Wheel Fitting Issue (Need Help!!!)
Discussion in 'Wheels & Tires' started by Jomeze, Jul 12, 2019.
  1. Jul 12, 2019 at 7:48 AM
    Jomeze
    Jomeze [OP] Jomo
    Johnathon
    Cayce, South Carolina
    2007 Black Tundra SR5
    Painted Calipers Restored Headlights
    So I bought these wheels from 4Wheel Online through Amazon. Please see link below.
    https://www.amazon.com/gp/product/B004IPPA5I/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1
    This morning I went to have them mounted and the tire professional said that they didn't fit. I called 4Wheels Online and they said it could be an offset issue. I looked up the specs again and everything checked out. I have a 2007 Tundra. They should fit perfectly right? I'm completely flabbergasted that they didn't fit on the hub. I"m planning to return the wheels and getting different ones but I need a second, third, and fourth opinion. Any advice?
  2. Jul 12, 2019 at 8:04 AM
    TrooperDC4x4
    TrooperDC4x4 New Member
    Nor Cal
    2017 BBP Double Cab 5.7L TRD 4X4 OR
    Bilstein 5100 2.5", 1.5"
    I almost bought these wheels but I was never able to confirm fitment. By the specs they should fit. Is it the hub bore that is causing the problem? Can the tire shop tell you why they don't fit?
    Rica25 likes this.
  3. Jul 12, 2019 at 8:26 AM
    Jomeze
    Jomeze [OP] Jomo
    Johnathon
    The center bore lined up just fine. I did more digging on it and it looks like it is an offset issue. I need to find wheels with the correct offset.
    Rica25 likes this.
  4. Jul 12, 2019 at 8:31 AM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    Checking the specs it looks like they should fit. Major f-up on the part of the manufacturer if they don't 'cause only Tundra, sequoia, LC and their lexus cousins use 5x150
    Rica25 likes this.
  5. Jul 12, 2019 at 8:35 AM
    TrooperDC4x4
    Nor Cal
    These wheels are supposed to have a 30mm offset. Seems like they should fit without issue. It would be nice to confirm the offset.
    Rica25 likes this.
  6. Jul 12, 2019 at 9:53 AM
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    An 18x9 +30 should fit fine. Have you verified yourself exactly what about them isn’t fitting? What is hitting?
    15whtrd likes this.
  7. Jul 12, 2019 at 11:25 AM
    Ynot_tonY
    Ynot_tonY Merciful
    Tony
    Baby mods doo doo doo doo doo doo
    Audio/Lift/Tires
    Whats the backspacing? Thats just as important as the offset.
  8. Jul 12, 2019 at 11:53 AM
    TrooperDC4x4
    Nor Cal
    Specs say 6.181".
    These wheels should fit.
    Here's the specs.
    Wheel Diameter:18 in.
    Wheel Width (in):9.000 in.
    Wheel Material:Aluminum
    TPMS Sensor Compatible:Yes
    TPMS Sensor Mounting Style:Universal band mount
    Primary Wheel Color:Black
    Wheel Finish:Matte
    Manufacturers Wheel Series:ION Alloy 179 Series
    Backspacing (in):6.181 in.
    Offset:+30.00mm
    Wheel Construction:1-piece
    Beadlock Included:No
    Beadlock Functional:No
    Lug Nut Seat Style:Conical seat - 60 degree
    Hub Centric Ring Compatible:Yes
    Center Bore Diameter (in):4.331 in.
    Center Bore Diameter (mm):110.00mm
    Center Cap Included:Yes
    Load Rating (lbs):2,500 lbs.
    Lug Nuts Included:No
    Small Diameter Lug Nuts Required:No
    Valve Stems Included:No
    Quantity:Sold individually.
    Wheel Bolt Pattern (app):5 x 150mm
  9. Sep 8, 2019 at 12:24 PM
    TrooperDC4x4
    Nor Cal
    Did you ever get this straightened out? Interested to find out what became of this. Did the wheels fit?
    I still like these wheels, like to know if they fit.
  10. Sep 8, 2019 at 12:28 PM
    TXTundra2722
    2015 Black Tundra
    I'm curious as well as to the actual backspacing/offset was on these... not the advertised but measure it and see
  11. Sep 8, 2019 at 12:32 PM
    TrooperDC4x4
    Nor Cal
    Yeah, with these specs how could they not fit our trucks. Vision Raptor 9.5" wide wheels with 6.25" backspacing fit so these should also.
  12. Sep 8, 2019 at 1:07 PM
    TXTundra2722
    2015 Black Tundra
    I'm thinking they must have sent the wrong wheels or they were labeled improperly
  13. Sep 8, 2019 at 1:09 PM
    TXTundra2722
    2015 Black Tundra
    With only 15 posts I'm going to guess that OP doesn't get on here anymore or often
  14. Sep 8, 2019 at 1:12 PM
    Scuba
    Scuba Sober member
    Austin, Tx.
    2012 Texas Edition CM.
    Sometimes even with the correct offset certain wheels will contact the calipers.
  15. Sep 8, 2019 at 1:17 PM
    TXTundra2722
    2015 Black Tundra
    Well that sucks. ..... got me nervous about my wheels coming in now
    :boom:
  16. Sep 8, 2019 at 1:20 PM
    TrooperDC4x4
    Nor Cal
    That's the only thing I could see. The way the spokes point toward the center of the wheel on the outer rim. Sure doesn't look that bad though.
  17. Sep 8, 2019 at 1:21 PM
    TrooperDC4x4
    Nor Cal
    Did you order these wheels?
    Let us know because I would like to pull the trigger on these wheels.
  18. Sep 8, 2019 at 1:22 PM
    TrooperDC4x4
    Nor Cal
    I think these would look really good without the center caps installed.
  19. Sep 8, 2019 at 1:24 PM
    TXTundra2722
    2015 Black Tundra
    No, I bought six, 17 inch, method, the standard rims off of another member on here. 0 mm backspacing.
  20. Sep 8, 2019 at 1:27 PM
    TrooperDC4x4
    Nor Cal
    I think the Method's have been proven to fit, you should be fine even with the 17's.
  21. Sep 8, 2019 at 1:44 PM
    CMB
    CMB New Member
    Cecil County MD.
    2010 Tundra DC 4X4 SR5
    Not nearly enough room here!
    I bought Land Cruiser wheels for my Tundra and had to buy 1/4" spacers, so they'd clear the calipers. I would've returned them but they were exactly the wheels I was after and my Mechanic said I'll see no issues with spacers that small.
  22. Sep 8, 2019 at 3:42 PM
    Scuba
    Scuba Sober member
    Austin, Tx.
    Yeah, exactly.
    I've seen it a few times over the years (not necessarily on Tundras).
  23. Sep 9, 2019 at 8:15 PM
    Jomeze
    Jomeze [OP] Jomo
    Johnathon
    I ended up sending them back but now I realized that I could've bought 1/2 inch spacers or 1 inch spacers and would've been fine. I'm glad I learned what to do but I found some TRD style wheels that I like a little more so I'm saving up for them. So in summary those wheels do fit but they would need spacers on a 2nd generation. I might just by some just to be safe so this won't happen again.
  24. Sep 9, 2019 at 8:55 PM
    TrooperDC4x4
    Nor Cal
    Where were the wheels making contact exactly? Were the spokes hitting the calipers or were the the tires hitting the skid plate when wheels were turned?
    Just curious as the specs for those wheels should work with our trucks.
    Glad you found something you like.
    What TRD wheels are you looking at?
