Which magic bean is the best?
Discussion in '1st Gen Builds (2000-2006)' started by Rsrguy3, Feb 8, 2021.
  1. Feb 8, 2021 at 7:35 PM
    Rsrguy3
    Rsrguy3 [OP] New Member
    You can pick any engine t-case/tranny.... You're goal is maximum fuel efficiency, towing torque and off road dependability...
    The chassis, Toyota t100...
    What do you pick?
    I like the Toyota brand for dependability, but I am not attached to it unless there is a way to get solid mpg's... A light weight mill would be nice but I have no idea what good options exist. Gas diesel whatever.... What do you pick and why?
  2. Feb 13, 2021 at 8:05 AM
    Maximum MPG? good luck with gas. That contradicts the maximum torque requirement. An engine cannot be tuned to be good at both. Torque is a product of energy production, gotta burn gas to make torque. Sounds like you've got a diesel in your future. They are more efficient in that regard, but typically heavier. And the fuel is more expensive, negating some of the advantage of efficiency. But gobs of torque. Maybe a 4cyl deisel with a 5 speed trans with OD. Hilux mill, D-4D is a great one, although likely not widely available. Not sure you can even get one and use it legally stateside. It's a dreamer's option really. Your real options are the factory available V6, and maybe some sort of 2.7L 4 banger swap with manual. Neither will give you great MPG. Neither will give you great towing torque.
  3. Feb 13, 2021 at 8:09 AM
    Professional Hand Model
    Hand Protectors
  4. Feb 13, 2021 at 8:26 AM
    YardBird
    YardBird Native San Diegan
    Jonesy
    2005 RCLB
  5. Feb 13, 2021 at 10:41 AM
    des2mtn
    SW
    2004 Black DC Limited 4x4
    Tonto cover
    I pick America's best selling truck series™.
  6. Feb 14, 2021 at 10:58 AM
    Rsrguy3
    Ya... I know it’s a tall and stooopid order for sure.
    This is way, way different than any of the other hot rod builds I’ve done.. none of them were built to be DD’s.
    My hunch is 22 mpg when not towing shouldn’t be impossible with the correct mill properly OD’d.
    I’ve just never rodded for efficiency...
    My bet….? That it’ll take a long time to figure out the best combo, and that tall skinny tires are in my future...
    In the end I want this to be the last truck a acquire, so I want to get it right... lm budgeting 25k
  7. Feb 14, 2021 at 10:59 AM
    Rsrguy3
    To who’s propo are you referencing?
  8. Feb 14, 2021 at 11:38 AM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    The very best thing you can do for gas mileage is --------------- drop the price of gasoline. At some point it becomes of supreme indifference.
  9. Feb 14, 2021 at 12:05 PM
    Rsrguy3
    Because that's going to happen with eviro cataclismists running the show....
  10. Feb 15, 2021 at 7:12 AM
    lsaami
    lsaami Let ‘er buck
    Minnesota
    2000 Tundra 4x4 "$1100 Build"
    honestly, your best bet is probably a 4BT swap and turn it up a bit. there's a guy who did that to an old dent side F250 and he said he average low 20s in fuel economy.
    https://youtu.be/W80B0xplPoI
    Darkness likes this.
  11. Feb 15, 2021 at 6:08 PM
    Lovetrucks
    Lovetrucks Member
    2019 Ram Rebel
    You could look at an old Chevy 350 swap . With the right transmission and the weight of the little T100 you’d barely break idle getting it to move .
