Which running boards to go with?--Pictures requested
Discussion in '3rd Gen Tundras (2022+)' started by scruff1221, Jun 23, 2022.
  1. Jan 28, 2023 at 7:45 AM
    #121
    Tundrafarm
    Tundrafarm New Member
    22 hybrid limited 4x4
    I’m running mine backwards, go rhino rb20
    Durtywrench likes this.
  2. Jan 28, 2023 at 9:54 AM
    #122
    opusmagnum
    opusmagnum New Member
    2023 Blueprint Tundra SR5
    how's the grip on the RB20s vs OEMs tubes?
    I need full step for my older members of family with a moderate amount of grip for when it goes snowy here in the midwest.
    Just don't want anything that gets slippery as snot when wet
  3. Jan 28, 2023 at 10:05 AM
    #123
    Durtywrench
    Durtywrench New Member
    Lou
    23 Tundra platinum
    None
    I have the rb20 slims with the textured black not the bedliner coating and they’re pretty grippy . I imagine the bedliner to be way better .
  4. Jan 29, 2023 at 11:06 AM
    #124
    worksjo
    worksjo New Member
    2023 Tundra SR5 Off Road
    Are the RB20 slims wide enough at the back door for a step? Or at least a step for kids?
  5. Jan 29, 2023 at 11:38 AM
    #125
    Durtywrench
    Lou
    23 Tundra platinum
    None
    I’m studying that as we speak . If you intentionally turn your foot sideways it enough but it feels like it sets your foot to hit the truck sometimes . My little girl has to step right .
  6. Jan 29, 2023 at 1:12 PM
    #126
    TexasTacoma713
    TexasTacoma713 New Member
    2023 SR5
    I have my rb20 slims mounted backwards so the wider part is in the rear. It’s fine for kids. Hell the slimmer portion in the front is fine for my size 12 foot but I do have to step sideways… If you’re considering that, just get the regular Rb20s or even rb30s
  7. Jan 30, 2023 at 7:43 AM
    #127
    Ruger19
    Ruger19 New Member
    Bill
    2022 Tundra
    I went with the D 6's. Pretty happy with the way they look. They are tucked in and have no under brackets sticking down. The wife likes them, soooooooooo. IhDzlIuRV5hmpAOMeovOL6nOro--yLxUeYScQgVm_8acdbea9520314e836211877f6c4e19ee8301520.jpguFrCnDg0BpxARXMcM0Rmmk_i0zZGST2nvVlqNNR0_8345479bbed0a92b6928720fb9783295c82ffdda.jpg
    Durtywrench and AND like this.
  8. Jan 30, 2023 at 7:58 AM
    #128
    Durtywrench
    Lou
    23 Tundra platinum
    None
    That’s one thing I hate about mine . How do they attach ?
  9. Jan 30, 2023 at 8:00 AM
    #129
    TexasTacoma713
    2023 SR5
    All running boards attach with brackets like these.. Crewmax has 4 and double cab has 3
    Durtywrench[QUOTED] likes this.
  10. Jan 30, 2023 at 8:02 AM
    #130
    Durtywrench
    Lou
    23 Tundra platinum
    None
    I was just curious cause he said his brackets don’t hang down . The ones on my go rhino do
  11. Jan 30, 2023 at 8:02 AM
    #131
    raylo
    raylo not so new member
    Frederick, MD
    DashCam, amp/sub, rear seat del, cat shield, AMP power boards
    Do you have pics of these installed? I have a set coming today with the bedliner coating. I am tall enough that I probably wouldn't have got running boards but I have a dodgy left knee that probably will get replaced at some point so the step should make it easier during rehab.
  12. Jan 30, 2023 at 8:16 AM
    #132
    Durtywrench
    Lou
    23 Tundra platinum
    None
    I’m on my second set from Amazon . At the time I didn’t realize they are too short . I’ve seen another member on here and his are the correct length . For some reason Amazon does not give you the right ones . On both orders I had the correct part number that is bedliner coated . The order that showed up is the textured black and too short . I’ve attached a pic of correct length and mine
    Bgoodman4 and raylo[QUOTED] like this.
  13. Jan 30, 2023 at 8:17 AM
    #133
    raylo
    Frederick, MD
    What do you mean, "hang down"? You mean they protrude below the running boards? Maybe the excess can be cut off?
  14. Jan 30, 2023 at 8:17 AM
    #134
    raylo
    Frederick, MD
    Those look great to me. Thanks. As for "too short", shouldn't be the case. I got mine from Real Truck and they require that you enter your cab. And mine is a DC so I guess I get the shortest ones anyway. Hope they don't send the CM version by mistake which would be too long!
