Which slider/steps?
Discussion in 'General Tundra Discussion' started by Mark843, Mar 26, 2018.
  1. Mar 26, 2018 at 1:43 PM
    Mark843
    Mark843 [OP] New Member
    Mark
    WNY
    2018 Barcelona Red Tundra SR5 with TRD offroad package
    I need to get something to help the wife and kids get into the Tundra. I was going to get some steps/nefbars, but I like sliders better. I like the idea of bolting to the frame instead of the body and they are more durable.
    I will not be offroading my Tundra so I don't need something super stout. I am looking for something that has a fill plate, flat and can bolt on. I like the All-Pro Apex sliders but they are angled up. Then I looked at Slee, but they don't work with the larger gas tank.
    I was going to order the white knuckle, but the idea of drilling 10 holes in the frame concerns me as I live in the northeast. The Trundra will get a generous salt bath each winter and I am concerned about frame rust.
    Any suggestions as to what other ones I should look at?
  2. Mar 26, 2018 at 4:25 PM
    alpinepro4
    alpinepro4 What is your MPG Today!
    Pat
    2017 TRD Pro Cement DC
    Baja Designs Squadron Sport Fog lights, ARE CX Series Topper, Alcan Springs , DAP Tune, Coach Builder +1 Shackles, Headlight Revolution Supernova V.4 LED bulbs, HR LED interior bulbs. General Grabber ATX 275/70/R18
  3. Mar 26, 2018 at 5:11 PM
    Hoologan
    Hoologan New Member
    California
    18 Cement Limited Crewmax TRD
    Sub'd cuz I have a similar situation. I hate steps but don't "plan" on offroading to the point where I'l need sliders. Sliders definitely look better, IMO.
  4. Mar 26, 2018 at 5:19 PM
    Sunnier
    Sunny
    San Diego, CA
    Demello are better "steps" than SDHQ and may be bolted or welded on. Still not actual "steps" though. The "problem" with sliders in this application is that they fit close to the truck. The same reason they offer frame protection and look good is why they are not good steps.
  5. Mar 26, 2018 at 5:23 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Every slider I’ve ever stepped on works perfectly as a step. And I think I’ve stepped on every single brand now. Even without the fill plates they’re fine. Just might need a little skateboard tape or something on round tubes when it gets wet.
  6. Mar 26, 2018 at 5:39 PM
    jc153
    jc153 Speed-ish Glamper
    San Diego
    2009 Tundra Ltd CM 4x4
    TC Front Long Travel, ADV Glass Fenders & Bedsides, TC Spindle Gussets & King LT Coilovers, RCV Axles, DuroBumps, CB Steering & Carrier Bearing Drop Kit, SDHQ ABS Sensor Shields, Rear 3.0 ADS Triple Bypasses w/MCM Fab Under Bed Shock Mount Relocation, SUA Deaver I96HD Springs & TC Shackles, MCM Fab Rear Hydro Bumpstop Kit, Solid Offroad Engine Mounts, 17" Method Standards, 37/12.5/17 Toyo RT's, Nitro 488 Gears w/Auburn LSD, Evil Off Road Bumpers, RCI Skid Plates, White Knuckle Sliders, Dirty Deeds Ind. BAMuffler 8" Catback, Baja Designs Lighting, SwitchPros Controller, Custom PS Cooler Relocation Kit, Custom Dual Battery Setup
    For steps I really like the Amp Research retractable type. That’s what I would get if I only needed steps.
    I personally have White Knuckle sliders because i do quite a bit of off roading. They are great dual purpose body panel protection and steps. I just put a little skate board grip tape on them where you step to get in. My 5’2” wife and 12 year old daughter have no issues using them as steps.
  7. Mar 26, 2018 at 7:23 PM
    Sunnier
    Sunny
    San Diego, CA
    I meant that, sliders being mounted close to the truck, it doesn't decrease the "step-up" distance for kids, as much as purpose-built steps.
  8. Mar 26, 2018 at 7:30 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    My response wasn’t directed at you Sunnier. :thumbsup:
    Sunnier[QUOTED] likes this.
  9. Mar 26, 2018 at 7:34 PM
    15whtrd
    15whtrd Mr. Blonde
    Tundracollector likes this.
  10. Mar 26, 2018 at 7:42 PM
    Sunnier
    Sunny
    San Diego, CA
    No worries; I don't mind even if it was. Your comment made me realize I hadn't gotten what I wanted to, across.
    Btw, I've put off installing the steps I got for so long, my family have stopped mentioning it. My son uses his knee when necessary to crawl in....:cool:
    joonbug[QUOTED] likes this.
  11. Mar 26, 2018 at 9:18 PM
    speckmon
    speckmon Must. Have. Pow.
    Thornton, CO
    '07 mountain road bomber
    Look on your local Craigslist for guys that can fab for you. There's a guy here that'll do whatever I want for 500 bucks. Just waiting on a few other things I want to get done first
  12. Mar 26, 2018 at 9:44 PM
    Hoologan
    Hoologan New Member
    California
    @Mark843 Have you looked at the N-Fab RKR steps? From what I can tell, they're a slider with a detachable step. No idea how durable they are as I don't see many people running them.
