in '2.5 Gen Tundras (2014-2021)' started by georgiey22, Dec 25, 2022.
  1. Dec 27, 2022 at 2:53 AM
    Joe333x
    Joe333x Member
    Boston
    2019 Tundra CrewMax Platinum
    FYI the stock plugs are iridium. It has nothing to do with performance, precious metals like iridium or platinum last longer than standard copper plugs. The cheaper copper plugs actually provide better performance since it is more conductive than iridium just the copper does not last as long so service intervals are shorter.
    georgiey22[OP] and centex like this.
  2. Dec 27, 2022 at 5:50 AM
    centex
    centex New Member
    This. If you are going to do 50k service intervals, save the money and go copper. Changing iridium’s at 50-70k is just throwing money away.
    Rocko9999 and georgiey22[OP] like this.
  3. Dec 27, 2022 at 7:47 AM
    georgiey22
    georgiey22 [OP] Moving to Idaho
    2019 Tundra | TRD Sport | Cavalry Blue | Crew Max
    appreciate the insight here everyone. Thank you!
  4. Dec 27, 2022 at 9:15 AM
    Sumo91
    Sumo91 Busy with projects
    TN
    2014 MGM Tundra Platinum 4x4
  5. Dec 27, 2022 at 11:34 AM
    Rocko9999
    Rocko9999 New Member
    OEM from dealer or very reputable source. No need for any other kinds, you will get no benefit.
  6. Dec 27, 2022 at 12:49 PM
    Joe333x
    Joe333x Member
    Boston
    Service intervals for copper plugs is way less than 50k, it would be more like 10k. My Subaru had iridium and service interval was 60k. I'm going to do 60k for the Tundra as well. Not so much because I think the plugs will need to be replaced but I just like to do things and I'd be worried about them being stuck at 120k.
  7. Dec 27, 2022 at 12:57 PM
    parkerbows
    parkerbows New Member
    Jack
    2017 crew max sr5 trd off road
    Firestone air ride air bags
    I recently bought 6 ngk plugs for my boat and the cheapest by far was directly from NGK
  8. Dec 27, 2022 at 4:27 PM
    Roborob70
    Roborob70 New Member
    Robert
    18 Toyota Tundra TRD
    It is more than likely fine running plugs for 100k...plugs in my camry look fine...the issue becomes a seized plug in the head, if not seized very very stubborn to get out. Every 25 or 30k i just pull the plugs and reinstall....issue solved.
  9. Dec 27, 2022 at 6:34 PM
    dt325ic
    dt325ic Member
    GA
    2019 TRD Sport
    On the 1st gen Tundra V8 with factory copper plugs (00-04), the interval for spark plugs from Toyota was 30,000 miles. That's what I did, and they always looked fine (and gap was ok). I waited until 60k once, and the gap had gotten too wide.
  10. Dec 27, 2022 at 7:06 PM
    Joe333x
    Joe333x Member
    Boston
    Interesting, only vehicle I changed plugs in that has copper is my bike and its 7500, so figured it would have been shorter than 30k but the bike is high compression so I guess it makes sense.
  11. Dec 27, 2022 at 7:18 PM
    centex
    centex New Member
    I’ve always found 50k worked well for my vehicles with copper plugs. Not certain why your bike says 7500 but I’d imagine high rpm is a factor. More cycles per ignition stroke, more wear on the electrode.
  12. Dec 27, 2022 at 7:48 PM
    Dantdodge
    Dantdodge New Member
    Danny
    Tampa
    2018 tundra sr5 crewmax trd 4x4
    Stock trd off road
    Just changed mine at 85k oem denso. Running Like a champ.
