Wheels and tire situation
Discussion in 'Wheels & Tires' started by ab1653, Aug 2, 2018.
  1. Aug 2, 2018 at 9:22 AM
    ab1653
    ab1653 [OP] New Member
    TX
    2014 Tundra.
    Ok so I had a tire blow out due to this extreme heat in Texas. The tires were a little old so I decided to replace them. Ultimately I decided the difference for some new wheels and similar tires wasn’t much of a difference so I pulled the trigger and bought new wheels and tires. I am going to go with 285/65/r18 and the vision nemesis wheels. The current situation is everything on my truck is stock but I have the Bilstein 5100s sitting in my garage waiting to be installed. Can I go with the 295/70r18 until I install the Bilsteins 5100s. Maybe like a week or two until I install? Or will they just not fit? I have a 2014 4x4 crewman Sr5. Getting rid of the TSS wheels
  2. Aug 2, 2018 at 9:28 AM
    parker44
    parker44 New Member
    Keith
    Columbia, South Carolina
    2008 Tundra - Desert Sand Mica
    I think 295's have been fit on a stock truck, but you are probably going to have significant rubbing with it. I would probably stick with the 285's.
  3. Aug 2, 2018 at 10:15 AM
    ChrisTRDPro
    ChrisTRDPro New Member
    MT
    2017 Tundra TRD Pro CM
    Depends on the offset of your new wheels
  4. Aug 2, 2018 at 10:16 AM
    ab1653
    TX
    2014 Tundra.
    The offset is +18
  5. Aug 2, 2018 at 10:19 AM
    ChrisTRDPro
    MT
    should be fine with the 295's then I believe
  6. Aug 2, 2018 at 10:29 AM
    joonbug
    joonbug bacon bastrd
    Joon
    NorCal - Dublin
    2015 DC 5.7 TRD off-road
    You're gonna hate life for a week or two. It's going to rub like crazy. But it'll be worth it. :D You'll definitely have to remove the mudflaps and the front liner until the lift goes on and may rub the cab mount a little. Then you'll be able to put the liner back on with some trimming. But the mudflaps will have to stay off.
    GNTundra likes this.
  7. Aug 2, 2018 at 10:32 AM
    ab1653
    TX
    2014 Tundra.
    I’m wondering if it’s even worth going with the 295s. I guess I could wait it out until the tires wareout and just do it all then... decisions decisions. It’s sucks that all this happened as I am moving so I have parts in one city and parts in another. Fml
  8. Aug 2, 2018 at 10:34 AM
    joonbug
    Joon
    NorCal - Dublin
    Definitely worth it IMO. If you can wait til you get your lift on, I definitely would.
  9. Aug 2, 2018 at 10:34 AM
    ChrisTRDPro
    MT
    Plenty of people run 295s with just removing the mudflaps and spacers or a less offset wheel than stock like you have. Just have a look around here and you'll find them ;)
  10. Aug 2, 2018 at 10:37 AM
    joonbug
    Joon
    NorCal - Dublin
    No one runs 295's on stock (non Pro) suspension with a +18 offset. It's doable with +50 or +60.
    zcarpenter92 and monaco730 like this.
  11. Aug 2, 2018 at 10:41 AM
    monaco730
    monaco730 New Member
    16 Inferno Tundra
    TRD Exhaust, TRD grill, TRD shift knob, weathertech floor/bed liners, ARE topper, FrontRunnerOutfitters cargo rack, Relentless cargo bars, color matched front bumper/side mirrors, 3/1 readylift, fuel wheels, nitto RGs, K&N intake,
    I have 295/70/18s with +20 offset but with a 3/1 lift. I had to remove both front mud flaps and cut into the plastic cover on the corner bumper. I don't see how anyone could fit 295s on stock suspension but I'm no expert.
    tinman10101 and joonbug like this.
  12. Aug 2, 2018 at 10:42 AM
    ChrisTRDPro
    MT
    How does a lower offset hinder you? You're moving the wheel & tire away from the UCA/suspension?
  13. Aug 2, 2018 at 10:43 AM
    joonbug
    Joon
    NorCal - Dublin
    The lower offset gets you away from the UCA, but that's what causes you to hit the cab mount and the front liner.
    tinman10101, equin and ChrisTRDPro like this.
  14. Aug 2, 2018 at 10:44 AM
    ChrisTRDPro
    MT
    Makes sense, thanks!
    joonbug likes this.
  15. Aug 2, 2018 at 10:52 AM
    parker44
    parker44 New Member
    Keith
    OP, your truck will still look good with the 5100's and the 285's.