  13. Mar 26, 2018 at 9:51 PM
    15whtrd
    15whtrd Mr. Blonde
    While they look to be one of the sturdiest steps out there they are not sliders.
  14. Mar 26, 2018 at 9:56 PM
    Hoologan
    Hoologan New Member
    California
    Roger that. I just saw on Youtube that they bolt to the body.
    15whtrd[QUOTED] likes this.
  15. Mar 26, 2018 at 10:06 PM
    15whtrd
    15whtrd Mr. Blonde
    For a slider you definitely want it only bolted to the frame. Although I was under the impression that steps also only bolt to the frame. I would think the sheet metal would crumble.
  16. Mar 27, 2018 at 11:29 AM
    Mark843
    Mark
    WNY
    I am heavily leaning toward the SDHQ sliders. Does anyone have a picture from front to back, or back to front showing how much angle there is to them? Pictures can be very deceptive depending on how they are taken. Does anyone have them on a stock height truck and are willing to give me measurements from the ground to the top of the outside tube?
  17. Mar 27, 2018 at 11:34 AM
    Flyinryank
    Flyinryank New Member
    Ryan
    Las Vegas, NV
    White 2015 CM 4x4
    I have these. They sit high and tight but do not mount to the frame. They mount using the existing holes for the factory side steps. They are beefy for what they are but no sdhq sliders.
    For light to medium hits they get you buy. Not bad for the money especially if you get em on sale. Good budget option.
    If I could do it over again I think I’d go with the sdhqs due to the fact that I actually use my truck off road
  18. Mar 27, 2018 at 11:35 AM
    itsdchz
    itsdchz 50statesoverland
    Clovis, CA
    2018 SR5 CM Cement 4x4
    Icon, UCAs, Method, SSO, KB VOODOO, Skids and Sliders
    My @sdhq_offroad sliders work great as steps for the kids, wife and I!
  19. Mar 27, 2018 at 11:39 AM
    Mark843
    Mark
    WNY
    @itsdchz Thank you for the pics. I sent the pics to my wife for approval to see if she thinks the step height would work.
  20. Mar 27, 2018 at 11:40 AM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    The height on sliders is a non-factor unless maybe you're on a 7" lift or something.
  21. Mar 27, 2018 at 12:04 PM
    itsdchz
    Clovis, CA
    A couple others to help:
    Sunnier and Flyinryank like this.
  22. Mar 27, 2018 at 12:14 PM
    thetwood
    thetwood New Member
    Louisville, CO
    2017 Blazing Blue Limited CrewMax TRD
    Kings, SPC, Icon Six Speed, Falken Wildpeak AT3w
    I went with the new P&P design. Have been happy so far. Were pretty easy to mount, seem rock solid and like how they're angled at front and back to match body shape.
    mac11, seniramsu, rons23 and 2 others like this.
  23. Mar 27, 2018 at 1:13 PM
    BIGUGLY
    Paul
    2018 Limited
    Are the SDHQ sliders the only sliders that require no holes to be drilled?
  24. Mar 27, 2018 at 1:18 PM
    Mark843
    Mark
    WNY
    If you use them as sliders then probably. BudBuilt's may be 100% bolt on also, but are much heavier then SDHQ sliders. Others like ALL-Pro and others can be used as steps without drilling, but not to to their full potential without doing the drilling.
  25. Mar 27, 2018 at 6:38 PM
    Samoan Thor
    Samoan Thor God is technically an alien
    Limited 2014 crewmax 4X4
    Kings F&R, no sway bars
    How long before you actually got the sliders after ordering? I like P&P’s sliders but I hear it takes too long for shipping or production one of them.
  26. Mar 27, 2018 at 7:04 PM
    Cutter29
    Cutter29 ...
    Utah
    2015 Super White TRD PRO
    I have the SDHQ sliders as well and they work great as a step. Added some grip tape for wet weather and haven’t had any issues.
    joonbug likes this.
  27. Mar 27, 2018 at 7:53 PM
    thetwood
    thetwood New Member
    Louisville, CO
    Took about 2 months from order to delivery, though that did include Christmas and New Years. Not in stock or super quick, but luckily I wasn't in a huge rush either.
    Samoan Thor[QUOTED] likes this.
  28. Mar 27, 2018 at 8:09 PM
    Samoan Thor
    Wow! Oh well, they look cool though
  29. Mar 27, 2018 at 8:11 PM
    itsdchz
    Clovis, CA
    Took 3 business days to get the SDHQ sliders to me! Was very impressed!!
    Black Wolf likes this.
  30. Mar 29, 2018 at 11:49 AM
    Mark843
    Mark
    WNY
    Any issues with the SDHQ front mount being where the cab attaches? I don't plan on offloading so probably a non issues for me, but if you cam down hard on them, could them bend the cab mount where they attach to in the front?
