Wheels won’t fit! What is the best choice?
Discussion in '1st Gen Tundras (2000-2006)' started by Juniormonroy513, Oct 16, 2023.
  1. Oct 16, 2023 at 3:20 AM
    Juniormonroy513
    Juniormonroy513 [OP] New Member
    Junior
    2003 3.4l v6 tundra
    I so I have a 2003 Toyota tundra with a 3.4l v6. I bought some tires from offer up they are from a 2023 Toyota tundra right now I have the stock steel wheels and I took it to a tire shop to get the new wheels mounted and they wouldn’t fit. Are spacers my best bet?
  2. Oct 16, 2023 at 3:41 AM
    artsr2002
    artsr2002 2005 Tundra DC SR5
    'Yonder
    Why wouldn't they fit?
  3. Oct 16, 2023 at 3:51 AM
    Juniormonroy513
    Junior
    2003 3.4l v6 tundra
    The hit on the caliper when they mounted them
  4. Oct 16, 2023 at 5:53 AM
    shifty` Animals and insects don't do drugs
    Resell on CL; buy wheels that are known to fit. As it is, the 2023 wheels won't work without custom spacers because the hub bore is totally different (Edit: Smaller, which wouldn't allow the wheel to fit over, much less center properly with our 106mm hubs). The shop should've told you that. If not, a quick well-formatted search on this forum would have. I'm positive that info is in the info-dumpo sticky, under the wheels section, with a potential solution that is $$$: https://www.tundras.com/threads/so-you-wanna-buy-just-bought-a-1st-gen-tundra-eh.115928/
    You're looking at about $350-400 for spacers that will adapt for the hub bore and get the wheels out. I don't see why any rational person would make the investment, but you do you.
    NickB_01TRD, GODZILLA and Richid like this.
  5. Oct 16, 2023 at 7:28 AM
    Richid
    Richid New Member
    Second the 'buy the right wheels the first time'. Check for compatible rims first - Tons of 4Runner wheels out there. Always ask what they came off of, not what the seller thinks they fit. Summary:
    Center Bore: 106.1 mm
    PCD: 6x139.7 (6x5.5)
    Thread Size: M12 x 1.5
    7.5Jx17 ET15
    Tundra 2000-2006
    FJ Cruiser 2007-2022
    4Runner 2010-2022
    shifty` likes this.
