Where is the fuel filter on 2005 tundra 4x4?
Discussion in '1st Gen Tundras (2000-2006)' started by selba5, Sep 6, 2017.
  1. Sep 6, 2017 at 12:30 PM
    selba5
    selba5 [OP] New Member
    2005 tundra 4x4 TRD
    Just bought a 2005 Tundra access cab, TRD, 4X4. Decided to change the fuel filter and it is not located on the left frame rail near the transfer case as everything I've found indicates that it should be. Anyone know of any alternate locations?
  2. Sep 7, 2017 at 4:31 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    The frame rail woulda been my first guess....dunno.
  3. Sep 7, 2017 at 6:10 AM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    04 was the last year for a frame mounted filter.
  4. Sep 7, 2017 at 8:21 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Sooo, do you know if they've eliminated it or just use the same set up as the 2nd Gens?
  5. Sep 7, 2017 at 9:06 AM
    Festerw
    Festerw New Member
    04 Tundra DC
    They use a strainer/filter on the pump itself, I would assume similar to the 2nd Gen but I can't say for certain.
    Wynnded likes this.
  6. Sep 13, 2017 at 12:13 PM
    Retired Tom
    Retired Tom New Member
    2005 Tundra, 4.7 sr5,
    2005 is when they went to a plastic gas tank which eliminated rust, therefore, no fuel filter.
  7. Sep 14, 2017 at 8:48 AM
    selba5
    2005 tundra 4x4 TRD
    Thanks Tom - guess I'll quit looking for it then.
  8. Sep 14, 2017 at 10:06 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    I wonder how they thought to safeguard against dodgy fuel sources where an owner may not be able to verify the cleanliness of the fuel.
    TRDGen likes this.
  9. Sep 14, 2017 at 11:11 AM
    selba5
    2005 tundra 4x4 TRD
    Kind of what I was thinking Wynnded..... any number of contaminants can be introduced to the fuel tank in any number of ways. Mine will have a fuel filter soon.
  10. Sep 14, 2017 at 12:41 PM
    Festerw
    Festerw New Member
    04 Tundra DC
    I'd be more concerned about water than anything. I pulled the original pump from my Dakota when it was 18 years old and the plastic tank had nearly no crud in it, as in a quarter paper towel wiped it all up with room to spare.
    Wynnded likes this.
  11. Aug 22, 2023 at 10:35 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    If you indeed have a fuel filter in that location, it’s not an OEM part from factory. Any chance there is legible markings or a part number stamped on your filter?
    Tex-Tun[QUOTED] likes this.
  12. Aug 23, 2023 at 7:28 AM
    Tex-Tun
    Tex-Tun New Member
    Gary
    North Central Texas
    2012 Toyota Tundra Texas Edition
    Brush guard, 3M protective headlight lenses. Weather Tech floor mats. LED lamps/Fog lamps.
    This fuel filter looks factory. That’s interesting. I have seen some filters on line that match the one I have but I want a WIX or Bosch (high quality). I’ll take some photos and post. Thank you for the feedback Landphil!
  13. Aug 23, 2023 at 7:44 AM
    IT IS NEVER THE FUEL FILTER. Don't bother changing it. We've been over this about 5,000 times here in the 1st Gen Tundra forum, I'm re-iterating: Not a single member on this forum who has changed their fuel filter has EVER seen it fix, help, resolve any issue. It's not a regular or even irregular maintenance item. This is not a Ford, Dodge, or GM truck, it's a Toyota.
    EDIT: Oh crap, I just realized you have a 2012. You're posting this reply in the 2000-2006 truck forum. Sorry, I got confused.
    Stick with OEM filters. Toyota has designed their filters to work better than anything in the 3rd party. This is coming from a guy who is a Wix fanatic. Plenty of test data out there on OEM Toyota oil and air filters out there!
    This sticky thread will help you find the OEM part number: https://www.tundras.com/threads/howto-use-the-toyota-parts-system-to-find-order-parts.113808/
  14. Aug 23, 2023 at 7:54 PM
    Tex-Tun
    Tex-Tun New Member
    Gary
    North Central Texas
    After further investigation, my friend from Canada was exactly right. There isn’t a fuel filter on my Tundra. Must have had a Ford flashback ‍♂️. Anyway, that’s why I couldn’t find the fuel filter on line. . Case solved. Human error.
    landphil and shifty` like this.
  15. Aug 26, 2023 at 8:20 PM
    Tex-Tun
    Tex-Tun New Member
    Gary
    North Central Texas
    Thank you Landphil
  16. Aug 26, 2023 at 8:22 PM
    Tex-Tun
    Tex-Tun New Member
    Gary
    North Central Texas
    I’m getting 13mpg in the city. That’s not bad for a heavy half ton I reckon.
  17. Aug 26, 2023 at 8:22 PM
    Tex-Tun
    Tex-Tun New Member
    Gary
    North Central Texas
    Fuel in Texas is $3.20 a gallon. 87 octane
