Wheel offset
Discussion in 'Wheels & Tires' started by Dustydirt19, Oct 20, 2016.
  1. Oct 20, 2016 at 1:55 PM
    Dustydirt19
    Dustydirt19 [OP] Hoghead
    Dustin
    Duluth, MN
    2015 Blue Ribbon Metallic 5.7L 4WD SR5 TRD DC
    ProComp 6" stage 2 lift 18x9 Fuel Vapor -12 offset 35x12.5 Nitto Ridge Grapplers BullyDog Tuner Gibson Metal Mulisha cat-back exhaust, S&B cold air intake, Color matched TRD PRO Grille, Compustar Remote Start N-Fab Hooped Nerf Bars, AMI Big stick antenna, Salex organizer and tray, Weathertech laser cut floor mats, Weathertech window deflectors Black out badge Black out front and rear bumper Black out flags 24/7 black out TRD Off-road decals Spray in Line-X Bedliner Scosche phone mount Soft rolling tonneau cover TRD pedals and footrest
    On 18x9 rims with 295 70 18 tires with a 3 in lift what would a good offset be? I'm going to be putting fender flares on my truck and don't want them to be sucked in to far and look dopey
  2. Oct 20, 2016 at 1:55 PM
    ToyotaTundraMike
    2015 Tundra
    +12 to +18 should do the trick
    zcarpenter92 likes this.
  3. Oct 20, 2016 at 2:01 PM
    Dustydirt19
    Dustin
    Duluth, MN
    Ok that's about where I was thinking. I don't want them sticking out too far but I'd rather have an outty that an inny haha
    NewImprovedRon likes this.
  4. Oct 20, 2016 at 8:38 PM
    BlueBottle
    BlueBottle not a PRO
    '16 Platinum 4x4
    See fine print
    I think 18 is good if no flares.. here is my truck with 18x9+12 with 305/65's
    EE66D69C-0940-43BE-A208-5D007B31DEAA_zps_61fe01ea2fa85e6d9a1f7944bd2c0e6d2580ef4e.jpg
  5. Oct 20, 2016 at 8:46 PM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
  6. Oct 21, 2016 at 1:32 AM
    chphilo
    chphilo Tundra addict
    Western PA
    Do not get 18 mm offset if you are planning not to get flares. The sides of your truck will thank you for it. Also in PA, if you have tires beyond fender, it's illegal. Check your state law.
    Each Tundra seems somewhat different from another. Here's mine with Bushwacker fender flares. My wheels are 18x9 18 mm offset. Tires are 295/70/18. Mine seems to be pushed out more than GNTundra's.
    Dustydirt19[OP] and GNTundra like this.
  7. Oct 21, 2016 at 4:42 AM
    louscrw
    louscrw all jacked up on Mt. Dew
    Lou
    Warner Robins, Ga
    2023 F150 Raptor
    He is my +18 on a 295 tire...contemplating flares
  8. Nov 1, 2016 at 6:11 AM
    BlueBottle
    '16 Platinum 4x4
    See fine print
    Put on my 1.5" extend a fenders
    54C22950-703F-400B-876B-21E404E58128_zps_70ec053d8c6cea73d948ba9b0e20dd915aad6479.jpg
  9. May 9, 2017 at 10:51 AM
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    Wheel experts, if our truck is 60mm offset stock and I think 9 inch wide rim? Correct if im wrong.. -13 offset would be a difference of 73mm, BUT if our new wheel is a 10 or 11 inch wide, does that also add to how much further the wheels will stick out past fenders,
  10. May 9, 2017 at 10:52 AM
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    Would a 22x11 -18 offset stick out further than a 22x10 -18 offset??
  11. May 9, 2017 at 10:58 AM
    Dustydirt19
    Dustin
    Duluth, MN
    Jsena likes this.
  12. May 9, 2017 at 11:00 AM
    ej63090
    ej63090 New Member
    Eric
    McHenry, Illinois
    2017 White Crewmax SR5
  13. May 9, 2017 at 11:02 AM
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    That's not helping thanx tho. I know what offset is. I'm assuming with the 1 inch wider wheel with same tire, same offset, it would stick out further???
  14. May 9, 2017 at 11:12 AM
    tomsinamerica
    tomsinamerica New Member
    Tom
    Wilmington, NC
    White 2016 Tundra DC ltd
    yes... by half of the difference of the width.
  15. May 9, 2017 at 11:12 AM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Yes, the wheel will stick out 1/2" out further. But the same tire size on either one will stick out the same. If you're going for visual sticking out, you have to go by tire width.
    Jsena[QUOTED] likes this.
  16. May 9, 2017 at 11:15 AM
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    Thanx guys
  17. May 9, 2017 at 11:35 AM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Jay, here's a little pic to help you understand. You see the 11" wheel stick our 1/2" more. Whatever the offset, it'll stick out 1/2" more than the 10". (1/2" to the outside and 1/2" to the inside) But when you put the same size tire on either wheel, they'll stick out exactly the same. The narrower wheel will just look a little deeper. So when you're trying to determine how far you want to stick out, it only depends on offset and tire width.
    MotoTundra, NewImprovedRon and Jsena like this.
  18. May 9, 2017 at 11:41 AM
    TTU19
    TTU19 Wreck 'Em
    Wes
    Tx
    2021 TRD Sport
    I also have the flares and first thought about the +18. But on a lot, they still seem a little too tucked in. So I thought about a +1. Even that didn't seem enough. So I've been thinking about the -12 now. I want the tires just slightly outside of the flares.
  19. May 9, 2017 at 12:13 PM
    Dustydirt19
    Dustin
    Duluth, MN
    Read the second link I sent you. After the chart it explains all of this
    Jsena likes this.
  20. May 9, 2017 at 1:02 PM
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    Thank joon.. love the picture... glad you took time to make that for me. Lol artistic
    joonbug[QUOTED] likes this.
  21. May 9, 2017 at 2:27 PM
    chphilo
    Western PA
    A good rule of thumb:smaller the offset, more rubbing problem you will get. Typically, with 0 offset, the maximum tire size is 33 inches. Anything larger, you will have to do some serious cutting.
  22. May 9, 2017 at 4:13 PM
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    Thanx bro
