Which Lift Kit do I get
Discussion in 'Suspension' started by Les7311, Jan 28, 2017.
  1. Jan 28, 2017 at 9:56 AM
    Les7311
    Les7311 [OP] Look up, what do you see
    2008 Blue Tundra TRD 4x4
    Sorry to beat a dead horse
    Suspension Connection
    Rough Country
    Tuff Country
    Am leaning towards suspension connection for a 6 in lift kit, cost about $500
    Tuff country is a little over $1k
    What's your thoughts on suspension connection kit for my 08?
    Ready to pull the trigger
  2. Jan 28, 2017 at 10:40 AM
    What size tires u gona run?... Check out toytec.com boss kit
    Law323, BlueFalconActual and T-Rex266 like this.
  3. Jan 28, 2017 at 10:56 AM
    CaptTyler
    CaptTyler Life’s too short to have an ugly boat.
    Tyler
    2018 Ram 2500 Cummins
    Be careful, it's probably that cheap for a reason.
    ToyMD, Law323, CM-LENNY and 4 others like this.
  4. Jan 28, 2017 at 11:02 AM
    Midnighttaco08
    Midnighttaco08 High Quality H2O Inspector
    Sam
    Gilbert, AZ
    2017 Quicksand TRD OR 4x4 2008 Indigo Ink Tacoma TRDOR
    None yet!
    Definatly.
    If there is one thing I've learned through mods on my vehicles, its this. :amen:
    Law323, CM-LENNY, geno0506 and 4 others like this.
  5. Jan 28, 2017 at 1:05 PM
  6. Jan 28, 2017 at 1:07 PM
    chphilo
    chphilo Tundra addict
    Western PA
    I have not heard of Suspension Connection but I would not cheap out on a lift kit. It $hit starts to break, then it will end up costing you a lot more than what you save initially. I heard good things about BDS. A lot of guys seem to run Pro Comp. I personally prefer 3 inch coilover lift. An excellent balance between ground clearance and stable center of gravity, imo.
    Law323 likes this.
  7. Jan 28, 2017 at 1:12 PM
    [​IMG].................Call ToyTec.................
    Toll Free 1-866-254-0076
    303-255- 4959
    Law323, rons23, geno0506 and 4 others like this.
  8. Jan 28, 2017 at 2:29 PM
    Les7311
    Am pulling triggers.
    20x10 ballistics rims with 35 tires.
    I do agree that you pay for what you get. So throw it at this OP. Am going with a 6 inch lift.
    The mods have started, and today was no better seeing " lifted Ryder " around me in Maryland.....
    What's a good kit from whom and about how much.....( new to the truck and lift world)???
    https://www.suspensionconnection.com/
  9. Jan 28, 2017 at 2:46 PM
    What are u looking for? Wheeling? 50/50? Pure comfort? Must it be 6"? Are you going to be able clear parking structures, garages and such?
    On the wheels- go with 18". More sidewall protectuon and cheaper.
    zcarpenter92, Law323 and Black Wolf like this.
  10. Jan 29, 2017 at 12:18 AM
    geno0506
    geno0506 New Member
    Michael
    what are you going with bud!
  11. Jan 29, 2017 at 4:47 AM
    Les7311
    Sorry for the late response. A picture says a million words. I don't know if this is a 6 inch lift, if it's more then I will keep it at six. I like this look.
    This will be a weekend truck or when it snows.
    Rims already purchased, so whose kit do I buy to get there at 6 inches lift.
  12. Jan 29, 2017 at 6:12 AM
    rons23
    rons23 Get The Led Out!!!
    Ron
    Kill Devil Hills
    2008 Nautical Blue TRD
    Definitely not supreme connection, just sayin. As stated above, Toytec, Wheelers Offroad, or Fabtech. Good luck and post some pics when done
  13. Jan 29, 2017 at 7:34 AM
    I'd definitely go with a highly regarded source/supplier that will also provide excellent service before and after install. There are several rides here with decent 6" lift setups. I haven't heard of Suspension Connection either. Doesn't mean they suck. 6" inch requires some serious geometry changes to begin with. The install is just as important as the quality of the lift kit. Tuff Country is USA made and may be OK. I'd want a lift that is known to be beyond OK. IMHO.
    CM-LENNY, Les7311[OP] and Law323 like this.