    Edit: something odd about your pics, however. The driver's side RB is 2 holes wide (I assume slim model), whilst the passenger side is 3 holes wide, which seems like a regular RB20??
  15. Jan 30, 2023 at 9:49 AM
    #135
    Durtywrench
    Lou
    23 Tundra platinum
    None
    Correct . The ones that are longer are the non slim version which I kind of wish I went with . If you do her crew max ones will you tradesies with me ? Lol
  16. Jan 30, 2023 at 9:50 AM
    #136
    Durtywrench
    Lou
    23 Tundra platinum
    None
    The brackets themself are lower than board not by much . Enough to Piss me off . If you cut or grind you’ll have support problems
  17. Jan 30, 2023 at 9:58 AM
    #137
    raylo
    Frederick, MD
    Odd. Without seeing both of these in person I fail to understand why anything would be different other than losing an inch or so of platform width.
  18. Jan 30, 2023 at 10:34 AM
    #138
    raylo
    Frederick, MD
    Upon further review... It looks like the slims are lowered a bit relative to the truck and they have a little lip. I will guess that these features are designed to keep you from hitting the truck with your feet on these narrower boards.
  19. Jan 30, 2023 at 11:31 AM
    #139
    worksjo
    worksjo New Member
    Are the Go Rhino D6 functionally any wider than the RB20 slims for actually getting your foot on?
  20. Jan 30, 2023 at 11:33 AM
    #140
    Durtywrench
    Lou
    23 Tundra platinum
    None
    From the pictures I see yes. They look a little wider
  21. Jan 30, 2023 at 11:42 AM
    #141
    Ruger19
    Ruger19 New Member
    Bill
    2022 Tundra
    Here is 2 better Pics. Brackets attach in the back of board. Eay62jYbpDwFz1q9mG03rrXtnxXkljI42qxXAdOp_aa6dc1366f11c7725bda02a286515aac57b11375.jpgGlaT-9I-NfBNoklWBSAnGy-KklR44_aQ4z5El5FD_b7eef4f13a5af82ed2f6f4f3bf5d2aa898a85c47.jpg
    Alden and Durtywrench like this.
  22. Jan 30, 2023 at 5:20 PM
    #142
    worksjo
    worksjo New Member
    Ok, you guy got me I ordered the D6’s.
  23. Jan 30, 2023 at 7:02 PM
    #143
    mlive
    mlive New Member
    South Central, PA
    2023 Tundra DC 6.5
    Can someone confirm for me the part number for the TRD running boards for double cab '23 Tundra?
  24. Jan 30, 2023 at 7:37 PM
    #144
    joee12
    joee12 New Member
    I hope you can find the TRD ones. I have been searching for 2 months for the TRD steps for my Crewmax. I have made dozens of phone calls to dealers all over the US with no luck.
    WesternDawg and mlive like this.
  25. Jan 30, 2023 at 7:53 PM
    #145
    worksjo
    worksjo New Member
    shot in the dark here but maybe someone else on the forum is close. There’s a guy selling a set of take off TRD running boards on FB marketplace in Bend Oregon asking $275 obo.
  26. Jan 31, 2023 at 3:55 AM
    #146
    mlive
    mlive New Member
    South Central, PA
    2023 Tundra DC 6.5
    I appreciate it, I have to confirm the part number to make sure I am getting the right thing but I will let you know how I make out!
  27. Jan 31, 2023 at 3:55 AM
    #147
    mlive
    mlive New Member
    South Central, PA
    2023 Tundra DC 6.5
    whole way on PA, won't work for me but thanks for the heads up!
  28. Jan 31, 2023 at 5:35 AM
    #148
    TexasTacoma713
    2023 SR5
    WesternDawg and mlive[QUOTED] like this.
  29. Jan 31, 2023 at 3:41 PM
    #149
    raylo
    Frederick, MD
    My running board install and pics will have to wait. The vendor messed up and sent me the RB 20 Slim set for a CrewMax when the order clearly stated Double Cab. Too cold to install for the next week or so anyway...
  30. Feb 1, 2023 at 4:27 AM
    #150
    raylo
    Frederick, MD
    Just had a thought... if anyone in the DC metro area has a CrewMax and is interested in RB20 Slims with bed liner coating I would bet that the vendor might give you a deal on these in order to avoid having FedEx come pack them up and ship them back. if so, shoot me a PM and we can check that out.
