What's your 2023 Tundra's Real World Fuel Mileage
Discussion in '3rd Gen Tundras (2022+)' started by Silver '23, May 10, 2023.
  1. Dec 13, 2023 at 7:37 AM
    #211
    DougNuts
    DougNuts New Member
    For fuel economy discussions, I recommend 3 tank averages. Fuelly is a good source for both data and recording your economy. Dash readouts are good for anecdotal bragging rights, but that's about all. ;)
  2. Dec 13, 2023 at 8:36 AM
    #212
    DRP
    DRP Old Member
    Dave
    50mph tailwind? Oops, sorry, 80Kph tailwind? :)
    Mattedfred likes this.
  3. Dec 13, 2023 at 8:38 AM
    #213
    Breathing Borla
    Northern Illinois
    the dash read out has been dead on balls accurate overtime Ive checked it, my old tundra was the same way.
    My ram was always higher reading than actual by 2-3 MPG
    TundraDan723 and BoulderGT3 like this.
  4. Dec 13, 2023 at 9:20 AM
    #214
    tboo72
    tboo72 New Member
    2022 Platinum
    Most my driving is hwy
    Stock tires in Wisconsin in the fall: 20MPG
    AT tires in Wisconsin in the fall: 17MPG
    AT tires in Wisconsin in the winter: 15MPG
    cmiles97 and Malinois38 like this.
  5. Dec 13, 2023 at 9:22 AM
    #215
    Breathing Borla
    Northern Illinois
    did you go up to load e? looks like it from that big of a loss
  6. Dec 13, 2023 at 10:26 AM
    #216
    tboo72
    tboo72 New Member
    2022 Platinum
    Yes they are load e. Stock size though and 18lbs heavier than the factory Yokos.
  7. Dec 13, 2023 at 10:47 AM
    #217
    Breathing Borla
    Northern Illinois
    ya, that sure explains it, plus winter blend here in the midwest is total shit
  8. Dec 13, 2023 at 11:29 AM
    #218
    PBNB
    PBNB Needy
    Peter
    Vancouver, BC
    2023 Z71 3500 HD
    Lots of stuff!
    My little electric BMW is a great way to show me what happens when you go faster. If I drive at 50 mph, I can see the battery drain slowly, if I bump it up to 70 mph, the electrons start to move quickly, at 80 mph, the electrons are being flushed down the toilet!.
    Slow down if you want better mileage. Like @Mattedfred diving closer to 50 mph will produce great economy, but in @Eurodriver example, the truck has the aerodynamics of a barn rolling down the road and running at full boost is just sucking the fuel!
    cmiles97 and Mattedfred like this.
  9. Dec 13, 2023 at 11:37 AM
    #219
    PBNB
    PBNB Needy
    Peter
    Vancouver, BC
    2023 Z71 3500 HD
    Lots of stuff!
    Thanks - that's perfect now! :)
    Eurodriver[QUOTED] likes this.
  10. Dec 13, 2023 at 9:37 PM
    #220
    PNW Tundra Mike
    Southern Cal
    MX4 Tonneau, Talon's Trans/Cat Shield
    Pick your year (from Fuelly users)
  11. Dec 13, 2023 at 11:30 PM
    #221
    NHKTundra
    NHKTundra New Member
    2022 Tundra TRD Pro Lunar Rock
    Retrax. Uptop AFS bed rack. Condor XL. Dobinson rear springs. BFG 35/12.5/r18. BD light bar and ditch lights. Prinsu roof rack. Diode dynamics fog upgrade.
    I’m at 11.8 with my TRD Pro. Not very good, but if anyone can help me understand. I do run bigger tires, 35/12.5/r18 BFGs on stock TRD pro wheels. My truck now runs 3 miles slower than real life shown on my GPS. IE odd shows 30 miles an hour, GPS now shows 33. Should my actual real world MPG be better than what my car shows? Any easy calculator to show how tire size change effects MPG calcs?
    To be fair, I got a big RTT, heavy rear load in general running around 500-600 lbs with all of our overlanding gear. Roam boxes up top. Not to mention frequently doing road trips in Texas driving 90-95 miles per hour.
  12. Dec 14, 2023 at 3:10 AM
    #222
    racer01
    racer01 New Member
    Geoff
    Aiken South Carolina
    23' TRD Pro
    295/70-18 Nitto Recon Grappler, RB 20 running boards
    My thoughts. I have 34.3" tires on my TRD Pro so have done some (probably shady) maths.
    Yes your MPG on the truck dash will show lower than actual, as your bigger tires throw off the odometer. You are actually going further than the odometer says as it is calibrated to stock tires (~32.6")
    To calculate actual MPG take your 35" tires actual diameter (from discount tire or tire rack specs) and find % difference from stock. Then use that to correct odometer reading (i.e. my tires are about 5% bigger so I multiply odometer reading by 1.05 to get actual miles traveled).
    I see about 1 mpg estimated improvement over the dash reading when I apply this logic.
