Wheel spacers? Which one does tundras recommend?
Discussion in 'Wheels & Tires' started by Erick, Dec 2, 2018.
  1. Dec 2, 2018 at 10:51 PM
    Erick
    Erick [OP] New Member
    Erick
    Thornton Colorado.
    Bronze 2016 SR5 TRD. CM cab.
    HID lights, Duratracs, Bilstein 5100's, 2" Spacer, Sumo springs.
    I'm looking to add some wheel spacers. Pros and cons? I do haul and load heavy things regularly.
  2. Dec 2, 2018 at 11:14 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    I ran Spidertrax for a while. Either those or Bora. Almost everyone here will say the same I believe.
    15whtrd, MS22, porkitt and 2 others like this.
  3. Dec 2, 2018 at 11:18 PM
    Erick
    Erick
    Thornton Colorado.
    What size did you go with? Thanks.
  4. Dec 2, 2018 at 11:27 PM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    As far as I know, Spidertrax only makes 1.25". Bora makes different thicknesses. Both are hubcentric which is important. When dealing with something as critical as keeping the wheels on the truck, it's a good idea to go with top quality parts.
    1.25" with OEM +60 offset wheels nets roughly a +28 offset which is in the sweet spot for our trucks.
    plumber802 likes this.
  5. Dec 3, 2018 at 12:09 AM
    Erick
    Erick
    Thornton Colorado.
  6. Dec 3, 2018 at 12:10 AM
    Erick
    Erick
    Thornton Colorado.
    Also, Do I need an alignment after spacers are installed?
  7. Dec 3, 2018 at 3:24 AM
    Berdine
    Berdine Voodoo Sport
    Binghamton, NY
    2020 VooDoo Blue Trd Sport
    Spacers have nothing to do with your alignment, just make sure they're hub-centric and work them into your maint schedule, like an oil change, check them out make sure everything still tight and so on, ran them for of 2 yrs on my tundra, no issues
    MS22 and sr5shark like this.
  8. Dec 3, 2018 at 3:27 AM
    Mr Swervlin
    Mr Swervlin "Yes....In Dee Face"
    O H I O
    2017 Silver Sky limited TRD Crewmax
    Line X bed liner Window tint AVS in channel vent visors Paint protection wrap Husky front & rear floor liner ESP Crewmax rear storage Console organizer and tray TRD shift knob TRD rear sway bar Thule exporter pro 500 Color matched door handles, side mirrors, and grill surround VLEDs interior/reverse/cargo Driver side grab handle 10" BAmuffler Trd pro headlights
    Bro.......do a lot of research on this before you buy. This forum is filled with a ton of info on wheel spacers. A good Installation is critical. I would stick with the recommend brand.
    sr5shark likes this.
  9. Dec 3, 2018 at 3:32 AM
    plumber802
    plumber802 New Member
    Andy
    Vermont
    2018 White Platinum CM
    I have a set of Spidertrax 1.25" spacers.These are QUALITY pieces.
  10. Dec 3, 2018 at 6:38 AM
    bigblue14
    bigblue14 New Member
    Craig
    2022 1794 Advanced Package
    TRD lift and AFE airbag arms, 285/65 Cooper AT3s
    Be warned that a spacer will make the "arm" of a turning tire bigger. It may cause rubbing in different spots.
    porkitt likes this.
  11. Dec 3, 2018 at 7:23 AM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
  12. Dec 3, 2018 at 7:45 AM
    Voyagermike
    Voyagermike New Member
    California
  13. Dec 4, 2018 at 4:22 AM
    Fired
    Fired Flame Extinguishment Specialist - Ret.
    The LowCountry
    '18 Limited Dbl Cab TRDOR
    Swapped 5.7 for V6
    I went with the Bora 1" and 275/70 - 18 BFG K02's on stock wheels. Perfect fit & couldn't be happier with results. BTW if you go the .75 route - you'll have to cut stock wheel studs down to fit.
  14. Dec 4, 2018 at 5:16 AM
    rustynail11
    rustynail11 New Member
    Scott
    Mansfield,TX (DFW Area)
    2017 Grey Tundra TRD
    G2's are another to consider. I ran G2 spacers on several jeeps without any problems, they are also hub centric. As others said make sure you check them as part of your maintenance routine
    MS22 likes this.
  15. Mar 18, 2021 at 9:13 PM
    yikes84
    yikes84 New Member
    yiking
    im getting ready to install bds fox 2.5 coilover 3" lift/level kit. i'd like to put 305/65/18 on stock trd off road wheels. any one wanna gimme some insight on this move good/bad? spacer thickness?
  16. Mar 18, 2021 at 9:36 PM
    RoniusMaximus
    RoniusMaximus The One and Only
    J
    Tri-Cities, Washington
    2020 MGM Toyota Tundra TRD PRO
    Synthetic Blinker Fluid
    Ive had spidertrax with my Pro wheels installrd since August and have done quite a few long trips. Still early but so far so good. I got Spidertrax for peace of mind and also considered bora as recommended by fellow Tundra owners. Was about to purchase boras but then someone locally listed the 4x spidertrax for $120 and the rest was history.
  17. Mar 18, 2021 at 10:00 PM
    yikes84
    yikes84 New Member
    yiking
    What thickness? I’m doing fender flares so I wanna little wider stance. Considering 2” spacers.
  18. Mar 19, 2021 at 12:35 PM
    Badknees
    Badknees New Member
    South Carolina
    2016 White Tundra 1794 CM 4X4
    TRD Pro BBS Wheels, TRD LED Headlights, Rigid LED Fog lights, 040 TRD Grille, 040 Hood Bulge, Black Center Valence, Driver's Grab Handle, TRD Pro Fox Suspension, 1.00" BORA Wheel Spacers, 1.5" Rear Shackles, TRD Front and Rear Sway bars, 295/70 R18 Cooper Discoverer AT3 XLTs, Full Size Spare, TRD Dual Exhaust, Console cover, Console Organizer, Husky Liner X-act Contours, Tinted Front Windows, Stubby Antenna, Autoventshade Deflectors, Duplicolor Painted Calipers, 040 Painted Front End Caps, Undercover Armor Flex Bed Cover
    I have a 2016 1794 CM and had 1.25" spacers with 295/70 R18 OR wheels and had some rubbing issues - nothing major to fix, but they did rub. I bought some less expensive (but good enough I think) spacers off Amazon shown below. I didn't want to add fender flares but also didn't like all the crap thrown on the side of my truck, so went to 1" BORA spacers - no more dirty truck and the outside of the tire is almost even with the body side panel now. Also, I still have plenty of UCA clearance. I can't speak about 2" spacers, but seems the rubbing could be bad.
  19. Mar 19, 2021 at 7:59 PM
    Berdine
    Binghamton, NY
    This is 2" spacers with 305 70 18 stt pros on stock trd wheels20181223_104210.jpg
    wolky and TucsonTundra1794 like this.
