Which LineX coating?
Discussion in 'General Tundra Discussion' started by airgunner, Apr 25, 2018.
  1. Apr 25, 2018 at 9:24 AM
    airgunner
    airgunner [OP] New Member
    N-KY
    2015 DC MGM TRD
    So for a spray in Liner, seems LineX is the way to go? I'm getting ready to call a local LineX dealer to make an appointment but I'm not sure which version to go with (Standard, Premium, Pro, etc.).
    My truck isn't used for anything extreme. Probably the harshest thing I do with it is shoveling out a load of dirt or mulch.
    I was considering at least getting the premium for the extra UV resistance as my truck is parked outside all day but I just ordered a Bakflip Mx4 so the bed will be covered most of the time. I'm not worried about color matching, black is just fine.
    So I'm thinking the standard will be fine for me? What should I expect to pay these days (I have the 6.6" bed and will have them keep it under the bed rails)?
    Thanks
    Y0TA PR0 likes this.
  2. Apr 25, 2018 at 9:42 AM
    trey169
    trey169 New Member
    SF Bay Area
    2007 Tundra DC SR5
    I didn't do Line-X, ended up doing Bullet Liner, which is a company started from a guy who branched off from Line-X. Only reason I went with it vs Line-X is cost was lower and it appeared thicker and included the UV protectant. I paid $599, I was quoted Line-X from two different places for the premium version at about $650 and the other was around $730. I live in CA so cost will vary depending on where you live.
    rons23 likes this.
  3. Apr 25, 2018 at 10:30 AM
    airgunner
    N-KY
    2015 DC MGM TRD
    I just called the local LineX shop. $479 + tax for the Standard LineX coating. +$150 for the Premium (UV resistant) version.
    I've looked at (online) and considered the Bullet Liner before. There is a shop about 45 minutes away who does it and I called them too and it is a little less expensive ($450 + tax but that includes UV protection)
    I'm hesitant to go with any new or lesser known alternative. I did that with my last truck. That was back in like 2001 and I forget what that product was even called? Whatever it was, it had a "lifetime warranty" which ended up being worthless because the company went out of business before my liner started to having issues. Even if Bullet Liner doesn't go out of business, there is only one shop anywhere around here who does it so what happens if I have issue and they are no longer in business?
    The only reason I'm even considering it is, my last truck liner was a soft, grippy material like Rhino liner and I liked the fact that I could put stuff in the back and it wouldn't slide around. That's the one thing I do not like about LineX but on the other hand, I do wonder if that's why LineX seems to hold up better then it's softer competitors?
  4. Apr 25, 2018 at 10:49 AM
    trey169
    trey169 New Member
    SF Bay Area
    2007 Tundra DC SR5
    Sounds like you should go with Line-X, and I would get the premium. I also have only one Bullet Liner dealer in my area, and I'm not too worried about needing any warranty work as its a high end product like Line-X. For piece of mind spend the extra money and get Line-X premium. Reality is it all comes down to the prep. Bullet Liner spent 5 hours prepping my car and my bed looked new when I brought it in. They also removed the bed bolts and sprayed in between the the tailgate and bed and the vertical rails where the tailgate meets the bed.IMG_0114 11.02.34 PM.jpgIMG_0115 11.02.37 PM.jpg
    8MINT8 likes this.
  5. Apr 25, 2018 at 10:55 AM
    seniramsu
    seniramsu Pro Runnin
    Nate
    VA
    2017 TRD Pro Tundra Wht
    That looks really good:thumbsup:
  6. Apr 25, 2018 at 11:00 AM
    Atomic City Tundra
    Devin
    New Mexico
    2013 Tundra 5.7FFV CM 4X4
    I have had Line-X in several of my trucks/trail rigs. It is a great product. If you care about it looking "shiny" for longer than about 6 months - don't get the standard. In general, I do standard for stuff that isn't easy to see - like inside the bed. But, for applications where it is easy to see, do the UV upgrade.
  7. Apr 25, 2018 at 12:27 PM
    15whtrd
    15whtrd Mr. Blonde
    I got linex premium in my 6 1/2 foot bed for $600 even. Bring cash. Then I bought an $80 rubber Toyota bed mat to keep things in place.
    ChucklesToy likes this.