    My 295/70-18 Nitto Recon Grapplers are "S" weight range vs "E" on most every 35" tire so are a little lighter and a little smaller. Showing 16-17 mpg on the dash in normal driving so likely about 17-18 mpg actual.
    Eurodriver likes this.
  13. Dec 14, 2023 at 4:04 AM
    #223
    nodak67
    nodak67 New Member
    JR
    lol shows our tundra in the 2023 overview pic (middle one)
  14. Dec 14, 2023 at 7:00 AM
    #224
    cmiles97
    cmiles97 New Member
    2018 Toytota Tundra SR5 4x4 XP
    XP package
    With forced air induction vehicles the more boost you use the less mpg you get. Ford named theirs correctly. Eco or Boost, your choice.
    I read an article about why booted smaller displacement motors are capable of so much HP/TQ. Basically at 14.7 psi boost (equates to approx. twice atmospheric pressure) your volumetric capacity doubles.
    A 2.7L turbo motor is now a 5.4L
    A 2.3L is now 4.6L
    Funny how Ford made them that way to match their V-8s at the time.
    3.5L now equal 7.0L at that boost level. This is why they are worse on gas than their Naturally Aspirated counterparts at high boost. When not in or using very little boost you have small displacement and more mpg.
    22whatwedo and Mattedfred like this.
  15. Dec 14, 2023 at 7:02 AM
    #225
    Breathing Borla
    Northern Illinois
    Ill take a boost boost motor, keep the eco, HA
    TundraDan723, cmiles97 and Eurodriver like this.
  16. Dec 14, 2023 at 7:08 AM
    #226
    cmiles97
    cmiles97 New Member
    XP package
    At least the branch didn't get to the radiator behind it. :thumbsup:
  17. Dec 14, 2023 at 7:28 AM
    #227
    Breathing Borla
    Northern Illinois
    thats 0 fun dude, boost that bitch one in a while and let it eat, its fun
  18. Dec 14, 2023 at 7:51 AM
    #228
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    How many katahdin sheeps is it?
  19. Dec 14, 2023 at 9:48 AM
    #229
    PNW Tundra Mike
    Southern Cal
    LOL, Your Lucky Day!! Haven’t noticed mine up front yet. Great App though.
  20. Dec 14, 2023 at 9:57 AM
    #230
    Maharisc
    Maharisc w/Patty
    Karl
    2023 Tundra Platinum MBM Hv CM Adv Pkg
    Build date: 12/05/22
    Just in time for the Christmas Season, careful, you'll poke an eye out... :rofl:
  21. Dec 14, 2023 at 9:58 AM
    #231
    mayan
    mayan One pull a day keeps the engine debris away.
    Mayan
    DFW
    2023 SM Tundra Limited
    Natural selection at it’s peak lol
  22. Dec 14, 2023 at 10:02 AM
    #232
    G3ardnut
    G3ardnut Brushed Chrome is COOL
    Joe
    Canada
    2023 Limited TRD Offroad Crewmax Celestial Silver Metallic
    Humans poke themselves in the eyes at times too without ever realizing it.
  23. Dec 14, 2023 at 10:20 AM
    #233
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    Look, if you pinched the radiator and have about 4 rams in truck's bed, they can tow the truck to the dealer and get slayed to cover the parts+work. You can probably even get paid by Ford or GM for that show in front of Toyota dealership.
  24. Dec 14, 2023 at 10:54 AM
    #234
    DRP
    DRP Old Member
    Dave
    But there ain't no tow hooks to hitch the goats to:eek2:
    hagrid, Eurodriver and vtl[QUOTED] like this.
  25. Dec 14, 2023 at 11:01 AM
    #235
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    Oh sh*t, well planned, Toyota! They knew it could happen!
  26. Dec 14, 2023 at 11:10 AM
    #236
    JNeemus
    JNeemus New Member
    Arroyo Grande, CA
    2024 Tundra Limited
    Most trips I’m averaging 16-17 with a 3 inch lift and 35s. If I do 50-55mph I’ve seen 18-20mpg on some drives. Tire size comparison tool showed me that stock vs the 34.5 diameter of the new tires it’s off by roughly 6.2% so after a correction on the dash readout I’m at 16.1 after a thousand miles, way better than the 11ish mpg on my 5.7 with similar mods
  27. Dec 14, 2023 at 12:13 PM
    #237
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    Can it be any better?
  28. Dec 14, 2023 at 12:45 PM
    #238
    Well, technically since they are rams, they are likely to be best at pushing from behind anyway. See Wise Toyota.
    cmiles97 likes this.
  29. Dec 14, 2023 at 12:47 PM
    #239
    cmiles97
    cmiles97 New Member
    XP package
    It is nice to know folks haven't changed. This was a common compliant in the F150 forums when Ford put Ecoboosts in them in 2011.
    My car isn't getting very good gas mileage. I only did a few mods....
  30. Dec 14, 2023 at 12:48 PM
    #240
    And my front end shakes. Toyotas suck.