  16. Aug 2, 2018 at 10:59 AM
    equin
    equin Texarican Tundra
    Ed
    DFW, TX
    TRD Rear Anti-sway bar, TRD Pro skid plate, Bedrug bed mat, Icon Rebounds 285/75/17 Cooper Discoverer XLTs, Bilstein 6112s/5160s, Diamondback SE
    Don’t know if the 295s will fit stock without having to address the inner fenderwell area a lot (mud flaps, fender liner, etc.), but I’m wondering if 285/70/18 tires might work as a compromise. Their diameter is in between that of the 295s and the 285/65/18s you’re also considering. My guess is that you’ll still have to address the fender well area. Also, not much selection in that size and prices are higher than the 295s. But thought I’d throw this out there as another option to consider.
    ab1653 [OP] likes this.
  17. Aug 2, 2018 at 11:02 AM
    ab1653
    TX
    2014 Tundra.
    Thank you all for your input. Since I have to make the executive decision now... I am going to go with the 285/65. I figured I’ll will give me roughly 1.5 -2 years before I have to buy new shoes for my truck. Everyone in here sure helped before I did something that might not work out. I’ll post pics as soon as they come in
    equin likes this.
  18. Aug 5, 2018 at 3:17 PM
    ab1653
    TX
    2014 Tundra.
    Well... here it is. A little dirty, but we’ve been on the road quite a bit this week.
  19. Aug 22, 2018 at 12:54 PM
    dawn2014tundra4x4crewmax
    dawn2014tundra4x4crewmax Tundychick
    Dawn
    South Carolina
    2014 Tundra Crewmax XP 4X4 with mammoth package
    This tire shit is getting on my nerves, lol. These numbers r greek to me. We have a 14 tundra with mammoth which means 20" wheels and it came wth bfg AT 285/55/r20. We put a leveling kit on and now its time for tires. I want the k02's and I want a taller tire and just a tad wider tire, can i do 295/65r20? I dont know what offset means either so i need help.....
  20. Aug 22, 2018 at 1:26 PM
    Brian0414
    Brian0414 New Member
    Tucson, AZ
    2014 Black Tundra SR5 4x4
    - Winjet Black/Smoke Fiber Optic LED Tail Lights - Spyder Black/Smoke LED 3rd Brake Light - Lund 5" Oval Side Bars - K&N Air Filter - Volant Throttle Body Spacer - MagnaFlow Dumped Exhaust 3"-1" Supreme Suspensions Leveling Kit Bilstein 5160
    This is the setup Im going with! Looks great!! Ill be doing the Nemesis with STT Pros 295/70/18 5100's Top setting.
  21. Aug 22, 2018 at 2:02 PM
    Dawn
    South Carolina
    What does the 5100 mean? And top setting of what?
  22. Aug 22, 2018 at 2:39 PM
    Brian0414
    Tucson, AZ
    equin likes this.
  23. Aug 22, 2018 at 2:40 PM
    equin
    Ed
    DFW, TX
    Wheel offset: “5100” refers to the Bilstein shock model number. Bilstein offers 5100 series shocks for our trucks that come with the ability to set front ride height. “Top setting” means the ride height is set at the top setting along the shock body that allows for maximum lift. I don’t know how much lift is maximum for 5100s, but I’m sure someone on here will chime in on that.
  24. Aug 22, 2018 at 2:41 PM
    equin
    Ed
    DFW, TX
    Brian0414 beat me to it.
  25. Aug 22, 2018 at 2:42 PM
    Brian0414
    Tucson, AZ
    2.3" I think
    equin likes this.
  26. Aug 22, 2018 at 8:59 PM
    Dawn
    South Carolina
    Soo can i do 295/65R20 ?
  27. Aug 22, 2018 at 10:04 PM
    ab1653
    TX
    2014 Tundra.
    Attached you will find the size difference. I am not sure if they will fit with only the top setting another website you might want to check out is 7746DE1D-927C-4D76-88C5-D9642DCDF855.jpg
  28. Aug 23, 2018 at 9:05 AM
    Dawn
    South Carolina
    Surely there r people that has the same setup as mine and they either tried the 295/65/20 and it didnt work....or it did. Its like finding a needle in a haystack though.
  29. Aug 23, 2018 at 12:00 PM
    parker44
    parker44 New Member
    Keith
    Have you read through the wheel and tires thread? There are lots of pictures and information out there. I think that size might cause rubbing. Take a look at the 295/60/20, little bit shorter. The size you mentioned is jumping 2.5". How much of a lift did you put on with the leveling kit? @dawn2014tundra4x4crewmax
  30. Aug 23, 2018 at 6:33 PM
    Dawn
    South Carolina
    A 3inch front 2 on rear