  14. Jan 29, 2017 at 7:46 AM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    BDS or Zone, same company, would be my choice for a 6" lift. The Zone is a 5". With 35" tires you'll be adding another ~1" either way.
    Les7311[OP] likes this.
  15. Jan 29, 2017 at 7:47 AM
    Midnighttaco08
    Sam
    Gilbert, AZ
    None yet!
    No plans as of yet.
    But most likely camburg upper arms and some Kings up front and a custom deaver pack in the rear.
    Just speculation right now.
    T-Rex266 likes this.
  16. Jan 29, 2017 at 8:02 AM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    Honestly, I'd try to find a kit where you don't have to cut and weld anything on your truck in case you'd want to return to stock or go a little shorter.
    Stay away from spacers.
    Midnighttaco08 and Les7311[OP] like this.
  17. Jan 29, 2017 at 8:10 AM
    Les7311
    These are the shoes with 35 grabber. I read everyone loud and clear.
    Oh, I plan to do the lift with help in my garage....figured if we can move the tranny and engine from one car to another, how hard could it be with a lift kit????
    Will def post pics. So far only tin and tonneau so far.....
    rons23, Black Wolf and Law323 like this.
  18. Jan 29, 2017 at 8:18 AM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    Nice wheels!!!
    Yeah it's always best to do your own work when/if you can!!
    Les7311[QUOTED][OP] likes this.
  19. Jan 29, 2017 at 8:45 AM
    ToyTec does carry the T1 Zone 5" lift for around $1300. There may be a Tundras.com discount. ToyTec wouldn't have it on their website if it sucked.
    Les7311[OP] and T-Rex266 like this.
  20. Jan 29, 2017 at 9:10 AM
    trayday
    trayday New Member
    Oregon
    2015 limited CM 5.7
    I have a 7" BDS and no complaints of the lift. The front subframe is cut and weld. If you drive hard off road, I'd replace the steering rack bushings while your in there.
  21. Jan 29, 2017 at 10:32 AM
    Les7311
    True dat!
    Last weekend we replaced the spark plugs, valve cover gaskets, and PCV.
    Gas mileage went from 330 DTE, to 440 (no kidding). Some of the plugs were oil soaked.
    Law323[QUOTED] likes this.
  22. Jan 29, 2017 at 10:34 AM
    Les7311
    If I go 7 inches plus wheels, I don't think I'll be able to park in the garage........unless I adjust the garage pull brackets to bring in door another 8 inches...... hhhhmmmm
  23. Jan 29, 2017 at 10:45 AM
    Local46er
    Local46er New Member
    Neil
    Ontario Canada
    2016 Tundra SR5 TRD double cab
    500$ seems real cheap for a 6" lift. I was going to put a rough country on mine, but with more research and help from this site I decided to go with the 3/1 toytec boss lift with the uca.
    T-Rex266, TXMiamiFan and zcarpenter92 like this.
  24. Jan 29, 2017 at 11:30 AM
    Les7311
  25. Jan 29, 2017 at 5:18 PM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    Damn! And this is off your tundy? How many miles is on it?
  26. Jan 29, 2017 at 7:01 PM
    Les7311
    Purchased an 08 with a little over 100k miles. It will not be a daily driver, so it's putting my fingerprints all over it like everything else.
  27. Jan 29, 2017 at 7:23 PM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    Well that makes more sense. I was thinking a newer one.
  28. Feb 10, 2017 at 8:06 AM
    Les7311
    IMG_0859.jpg IMG_0866.jpg IMG_0857.jpg IMG_0859.jpg IMG_0866.jpg IMG_0857.jpg Well the surgery is compleIMG_0859.jpg IMG_0866.jpg IMG_0857.jpg te for the 6 inch Rough Country lift kit....
  29. Feb 10, 2017 at 11:14 AM
    kalani1126
    kalani1126 New Member
    Kalani
    Henderson, NV by way of Honolulu HI
    Unmodded.....yet
    Nice!!! Did you have to do any trimming to avoid rubbing with 35"s?
  30. Feb 10, 2017 at 2:03 PM
    Les7311
    Yeah the shop cut out a "C" shaped in middle of the fender liner the picture does not show justice with the shadow. I can live with it until I figure out a mod to seal the hole. IMG_0873.jpg
