Where should I buy a complete rear bumper kit from?
Discussion in '1st Gen Tundras (2000-2006)' started by Pucks18, Sep 30, 2020.
  1. Sep 30, 2020 at 4:33 PM
    Pucks18
    Pucks18 [OP] Fleabit peanut monkey
    2001 Tundra 4x4 Limited trd
    I have a rusty a$$ rear bumper on my truck and I need a whole new assembly. Where it attaches to the frame it's all rusted to hell. Thankfully only the bumper is rusty and not the frame. Anyways, where should I buy a kit from? Give me some suggestions. I'm going for an OEM look not some crazy high clearance bumper.. thanks!
  2. Sep 30, 2020 at 4:37 PM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    I think there is a complete bumper in Az if you ever road trip.
    robabeatle likes this.
  3. Sep 30, 2020 at 4:37 PM
    Kongap
    Kongap New Member
    2004 SR5 DC
    I started to look around locally for a fabricator to make a simple tubular bumper. Besides that, iirc it was <$200 or even less than that to replace the chrome piece.
    I almost went to the junk yard to get one but the pics of the ones there were pretty rusty but not as holey
  4. Sep 30, 2020 at 4:39 PM
    rock climber
    rock climber New Member
    2001 Sequoia 4X4, 2001 AC 4X4
    Junk yard, or ebay
    N84434 likes this.
  5. Sep 30, 2020 at 5:16 PM
    Cummins3500
    Cummins3500 Never finishes.....
    Logan
    TheBlackPearl likes this.
  6. Sep 30, 2020 at 5:30 PM
    RR60
    RR60 New Member
    2003 SR5 Tundra long bed
    https://www.amazon.com/gp/product/B071GNWHKN/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
    This is really a good deal a friend of mine got recently.
    Also came with the steel member that the bumper attached to. A separate part that cost me about 400.00 from the dealer 2 years ago. A separate part I needed when I wanted to get rid of a rusted oem trailer hitch and go with a aftermarket.
  7. Oct 1, 2020 at 5:15 AM
    Pucks18
    So it comes with the parts that bolt onto the actual frame? I need the whole complete assembly. Maybe u haul would sell that?
  8. Oct 1, 2020 at 6:16 AM
    N84434
    N84434 In the Frozen Tundra
    Milwaukee WI.
    2001 Limited TRD
    UHaul would not have the bumper reinforcement for a 1st Gen Tundra. They WOULD have a trailer hitch for it though....
    The Amazon bumper is the one to get, since it comes with the inner braces, bumper reinforcement bar, new mount brackets and the new step caps.
    bmf4069 and NewImprovedRon like this.
  9. Oct 1, 2020 at 6:25 AM
    RR60
    RR60 New Member
    Yes, The brackets that attach to the frame and then the support bar that attaches to the brackets. Then the actual bumber that goes onto that.
    Dont understand uhaul comment. Dont think they sell bumbers?
    Did yours come with a oem trailer hitch?
    If so you you dont need these extra parts that come with it. All that is built into and combined with the hitch.
    If not then you would use the extra parts.
    Or if your oem trailer hitch needs replacing like mine did. Then you would use the parts and get a seperate triler hitch. This is the one I got.
    https://www.amazon.com/gp/product/B000E267RO/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
    So this bumber comes with the Reinforcement sub assy- Toyota #52043-0C030 which is 273.00 and 2 of the frame brackets toyota #52016-0C010 for 76.00 each. If you did order from toyota over 400.00 with shipping. Then still need the bumper.
    If you try to get the oem trailer hitch. I think that was 1200.00 plus.
    G_unit3000 likes this.
  10. Oct 1, 2020 at 7:12 AM
    Pucks18
    Dude, thanks a bunch! So is it pretty easy to do? I saw a youtube video where this kid replaced his tundras bumper but only the cosmetic part of the bumper ( the outer shell) so no the part that goes to the frame. That looked slightly challenging. Does this job involve pretty much just taking like 6 bolts out and simply unbolting the rear bumper? Thanks again
  11. Oct 1, 2020 at 7:18 AM
    Kongap
    Kongap New Member
    2004 SR5 DC
    Grab some penetrating fluid and maybe some heat.
  12. Oct 1, 2020 at 8:09 AM
    N84434
    Milwaukee WI.
    2001 Limited TRD
    Removing the complete assembly is very easy, as long as you can get the 10 bolts out of the Left and right bumper arm brackets, where they mount to each frame rail. IIR, those are either 14mm or 17mm bolts that go into the frame. Lots of heat and PB Blaster will help break them loose. The rest Of the hardware on the old bumper will all be replaced, so no need to try and save those..
  13. Oct 1, 2020 at 8:12 AM
    N84434
    Milwaukee WI.
    2001 Limited TRD
    Oh, and make sure to gently remove the wiring harness from underneath, as it's attached to that frame reinforcement bar.
  14. Oct 1, 2020 at 8:19 AM
    Pucks18
    Just bought the the bumper assembly off Amazon
  15. Oct 1, 2020 at 9:35 AM
    peanut
    peanut making uneconomical choices about my truck
    2001 Tundra 4x4 V8 Access cab 222k miles
    car-part.com is also a good place to look some times for OEM stuff
  16. Oct 1, 2020 at 10:28 AM
    Pucks18
    I only need like 15 percent of that graph. Im doing the whole assembly. Thanks tho!
  17. Oct 1, 2020 at 11:07 AM
    Kongap
    Kongap New Member
    2004 SR5 DC
    No problem. Figured it’d help someone find where the bolts should be
    N84434 likes this.
  18. Oct 1, 2020 at 1:31 PM
    2006Tundra
    2006Tundra Financially Irresponsible
    Lou
    Long Beach, CA
    2006 Toyota Tundra Double Cab SR5, 4.7L V8
  19. Oct 9, 2020 at 9:15 AM
    N84434
    Milwaukee WI.
    2001 Limited TRD
    @Pucks18 Updates????
    Pucks18[QUOTED][OP] likes this.
  20. Oct 10, 2020 at 6:32 AM
    Pucks18
    N84434[QUOTED] and bmf4069 like this.
  21. Oct 10, 2020 at 6:58 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Did you rub it down with grease, or a pb blaster coating before you put the chrome "trim" on? Spray inside tubes?
    To prevent this one from rusting away too...
    Looking through your bumper hole where ball goes looks like bare metal.
  22. Oct 10, 2020 at 2:07 PM
    N84434
    Milwaukee WI.
    2001 Limited TRD
    Nice work. Really makes the truck pop... :thumbsup:
  23. Oct 10, 2020 at 5:34 PM
    bassman417
    bassman417 "Tundra Time". My favorite time of day...
    Paul
    Las Vegas
    2004 DC 2wd Imperial Jade
    Definitely Looks nice.
    A before picture for reference would make it look even better I bet.
    Nice Color also, I'm Partial to Imperial Jade....
    Pucks18[OP] and N84434 like this.
  24. Oct 10, 2020 at 7:30 PM
    Pucks18
    I put grease on the inside of the bumper. I bought it as the whole bumper assembly that attaches to the frame
  25. Oct 10, 2020 at 7:31 PM
    Pucks18
    O
    O man i wish I had a pic. It was the oem 2001 color matched imperial jade rear bumper, and it was rust severely.
