What's your general maintenance schedule?
Discussion in 'General Tundra Discussion' started by Spvrtan, Aug 16, 2017.
  1. Aug 16, 2017 at 3:56 PM
    Spvrtan
    Spvrtan [OP] Amateur fabricator
    Kris
    San Diego, CA
    The other threads got me curious on what people are doing with their routine maintenance. Below is the maintenance I do myself on Pluto, who is currently at 58k on the odometer..
    Every 2,500 miles
    Check fluids: windshield, steering, brakes, coolant.
    Check & lube suspension (use Tri-Flow): UCA, LCA, spindle, tie rod, leaf springs, shackles
    Every 5,000 miles
    Tire rotation
    Oil change (Royal Purple 5w-30), oil filter change (TRD oil filter), and engine cleaner (Sea Foam in gas tank)
    Lubricate driveshaft assembly (Royal Purple)
    Power steering fluid drain/fill (Toyota ATF)
    Every 10,000 miles
    Replace cabin filter
    Clean intake filter (K&N cleaner) and MAF sensor (CRC spray)
    Every 15,000 miles
    Differentials & transfer case (Mobile 1 75w-90)
  2. Aug 16, 2017 at 4:35 PM
    I pretty much stick to Toyota recommended PM. I was lucky...I have all maintenance records from birth on my 07. All recorded on "My Tundra owners" website. Lucky me.
    DalTee likes this.
  3. Aug 16, 2017 at 4:42 PM
    Cement Pro
    Cement Pro New Member
    2017 Toyota Tundra Pro
    Stock
    a little over kill don't you think?
    DalTee and Tundra_mike89 like this.
  4. Aug 16, 2017 at 5:06 PM
    DalTee
    DalTee New Member
    Dal
    2011 SuperWhite CrewMax Limited
    Extang Folding Tonneau, 20 percent tint, TRD dual exhaust, BedMat, Stubby antennae, Bully Hitch Step, AVS Window Shades
    Must not be married
  5. Aug 16, 2017 at 5:07 PM
    Eclipsed & Floating
    I’m right where I need to be
    Voluptuous Whitey
    It's a Toyota....no maintenance required
    Black Wolf likes this.
  6. Aug 16, 2017 at 5:09 PM
    Alphy...you left out weekly weekend fluid checks with the sixer...Just sayin....hoo..wee........
  7. Aug 16, 2017 at 5:09 PM
    Eclipsed & Floating
    Voluptuous Whitey
    you and i are friends....i assumed everyone already knew that
  8. Aug 16, 2017 at 5:14 PM
    You assumed correctly of course. My Sarc genes are kicking in with every beer.......after all...my liver tests came back negative....
  9. Aug 16, 2017 at 5:30 PM
    AnonVet
    AnonVet That's what she said!
    Weatherford TX
    2015 TRD SR5 CM
    7 inch pro comp 35x12.5 RPB Repulsars (Hate'em) 18x9 Rhino Glamis Bilstein 5100's TRD Pro grille Murdered out Spyder heads Smoked tails Leds all around her Debadged Go Rhino BR5 Front Bumper
    There's maintenance on these things?
  10. Aug 16, 2017 at 5:33 PM
    AnonVet
    Weatherford TX
    2015 TRD SR5 CM
    To be honest, you have all the reason in the world to conduct every single tiny preventative maintenance to your rig, it's pretty much a fucking tank without the milspec number.
  11. Aug 16, 2017 at 6:04 PM
    Cement Pro
    Stock
    I think you're not lubricating the exhaust enough
    kenomouth64 likes this.
  12. Aug 16, 2017 at 6:15 PM
    Yes there is some maintenance occasionally. A good wash and buff out per WarEagle specifications......I should know...I'm his great uncle today......
    AnonVet[QUOTED] likes this.
  13. Aug 16, 2017 at 6:30 PM
    kenomouth64
    kenomouth64 New Member
    Tetrus
    2007 Toyota Tundra Sr5 4x4 (TRD Off Road) Crewmax 5.7L
    Hold the Line! If you are not holding the line, abandon your ship. Destruction is inevitable without more to hold the line!
    Wow you definitely maintain your truck. If you ever plan on selling it, the person who purchases it will appreciate all the maintenance. If you do not ever sell it then you will appreciate it in 10+ years from now.
    At first glance I was thinking the maintenance was too excessive but after reflecting on the fact the you off-road all the time, it makes sense to keep the fluids you mentioned fresh.
  14. Aug 16, 2017 at 6:39 PM
    The main thing is.. Log on to My Toyota Owners site. Put in your VIN#. You may be pleasantly surprised. Maybe the previous owner/dealer put in info. If no info.......START new info. Can't hurt.
    kenomouth64[QUOTED] likes this.
  15. Aug 16, 2017 at 6:44 PM
    kenomouth64
    Tetrus
    I did not know that this existed. I will have to look into it. I currently keep very detailed info on the maintenance I have performed so far, so it will be nice to be able to transfer the info over.
  16. Aug 16, 2017 at 7:31 PM
    AnonVet
    Weatherford TX
    2015 TRD SR5 CM
    You should see him on instagtam... he uses his truck for every thing it is worth. The new owner better be ok with body imperfections lol
  17. Aug 16, 2017 at 9:42 PM
    Spvrtan
    Kris
    San Diego, CA
    Hah, better safe than sorry, especially to avoid any stupid breakdowns when I'm way off the grid. Also, for how much I abuse my truck offroad and the type of offroading I do, the maintenance is kind of warranted.
    That might change in 1-2 years if my girlfriend has her way, haha. I just love working on my truck.
    I plan on handing this truck down to my first child ..but that's a strong maybe, haha.
    AnonVet and kenomouth64[QUOTED] like this.
