Which Gaia layers do you use?
Discussion in 'Outdoors' started by Cruzer, Jul 26, 2022.
  1. Jul 26, 2022 at 7:32 AM
    Cruzer
    Cruzer [OP] Wheeling Full Size
    Cruz
    Sunnyvale, CA
    I find that I'm always tweaking my Gaia layers to try and find the best combo. I typically run this setup during the summer so that I can see fire and smoke updates. I also like to know who's property I'm on - no point going down an unknown trail if you know it's leading to someone's personal property. I stopped using USFS 2016 because I have found it to be inaccurate and it doesn't really play well with the other layers.
    Maybe I'm not using my Gaia to it's full potential. Which is why I want to know which layers do you use and why?
    KevinK, Sunnier and eccracer104 like this.
  2. Jul 26, 2022 at 7:52 AM
    eick
    eick New Member
    2020 CrewMax TRD Off Road
    They just released a new ‘Overlander’ one
    Cruzer[OP] likes this.
  3. Jul 26, 2022 at 8:13 AM
    Cruzer
    Cruz
    Sunnyvale, CA
    Hmmmmm. I just tested it out. It doesn't play well with my Satellite Topo base layer. I'm not able to see the MVUM or USFS trails that it states it includes o_O
    I put the Overland map as my base layer:
    Compared that with my original setup and the MVUM trail is present:
    Maybe they still need to work on it :monocle:
  4. Jul 26, 2022 at 8:14 AM
    KevinK
    KevinK SGU - High Speed Overlander
    Back in Arizona. Again.
    SGU - Speed Glampers Uberfahrt
    Tundras to Sedona
    This is my basic layout. I add public and private land if I have a question about where I am. I found using the USFS and USGS maps together helps me find more of the old overgrown trails that fall out of use. Swapping transparency back and forth.
    Gaia recently released this map pack specifically for off road. The Overland pack they call it. Seems good from the toilet so far.
  5. Jul 26, 2022 at 8:16 AM
    Cruzer
    Cruz
    Sunnyvale, CA
    Gonna check out USGS. I just did a comparison of the Overland map and it doesn't appear to be complete.
  6. Jul 26, 2022 at 8:32 AM
    eccracer104
    eccracer104 Dirty Paws Off-Road
    San Diego, CA
    2011 Tundra 5.7 4x4 CM
    I’ve been using Gaia topo as my base, and overlay MVUM (USFS). Rather interested to see what you guys are using, and how you’re using them as mine is about as basic as it gets - but it’s been getting the job done.
    Granted I usually try to pre-route the trails I’m headed for so they’re visible.
  7. Jul 26, 2022 at 9:33 AM
    JCBerb
    JCBerb Semper Fi
    Joel
    2017 CM LImited
    C4 Overland bumper, BD SAE fogs, Leitner Designs Rack, Rago Bed Channel Stiffiners, Warn Xeon 12S Plarinum, Bedslide, Front Runner Roof Rack, roof rack solar panels, RCI Full under carriage aluminum studs, RCI rear diff skid, Rago dash plate, Rago accessory panels, OEM LED headlights with wiring harness.
    I was having similar issues. Seemed as if some layers were conflicting or not even appearing.