  8. Apr 25, 2018 at 1:07 PM
    OCxCEMENT
    OCxCEMENT HI :)
    Orange County, CA
    2018 Tundra Crew Max Cement TRD-Off-Road 4x4
    Paid $450 for my Bullet Liner. Just got it done roughly a week ago. A buddy of mine that saw it said it looks thicker compaired to other.
    15whtrd likes this.
  9. Apr 25, 2018 at 1:18 PM
    TheBeast The Beach
    line X premium
    15whtrd likes this.
  10. Apr 25, 2018 at 6:10 PM
    airosey
    airosey 2009 CrewMax Limited 4x4
    East TN
    Slightly modified 2009 CrewMax Limited 4x4
    09 Tundra CrewMax Limited TRD Supercharger with URD pulley Tuned by OrangeVirus tuning (OV Tune) TRD Big Brake Kit with SS lines and titanium backing plates StopTech rear sport axle pack (rotors, pads, and SS lines) 7” Pro Comp lift 3” Performance Products Body Lift Coachbuilder 1” coilover shims Coachbuilder +3 shackles Coachbuilder Tie-rod ends 22x14 -70 Fuel Lethal’s - 2 piece 38x15.5 Mickey Thompson Baja Boss M/T’s King Shocks with remote reservoirs front and rear Nitro 5.29 gears front and rear Auburn LSD SPC adjustable UCA’s BAM 8” exhaust Pro Comp Traction Bars Enve Grille Smittybilt M1 front bumper Rough Country 12k lbs winch Demon Hook shackles front and rear Baja Designs Squadron Sport Amber and clear fog lights ADD HoneyBadger Rear Bumper with Rigid SR-Q reverse lights Sequoia Headlight conversion Switch-Pros SP-9100 mounted in overhead console SD Off-road MT under-hood tray AEM boost and afr gauges Hypertech Speedometer calibrator Bed and rear bumper are Bulletlined American Flag Headliner Mammoth Guards patriot edition Alpha and Omega Fabrication Patriot Hood shield 3rd gen door panels and steering wheel ProSpeed Catchcan Hornblasters Outlaw train horns Tufskinz real carbon fiber overlays Tufskinz carbon fiber B panels vLEDs footwell lighting front and rear vLED puddle lamps Lighting Trendz flow series wheel rings 16 RGB rock lights Toyota Bedmat Bestop Power folding steps Undercover bed cover Undercover SwingCase 4 gallon Rotopax fuel can Here’s a rundown of the audio setup. -Active front stage using a JL Audio TwK88 DSP, Focal 165KRX2 component speakers, powered by a JL Audio HD900/5 -Passive rear setup with Focal 165KRX2 component speakers -2 JL Audio Stealthboxes (13TW5’s) powered by a JL Audio HD1200/1 -Sony XAV-9500ES float mount display with a PAC Radio Pro 4 -Odyssey battery -JL 0 gauge power and ground cables -AudioQuest X-2 speaker cables and Golden Gate RCA interconnects -Entire cab has been lined with Dynamat Extreme and 1/4 CCF Amps and dsp are mounted under the passenger seat with a SoundsGoodStereo mounting plate.
    I really like the bullet liner. I had my bed and side steps sprayed.
    rons23 likes this.
  11. Apr 25, 2018 at 6:12 PM
    15whtrd
    15whtrd Mr. Blonde
    I like that they wrapped it around the edges. Nice touch.
    OCxCEMENT[QUOTED] likes this.
  12. Apr 25, 2018 at 7:38 PM
    trey169
    trey169 New Member
    SF Bay Area
    2007 Tundra DC SR5
    Might want to ask if they can wrap it to the edge like they did on mineIMG_0275.jpg IMG_0276.jpg
    OCxCEMENT likes this.
  13. Apr 25, 2018 at 8:34 PM
    Borgs
    Borgs New Member
    PA
    Just got LineX premium last week. $600. I liked the gloss and UV protectant if the premium.
  14. Apr 26, 2018 at 2:19 AM
    rons23
    rons23 Get The Led Out!!!
    Ron
    Kill Devil Hills
    2008 Nautical Blue TRD
    X2 :thumbsup:
    airosey[QUOTED] likes this.
  15. Apr 26, 2018 at 3:02 AM
    Tundraplatinum
    Tundraplatinum New Member
    2016 Platinum CM
    Linex premium
