Wheels rubbing
Discussion in 'Suspension' started by Marzjc, Jul 22, 2021.
  1. Jul 22, 2021 at 12:29 AM
    Marzjc
    Marzjc [OP] New Member
    2013 toyota tundra
    Well I changed the whole front suspension on my 2013 tundra but my tie rods are still rubbing on the inside of my wheels when I make sharp turns anyone else have this problem before?? Also these are the factory wheels that are rubbing they didn't start rubbing until after I lifted the truck .
  2. Jul 22, 2021 at 12:37 AM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    Change rims or use spacer
  3. Jul 22, 2021 at 7:09 AM
    Marzjc
    2013 toyota tundra
    But why would it rub if those where the original wheels it came with I did the road force balance rotated them and its still the same and it's only on one side not both wheels in the front . But thanks for the input appreciate it .
  4. Jul 22, 2021 at 7:16 AM
    Marzjc
    2013 toyota tundra
    What size spacers would you recommend??
  5. Jul 22, 2021 at 8:09 AM
    Kanobi13
    Kanobi13 New Member
    Alignment?
    equin likes this.
  6. Jul 22, 2021 at 8:11 AM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    Before all the control arms and tie rod is level with the ground while driving, after u lift the truck, everything is in an angle, so there’s less space. Sometimes an alignment could help if it’s just a little rub, or you could change the offset to give you more room.
    It’s depends how much it’s rubbing
  7. Jul 22, 2021 at 8:44 AM
    equin
    equin Texarican Tundra
    Ed
    DFW, TX
    I was wondering the same thing. An alignment should be done after lifting the front. Maybe that could be the issue?
    BravoDeltaRomeo likes this.
  8. Jul 22, 2021 at 9:54 AM
    Marzjc
    2013 toyota tundra
    I did an alignment after I lifted it and one after I did the front suspension and still have the same issue . It's making a scratch in the wheel but only when I make sharp turns or pulling out of my driveway I saw some spacers online between 1" to 2" inches what do you'll think I should go with??
  9. Jul 22, 2021 at 10:29 AM
    Rodtheviking
    Rodtheviking New Member
    Vancouver, WA
    Sequoia
    Bora, Spidertrax or Trail Gear in 1 1/4 inch flavor.
  10. Jul 22, 2021 at 10:29 AM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    Don’t know need a full lock pic to see where’s touching
  11. Jul 22, 2021 at 11:39 AM
    Rodtheviking
    Vancouver, WA
    Sequoia
    Can you post a picture of the tie rod end? I'm curious..
  12. Jul 22, 2021 at 8:21 PM
    equin
    Ed
    DFW, TX
    When you say you replaced the whole suspension, did you also replace the tie rod ends?
  13. Jul 22, 2021 at 8:34 PM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
  14. Jul 23, 2021 at 10:49 AM
    Rodtheviking
    Vancouver, WA
    Sequoia
  15. Jul 23, 2021 at 1:41 PM
    Marzjc
    2013 toyota tundra
  16. Jul 23, 2021 at 1:45 PM
    Marzjc
    2013 toyota tundra
  17. Jul 23, 2021 at 1:46 PM
    Marzjc
    2013 toyota tundra
  18. Jul 23, 2021 at 1:46 PM
    Marzjc
    2013 toyota tundra
  19. Jul 23, 2021 at 1:47 PM
    Marzjc
    2013 toyota tundra
  20. Jul 23, 2021 at 1:48 PM
    Marzjc
    2013 toyota tundra
    That's what it looks like now nothing g changed I did change both tie rods on both sides I did not flip them like suggested before
  21. Jul 23, 2021 at 1:49 PM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    1.5” spacer min
  22. Jul 23, 2021 at 1:53 PM
    Cruzer
    Cruzer Wheeling Full Size
    Cruz
    Sunnyvale, CA
    Holy shizzle my nizzle! Quick n dirty fix would be to grind that outer tie rod or get a spacer. Or you may want to get the Coachbuilder steering (tie rod) kits, which are straight (doesn't have the curve like the stock ones do).
  23. Jul 23, 2021 at 1:57 PM
    Ryuu
    Ryuu Hwat!?
    Oz
    SouthEast, TX
    2017 TRD PRO Barcelona Red
    a few
    if its a RC 4 to 6 inch, try switching the tie rods around, driver to passenger and passenger to driver. install instructions show the tie rods installed back on with the curve near the ball joints facing the knuckle instead of the wheel.
    if that doesn't help do what Cruzer suggests.
    saturn, Hi06silver and BiggHertz like this.
  24. Jul 23, 2021 at 2:04 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    They look curved to avoid the wheel, just R and L appear on the opposite sides
  25. Jul 23, 2021 at 2:32 PM
    BiggHertz
    BiggHertz DZTLIMO
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
    Any reason why your tie rod is coming in from the top vs the bottom?
  26. Jul 23, 2021 at 2:33 PM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    Shit bruh, I think those guy put that shit wrong, you need to take it back swap them tie rod and redo alignment
    Mr_Kane and BiggHertz like this.
  27. Jul 23, 2021 at 2:34 PM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    He lifted his truc
    Hbjeff and BiggHertz[QUOTED] like this.
  28. Jul 23, 2021 at 2:35 PM
    BiggHertz
    BiggHertz DZTLIMO
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
    ah, missing specifics…lol
    He is asking what color the sky is…but not specifying when and where?!?
    TheBeast likes this.
  29. Jul 23, 2021 at 2:38 PM
    BiggHertz
    BiggHertz DZTLIMO
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
    This would solve your issue if required. But without the details on your setup…it is a crapshoot…
    -JS
  30. Jul 23, 2021 at 2:44 PM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    Bruh, I check my 19 and the tie rod end is in different directions 96E53B97-D2A6-46AA-92A4-442E719EC23F.jpg
