where does everyone order their frontend suspension parts from?
Discussion in '1st Gen Tundras (2000-2006)' started by trunda_74, Nov 15, 2024.
  1. Nov 15, 2024 at 5:50 AM
    trunda_74
    trunda_74 [OP] New Member
    2013 White Tundra SR5 DC 4x4
    I have a 2002 Sequoia limited 4x4 with 175k and I am needing to do the following.
    Outer Tie Rod and Inner Tie Rod for both front passenger and driver side. Driver or Passenger Side Sway Bar Link and upper and lower ball joints for both driver and passenger side.
    I was wondering if 1AAuto or Partsgeek is a good place to order those parts? Also am I missing anything that you can think of?
    Thanks
  2. Nov 15, 2024 at 5:53 AM
    I order most of the parts from one of the online Toyota parts dealership sites, such as Serra or Ourisman. OEM only for ball joints, sway bar end links and tie rods.
    ToyotaDude likes this.
  3. Nov 15, 2024 at 5:54 AM
    trunda_74
    Thanks KNABORES.
  4. Nov 15, 2024 at 5:56 AM
    If you time your order, they will run 20-25% off sales and free shipping at times. Can save hundreds that way. Just be sure you do not put aftermarket ball joints on your truck. Known fail point, and causes significant damage when it fails.
  5. Nov 15, 2024 at 5:57 AM
    trunda_74
    Thanks you for that information.
  6. Nov 15, 2024 at 5:59 AM
    My apologies if you are talking about parts for your 2013, this question is posted in the first gen section (2000-2006). If this is in reference to your 2013 on your profile, then the ball joint design is different, but OEM is still the way to go.
  7. Nov 15, 2024 at 6:04 AM
    trunda_74
    This question is for my wife's 2002 Sequoia and that is the reason I posted in the 1st Gen section of the forum. I posted in the Sequoia 1st Gen section and they recommend posting here as there is more traffic in this section.
    KNABORES likes this.
  8. Nov 15, 2024 at 6:21 AM
    gagecalman
    gagecalman New Member
    Maryland
    2006 Tundra DC SR5 4WD 4.7 V8
    HBTundra likes this.
  9. Nov 15, 2024 at 6:23 AM
    trunda_74
    Thanks for that information gegecalman
  10. Nov 15, 2024 at 6:31 AM
    Her Seqouia does have the ill-fated ball joint design. OEM or die. At least that’s what the stickers say….
  11. Nov 15, 2024 at 6:40 AM
    trunda_74
  12. Nov 15, 2024 at 6:45 AM
    Non-OEM will degrade quickly from my experience.
    trunda_74[OP] likes this.
  13. Nov 15, 2024 at 6:50 AM
    I used Moog outer tie rod ends on my truck and they lasted 1 month.
  14. Nov 15, 2024 at 6:52 AM
    trunda_74
    That is not good. I am having a hard time finding the in Outer Tie Rod and Inner Tie Rod and Side Sway Bar Link
  15. Nov 15, 2024 at 6:59 AM
    trunda_74
    I did just find the Inner Tie Rod but still looking for the outer tie Rod and side sway bar link
  16. Nov 15, 2024 at 7:14 AM
    shifty` I'm having daydreams about night things
    It sucks because the EPC-DATA website I typically use for parts lookups has been down the last couple days. That said, www.amayama.com still has exploded diagrams, it's just a little more cumbersome for newbies to use. If you can PM your VIN@ on the '02 Sequoia I can grab part numbers for you.
    Two things I would advise you to do.
    1. Read this thread, which will advise you on parts you NEVER want to purchase aftermarket brands, and should tell you what brands made the OEM parts for Toyota (Denso, Aisin, Advics, Fujitsu, Hitachi, Spicer, Koyo, etc.)
    2. Before you commit to buying aftermarket, especially with suspension, check this thread to see if anyone in 1st gen has had problems with that manufacturer's part.
  17. Nov 15, 2024 at 7:16 AM
    trunda_74
    Thank you for that information and I will read both of those threads.
