Where to put switch on a 1794 for the anytime front/rear camera?
Discussion in '2.5 Gen TRD Pro (2014-2021)' started by Shadowfax1, Feb 16, 2022.
  1. Feb 16, 2022 at 3:03 PM
    Shadowfax1
    Shadowfax1 [OP] New Member
    San Francisco Bay Area
    2018 Toyota Tundra 1794 Edition w/ TRD Off-Road Package
    I'm planning to replace my head unit with one that includes several cameras, but it hasn't been available for over a year and I don't imagine it will be anytime soon. So for now, I'm thinking of sticking it out with the crap JBL system but at least adding a front camera that is badly needed.
    Looking at this Anytime Front & Backup Camera kit:
    https://www.anytimebackupcamera.com...ucts/anytime-backup-and-front-camera-full-kit
    For those of you with this kit or similar though, and who have a 1794 Edition, where on earth are you putting the switch?
    I am NOT interested in getting a sPOD yet. I know I will need one someday, but not any time soon and I don't want to have to spend the money on it yet. But the 1794 seems to have NO blanks anywhere...
  2. Feb 16, 2022 at 3:09 PM
    Shadowfax1
    Sorry. Meant to post this in the 2.5 Gen Tundra, not 2.5 Gen TRD Pro category. I keep making that mistake.
  3. Feb 16, 2022 at 3:13 PM
    mountainpete
    mountainpete Explore more
    2018 Cement Crewmax TRD
    Function before sparkle.
  4. Feb 16, 2022 at 3:33 PM
    Badge618
    Badge618 New Member
    Lassen County, Ca
    2019 TRD Pro Voodoo Blue
    TundraTex and Shadowfax1[OP] like this.
  5. Feb 16, 2022 at 3:38 PM
    Piki
    Piki New Member
    2017 Tundra crewmax 1794 TRD
    This is my solution for the problem
  6. Feb 16, 2022 at 4:12 PM
    Shadowfax1
    Bay Area, but spending a lot of time farther up to the northeast corner of the state in the coming weeks. #astrophotography -- clearer, darker skies up there!
  7. Feb 16, 2022 at 4:13 PM
    Shadowfax1
    Beautifully done. Not sure I have the courage to cut holes in the gorgeous leather there. But that's a nice way of doing it. Outta curiosity, you have the camera switch, and some external lights. But the rear window switch...did you move it from the dash?
  8. Feb 16, 2022 at 4:19 PM
    Shadowfax1
  9. Feb 16, 2022 at 5:31 PM
    Piki
    Piki New Member
    Thanks. Yes I relocated rear window switch too. Much better location.
  10. Feb 16, 2022 at 5:44 PM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    The glass breakage sensor works just as well shoved behind the panel. I did that and used that spot. It's the exact same size.
    AggiePhil, GELCW and TundraTex like this.
  11. Feb 16, 2022 at 5:48 PM
    Rustedfenders
    Rustedfenders If it ain't broke, don't fix it.
    Wally
    Rosedale Md.
    2016 Blazing Blue Pearl TRD Tundra Crew Max
    Aries 4" Bull Bar, 3-2 Level Lift Havoc Stainless hoop steps.
    What is the center switch for?
  12. Feb 16, 2022 at 5:56 PM
    AZTundra
    Paul
    Phoenix, AZ
    Here is mine. Out of sight and yet right at your fingertips when resting your arm on the armrest.
    GELCW, Shadowfax1[OP] and rothmigo like this.
  13. Feb 16, 2022 at 6:35 PM
    rothmigo
    rothmigo New Member
    DFW TX
    2020 Tundra Crewmax Platinum
    7" BDS/Fox, 5.29, 37x13.50 Nitto, 22x12 Hostile Rage,BAM
    Thanks for this idea, like how accessible they are there. Did you have to add wiring to the FRAC harness to reach that location? I'm preparing to install the FRAC on my Platinum. One thought is to push out the glass break sensor with pro of the OEM style switch looking awesome, but would like it a bit closer to finger tips. Another thought I have is above the 4x4 dial where can reach with hand on shifter lever or beside the tow haul but need to see what's back there.
  14. Feb 16, 2022 at 6:46 PM
    AZTundra
    Paul
    Phoenix, AZ
    The wires did have to be lengthened a little to reach that spot on the center console below the armrest. Simple to lengthen if you decide to go that route. I have a couple more pictures that might help with the hole placement (let me know if you want me to post those). It's a tight fit in there, but doable.
