Which OBD II Code Reader Do you Use?
Discussion in '1st Gen Tundras (2000-2006)' started by WaterOp, Sep 17, 2019.
  1. Sep 17, 2019 at 7:24 AM
    WaterOp
    WaterOp [OP] New Member
    So Lake Tahoe, CA
    2005 Tundra Access V-8 Auto 4x4
    Check Engine light just came on on my 2005 access cab 4x4. :(
    I've been thinking of getting a code reader for a while now, and I guess now is the time.
    A couple of questions for the Forum...
    First, what brand of code reader are you using and do you like it?
    Second, where on the 2005 is the port to plug it in?
    Third, what are the most common "Check Engine" light triggers that you've seen?
    Cheers
  2. Sep 17, 2019 at 7:53 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
  3. Sep 17, 2019 at 8:09 AM
    Randy Morton
    Randy
    Deepinahearta, Texas
    2012 Tundra Double Cab (I call it my Land Yacht)
    I use this one. https://www.amazon.com/gp/product/B015GMRZH2/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1 along with DashCommand https://www.palmerperformance.com/products/dashcommand/ on my phone. I like the reader because it has an on/off button. The first one I bought didn't and the transmitter burned out after a couple of months. I've had this one for a few years with no issues. I originally bought it to use with my Chevy pickup (it was used often back then) and used an OBD extension cable https://www.amazon.com/Veepeak-OBD2...9Y2xpY2tSZWRpcmVjdCZkb05vdExvZ0NsaWNrPXRydWU= so I could access it easily. I did the same in the Tundra, but haven't needed it.
  4. Sep 17, 2019 at 8:41 AM
    Mustanley
    Mustanley Two time totaler
    Hendersonville, NC
    2004 Limited TRD 4x4 DC
    Eibach Shocks/Coils|Doug Thorley Headers|Spintech 3000XL Muffler
  5. Sep 17, 2019 at 8:44 AM
    cnoyes72
    cnoyes72 New Member
    CT
    2018 Tundra SR5 DoubleCab 4x4
    Driver-side assist handle, extang trifect 2.0 tonneau cover
    I use OBD Auto Doctor on my Macbook Air with a generic OBDII-to-USB interface cable I got off Amazon. Works great.
  6. Sep 17, 2019 at 10:16 AM
    tvpierce
    tvpierce Formerly New Member
    Maine
    I use this too, along with the Torque Pro app on my Android phone.
    Riverdale21 and KarmaKannon like this.
  7. Sep 17, 2019 at 10:44 AM
    Gotyour6
    Gotyour6 New Member
    Fairport, NY
    2019 Tundra Pro
    What ever one is in Walmart.
    Basic but does everything I need it to
  8. Sep 17, 2019 at 6:18 PM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    Just a basic plug in and read/erase here.
  9. Sep 18, 2019 at 4:00 AM
    KarmaKannon
    KarmaKannon Master of None
    Utah
    2006 Double Cab w/long travel
    Some junk
  10. Sep 18, 2019 at 9:28 AM
    because_wumbo-truck
    because_wumbo-truck TTC#036 & 1st Degenerate
    Jon
    Houston, Texas
    2006 AC Tundra Limited 4x4 v8
    flowmaster 40, DDI injectors, sliders, bumper
    Scangauge II
    I love it because it actually shows you various gauges in real time. The code reader is just a bonus.
    The OBDII port is easy to find, just look under the dash on driver side and to the left.
    Jmpell and FrenchToasty like this.
  11. Aug 17, 2022 at 1:55 PM
    LameUsername
    LameUsername New Member
    Erica
    2007 Tundra TRD
    Hey all! new here and this is probably a dumb question, but here it goes...I have the cable that plugs into the OBD2 port under the dash and plugs into the USB on my laptop. I am curious, what is the best program I can download onto my laptop that will give me codes and help me diagnose issues using the cord I already have? I've never had to diagnose my tundra until now and pretty much every dash light is blinking at me :oops:.
  12. Aug 17, 2022 at 2:10 PM
    MOTORHEAD
    MOTORHEAD New Member
    DAVID
    LOS ANGELES CA
    2002 Toyota Tundra SR5 V-8 4.7L WHITE
    RCD 6" SUSPENSION LIFT,ICON EXTENDED FRONT COILOVERS,3" BODY LIFT,CAMBURG UPPER CONTROL ARMS.REAR DISK BRAKE CONVERSION,BIG BRAKE FRONT CONVERSION, AND MANY MORE
    Autel tablet mx808
  13. Aug 17, 2022 at 2:12 PM
    Every dash light blinking at you is a very specific symptom actually, you may want to create a new thread about that.
    But to answer your question, most chain auto parts stores will scan for free if you can get to one.
    If you already have the cable, Torque Pro is available for PC, not sure if you can try before buying or get a limited feature set w/o paying: https://torqueproapk.org/torque-pro-for-pc/
    OBD Auto Doctor is freeware with a lot of features, but you gotta upgrade to get the premium stuff: https://www.obdautodoctor.com/download/
  14. Aug 17, 2022 at 2:12 PM
    Lots of dudes here have the mx808 and mk808. Not gonna lie, I'd actually like to have one!
  15. Aug 17, 2022 at 5:54 PM
    Riverdale21
    Riverdale21 Speed seeker
    OTP ATL
    06 DC SR5 Tundra TRD Off Road
    Dirt Deeds injectors, Addco rear sway, AEM dry flow air filter, last ever set of Stan's Try-Y headers, Borla full custom exhaust, front level, wheel spacers, and lots of electronics.
  16. Sep 6, 2022 at 8:14 AM
    MOTORHEAD
    DAVID
    LOS ANGELES CA
    I love my autel , does so much more than other ones. Just needs to be updaed
  17. Oct 14, 2022 at 7:22 AM
    You're posting this question in the 1st Gen forum.
    WrongWayDave[QUOTED] likes this.
  18. Oct 14, 2022 at 12:59 PM
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    @shifty` How do you like your OBDLink MX+ reader? Also what app are you using it with?
  19. Oct 14, 2022 at 1:29 PM
    Pucks18
    Pucks18 Fleabit peanut monkey
    2001 Tundra 4x4 Limited trd
    Don't get one unless you get a scangauge 2. Or else just go to the auto store if you just need codes rewd
  20. Oct 14, 2022 at 1:43 PM
    It's still in the box. I'm just going to use their default app for now, which is what many other other apps are based off. Main focus right now is wrapping up a major remodel in my basement.
