Wheel Swap
Discussion in 'Wheels & Tires' started by k9shag, Feb 9, 2017.
  1. Feb 9, 2017 at 4:46 AM
    k9shag
    k9shag [OP] New Member
    Tony
    Midland, NC
    2017 Tundra DC SR5 MGM
    I am swapping my 17 Tundra steel wheels for TRD wheels. using same tires and sensors. Do the sensors need reprogramming?
  2. Feb 9, 2017 at 4:59 AM
    Drew05
    Drew05 New Member
    You plan on swappin your steel wheel sensors? If so they will only fit installed backwards
  3. Feb 9, 2017 at 5:03 AM
    k9shag
    Tony
    Midland, NC
    Yes , so is this advisable or should I just get new sensors?
  4. Feb 9, 2017 at 11:17 AM
    Drew05
    Drew05 New Member
    Buy new sensors. I did the same wheel swap and bought some new sensors on ebay really affordable and had to have them programed to my truck at the stealership for $100.
  5. Feb 9, 2017 at 12:43 PM
    k9shag
    Tony
    Midland, NC
    Yep that looks like the plan. I pick the wheels up tomorrow. Thanks for the info.
  6. Feb 10, 2017 at 3:56 PM
    k9shag
    Tony
    Midland, NC
    Well I had the rims swapped and was ready to put in new sensors when the manager of the Discount Tire I was at (and a 2015 Tundra owner) told me that he has used the steel wheel sensors several times without a hiccup. So I let him save me some $ and gave it a try.
    Drew05 and 040Tundra like this.
  7. Feb 10, 2017 at 7:56 PM
    CM-LENNY
    CM-LENNY No Complaints
    San Diego, CA
    2015 4x4 CrewMax SR5
    PRO shocks, 37's Nitto G2's 4:88 diffs, few other mods
    You had a decent installer. What has and will happen many times is the steel wheel sensor will get broken during a dismount. Only plus.........Discount had to install new (correct) sensors. Just maybe let the future installers know if and when you have a dismount/mount. What a change from steel to TRD...:thumbsup:
  8. Feb 11, 2017 at 2:13 PM
    k9shag
    Tony
    Midland, NC
    So it bugged me all day that the 40 deg sensors where working, but knowing that it wasn't by design and would probably fail at the worst time. I went back and had 20 deg sensors installed
    CM-LENNY likes this.
