Wheel Offset
Discussion in '3rd Gen Tundras (2022+)' started by Foxfloat50, Feb 13, 2024.
  1. Feb 13, 2024 at 5:23 PM
    Foxfloat50
    Foxfloat50 [OP] New Member
    2024 Tundra Limited
    Hi, can anyone tell me whether or can use a set of rims I took off my 2023 Tacoma limited (18”) and use them on my 2024 Tundra (18”). The difference in the two is that the Tacoma wheels are a +15 offset and the Tundra are +60.
    thanks for any advice
  2. Feb 13, 2024 at 5:50 PM
    bornxbackwards
    bornxbackwards New Member
    Bruno
    QC, Canada
    2024 Blueprint Tundra SR5 CrewCab
    Cooper Discoverer AT3 XLT, Bison Soft Tri-Fold Tonneau Cover, Debadged..
    Center bore and lugs size are different.
    GODZILLA likes this.
  3. Feb 13, 2024 at 5:53 PM
    Hoody
    Hoody Member
    Kommiefornia
    '23 Platinum 6.5 bed
    Supposedly the studs are thicker on Tundras but if they're aftermarket wheels they might still fit. Dry fit one front and rear to see.
  4. Feb 13, 2024 at 11:21 PM
    TundrX
    TundrX New Member
    Toan
    Sacramento, CA
    2024 Tundra Hybrid Platinum
    I took my aftermarket wheels from my Tacoma and put them on my Tundra to see how it would look. I ended up going a different route though. That said, yes it will fit. +15 will bring the tire outside the fenders possibly an inch or so, depending on your wheel/tire combo. You can get some inspiration on this thread https://www.tundras.com/threads/22-3rd-gen-wheel-offsets-fitment-thread.99924/
  5. Feb 13, 2024 at 11:49 PM
    The offset won't matter for fitment. You need to look at the lug pattern, lug size, and the hub size. Depending on the wheel you may need to make sure the load rating is appropriate as well.
  6. Feb 14, 2024 at 3:40 AM
    raylo
    raylo not so new member
    Frederick, MD
    The whole wheel offset and tire selection thing pisses me off mightily. I'd like to get a larger P metric road-oriented tire for my TRD OR 18" wheels but they are only 7.5" wide, so 285/60 p metrics don't fit (need min 8" wide rims). Otherwise, the selection of tires is limited to load range E, which I don't want. Then the aftermarket wheel guys... sheesh... all the 8-9" wide wheels I like come in zero or +20 offset, which with a 285 or 295 tire will be too poke-y for me. I don't understand why they don't make more of these wheels in +40 which is similar to the TRD Pros, which to my eye is perfect. Method has a couple with +35 and +40, but these are few and far between.
  7. Feb 14, 2024 at 3:43 AM
    They don't make them because they don't sell. Also, it's not uncommon to need to move the tires out when going larger to keep from rubbing on the control arms and such.
  8. Feb 14, 2024 at 3:56 AM
    raylo
    Frederick, MD
    I'd say that the majority of folks getting poke-y wheels do it for looks, not clearance and function. But, IMO, the 40mm don't sell because they don't make them. Not everyone wants to look like a... well I won't say it. I went through this same issue with my Tacoma and eventually got a set of TRD Pros for it which were perfect. But those were reasonably priced regular alu wheels, not the current Tundra forged BBS $$$.
  9. Feb 14, 2024 at 4:03 AM
    They do make them. You said so yourself, but they are few and far between because that is not what the majority of the aftermarket demand dictates. The Tacoma ones aren't forged, that is why they are cheaper.
    Instead of griping in this thread, why don't you create a new one and tap the awesome resource that is this forum? Give the offset and width your after and ask if anyone knows of something that fits it. You never know, there might be something great just waiting to be discovered.
  10. Feb 14, 2024 at 7:12 AM
    Yaboy
    Yaboy New Member
    Canada
    22 limited off-road
    I have 18x9 +15 offset for my winter set and they are a great setup.
  11. Feb 14, 2024 at 12:52 PM
    korslite
    korslite New Member
    Justin
    Bellingham, WA
    2022 SR5 TRD OR 6.5' Bed
    It can be tough being in the minority (of the market) sometimes...:p
    raylo[QUOTED] likes this.
  12. Feb 14, 2024 at 12:53 PM
    raylo
    Frederick, MD
    Exactly... and with my double cab and long bed I already feel like an outlier or second class citizen. ;-). But I was able to find the model wheel I like (Fuel Flux) in a 30mm offset, which would work. But they don't make that offset in the colors I want. LOL.
    korslite[QUOTED] likes this.