  15. Feb 16, 2022 at 8:27 PM
    Piki
    Piki New Member
    I don't know yet. ;)
  16. Feb 17, 2022 at 3:39 AM
    TundraTex
    TundraTex FRAC On!
    Lou
    DFW Texas
    '16 TSS CM 4x4
    @Shadowfax1 let me know if you have any FRAC questions. I'll be happy to assist.
    FYI, the round switches in the @AZTundra post are included with the basic FRAC kit. You can also add the OEM-style switch shown in the @Piki post.
    -Lou
  17. Feb 17, 2022 at 4:13 PM
    dkrou
    dkrou New Member
    dan
    2019 tundra
    I have a kenwood 1007 HU in my 19 truck....I recently put in a blackvue 2 channel dash cam. wouldn't mind getting front and rear on demand on my bigscreen. Sounds like I need some wire harness and a front camera????
  18. Feb 17, 2022 at 4:34 PM
    TundraTex
    TundraTex FRAC On!
    Lou
    DFW Texas
    '16 TSS CM 4x4
    The FRAC Harness will do that for you. And the Natika Front Camera available on Amazon will fit the bill for a front grill cam. As long as you used plug and play adapters to install your aftermarket HU, the FRAC harness will work great.
  19. Feb 18, 2022 at 5:31 AM
    dkrou
    dkrou New Member
    dan
    2019 tundra
    That is great to know...Unfortunately few dash cams compatible with those big screens.
  20. Feb 18, 2022 at 1:06 PM
    Shadowfax1
    How much length did you have to add? I assume one does that by getting another matching wire from any electronics supply store, stripping the ends of both wires, and then soldering them together? Or is there an easier way to lengthen it?
    On the front face of the console where you installed those, is there space for standard OEM style switches, or just the round ones you used?
    AZTundra[QUOTED] likes this.
  21. Feb 18, 2022 at 1:08 PM
    Shadowfax1
    So, how did you actually do this? Were you able to find an aftermarket piece that included the cut-out and mount for switches? Or did you cut the whole yourself in the existing piece using some fancy (and obviously skilled) cutting work? Correct me if I’m wrong, but it’s a single piece that includes the chrome box around the shifter and the surrounding leather, all the way down the lower edge below your switches.
  22. Feb 18, 2022 at 1:35 PM
    Piki
    Piki New Member
    Just cut the hole, glued edges around and installed Switches.
    dandrilla, DIYDad and rothmigo like this.
  23. Feb 18, 2022 at 1:48 PM
    thedonn
    thedonn New Member
    a nice front camera is like $40 and it plugs right in to the kenwood. it would be nice to see the blackvue stuff on the screen though once in a while
  24. Feb 18, 2022 at 1:49 PM
    AZTundra
    Paul
    Phoenix, AZ
    I actually got my harness from another member on here who had already lengthened the wires and had the switches installed in the same place as mine. If I had to guess they might be extended 2-3ft. You have the correct idea - get yourself some wire and either use crimp connectors or solder and heat shrink tubing to connect them, not hard at all to do.
    As for being able to install a standard OEM style switch there I'm not sure. I don't know off hand how they snap into place, but I don't think it would be as simple. Maybe someone else here that's worked with the OEM style switch can speak to that.
  25. Feb 18, 2022 at 1:51 PM
    thedonn
    thedonn New Member
    which head unit?
  26. Feb 18, 2022 at 1:53 PM
    thedonn
    thedonn New Member
    thats a great use of wasted space!
  27. Feb 18, 2022 at 2:12 PM
    AZTundra
    Paul
    Phoenix, AZ
    Thanks. If you didn't know they were there you'd never see them.
    Shadowfax1[OP] likes this.
  28. Feb 19, 2022 at 4:19 PM
    Nickatnight
    Nickatnight New Member
    Nick
    98445
    2021 1794 Tundra
    Rhino running boards, Amber running lights, Underhood automatic LED Lighting, OEM Fender Flares, Tech12 Volt New Killer Audio System with factory Head Unit.
    Piki, any chance on getting an underneath shot of how the hole was cut, and how the switch box was secured, on your 1794? Looks pretty clean, thanks
  29. Feb 19, 2022 at 4:22 PM
    Adam @abomb60 makes them. He has a thread about them.
    https://www.tundras.com/threads/fs-3-switch-panel-insert-plate.94140/#post-2377487
  30. Feb 19, 2022 at 4:40 PM
    Jego
    Jego New Member
    Orlando
    PR
    2018 Tundra 1794
    I installed it below the AC controls.
    GELCW likes this.
