Which headlamp assembly unit do I need????
Discussion in 'New Member Introductions' started by justsomedude, May 21, 2021.
  1. May 21, 2021 at 2:14 PM
    justsomedude
    justsomedude [OP] New Member
    Jeremy
    2017 Toyota Tundra TSS
    Hey all,
    I am currently working on replacing the stock headlamp assembly in my 2017 Tundra TSS. I am wanting to switch to LED headlights from the stock halogen ones. I found some on CarID and after watching the video on installing them I went with it. 1 problem, the headlamp unit installed on the video, though looking identical, were not the ones that were actually being sold. The ones that came only had 3 ports for wiring, but my truck had 4 wires that needed to be connected. Obviously I am returning these and ordering the correct ones. So I have a question...
    My truck has halogen drl. When buying the website asks if my truck has halogen or led drls. if I am switching to a LED headlamp assembly unit does it matter? I would like to have led drls on my truck, but I'm afraid if I order those they might not work correctly. I just don't want to order the wrong ones again and have to deal with installing and removing them becasue i was a moron. Have a great day and thanks for your help!
  2. May 21, 2021 at 2:26 PM
    If you are going from a halogen headlight to an LED headlight, you will need a harness. Contact @iHacker for this to confirm what you need from him. Which lights were you looking at on CarId? Some of the aftermarket lights are junk, and CarId is more expensive than other sources.
    Barrett50 likes this.
  3. May 21, 2021 at 2:40 PM
    justsomedude
    Jeremy
  4. May 21, 2021 at 2:43 PM
  5. May 21, 2021 at 2:48 PM
    justsomedude
    Jeremy
    Should i go with the 2017? Sounds like a dumb question, but from some of the threads I have read on here it looks like some have used 2018 or even 2019 headlamp assembly units on a different year model truck.
  6. May 21, 2021 at 2:51 PM
    TexAggie
    TexAggie New Member
    Eric
    2017 CM
    They are asking what your truck has, not what you want on the new headlights. You need to select halogen DRL's as that's what you have stock. I'd recommend the Alphrex over these, you can get some under $500, but I'd go with the nova's for $550.
    https://www.amazon.com/14-19-TUNDRA...harex+tundra+headlights&qid=1621633689&sr=8-8
  7. May 21, 2021 at 2:56 PM
    justsomedude
    Jeremy
    I could get down with those lights. First I need to make sure that CarID is going to take these back. then I need to find those Novas in the blacked out version if they have them!
  8. May 21, 2021 at 2:57 PM
    TexAggie
    TexAggie New Member
    Eric
    2017 CM
    I have not found the blacked out for that price...
  9. May 21, 2021 at 7:17 PM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    Hope you get the lights you want! Welcome from LA (Lower Alabama)!
  10. May 21, 2021 at 7:23 PM
    jdg1982
    jdg1982 New Member
    Florence, Colorado (From Louisiana)
    2017 Magnetic Gray Tundra SR5 4x4
  11. May 22, 2021 at 11:48 AM
    Dr Doobie
    Dr Doobie Growing member
    Talkeetna,Alaska
    '07 RCSB 5.7 SC'd 4x4 SSM
    Welcome from Alaska
  12. May 23, 2021 at 2:12 AM
    AZ Red Nek
    AZ Red Nek Native of the Valley, Bowl, Basin, ETC...
    Chuck
    2016 White SR5 Crew 4x4
    Hidden 1200# Waren winch, Baja Desgins lights, Switch Pro switch and controller, S&B air box and in bed tool box.
    Welcome from Phoenix
