What's With All The Shlt?
Discussion in 'Off-Topic Discussion' started by Wynnded, Oct 8, 2017.
  1. Oct 8, 2017 at 7:07 PM
    Wynnded
    Wynnded [OP] What MPG...
    Rockies
    Souped up truck
    As a motorcyclist, I find to occasionally and unexpectedly find myself wondering why it seems that cattle trucks appear to be allowed to POUR RAW LIQUID MANURE from their trailers onto public roadways. :crapstorm:
    I would be hard pressed to believe that an incidence of this behavior has not at some point been determined as the root cause of a motor vehicle accident. :poking:
    Law323, FlashCulprit and ColoradoTJ like this.
  2. Oct 8, 2017 at 7:12 PM
    Tacogrande
    Tacogrande New Member
    Jeremy
    2016 SR5 dbl. cab long bed gray
    Husky weatherbeaters,short antenna,window deflectors
    Did you get behind the convoy of livestock contractors heading to the last PBR event?
    MT Madman and ColoradoTJ like this.
  3. Oct 8, 2017 at 7:14 PM
    Baja Mike
    Baja Mike Baja Aficionado
    South Bay, Ca.
    2016 Tundra TRD 4x4 SR5 white
    LED interior lights, Baja Designs foglights, Baja Designs S8 hood bulge light bar, LED bed lights, Baja Designs S8 amber bar in bumper on Rago Fab mounts, AMP Research bedstep, Switch Pros sp-9100, tinted door windows
    Sounds like a shitty situation.
  4. Oct 8, 2017 at 7:14 PM
    Wynnded
    Rockies
    Souped up truck
    It really doesn't need a convoy to make one aware of this. :wink:
    ColoradoTJ likes this.
  5. Oct 8, 2017 at 7:16 PM
    Wynnded
    Rockies
    Souped up truck
    The more the merrier....
  6. Oct 8, 2017 at 7:21 PM
    I would hate to see what would happen if I left the black water dump upen on my RV cruising down the ol' roadways.
    Law323 and FlashCulprit like this.
  7. Oct 8, 2017 at 7:27 PM
    Wynnded
    Rockies
    Souped up truck
    You might have to be in the fallout zone to get the best view.
  8. Oct 8, 2017 at 7:34 PM
    zcarpenter92
    Zach
    NE Colorado
    2008 Desert Sand 5.7L DC
    In sig
    Did the trucks you saw just have their rear doors open after leaving a LWM washout? That's the only situation I could think of where manure could wind up on a roadway in significant quantities. If the trucks are loaded you do occasionally see manure dripping down the side of them.
  9. Oct 8, 2017 at 7:41 PM
    Wynnded
    Rockies
    Souped up truck
    No, doors closed/gates up. It's usually around corners when you can see it splashing out the outside corner of the rack. Sometimes, when you initially smell it, you can see the long wet streak on the pavement. It probably pools in the bottoms of the trailers on level travel, then sloshes out around the bend. It's gallons when it happens, like >10.
  10. Oct 8, 2017 at 7:44 PM
    MotoTundra
    MotoTundra The Ocho
    Don
    Be careful on the roads @Wynnded . There are too many hazards out there. Oil leaks, diesel leaks, retreads in the road, couches in the road, dead deer in the road, all sorts of stuff in the road. I have seen so much jacked up stuff on a roadway, ride safe, keep those eyes constantly scanning!
    GNTundra and Wynnded[OP] like this.
  11. Oct 8, 2017 at 7:45 PM
    Wynnded
    Rockies
    Souped up truck
    Ya, thanks man. All in a days work.
  12. Oct 8, 2017 at 7:50 PM
    zcarpenter92
    Zach
    NE Colorado
    In sig
    Now that ya mention it I have seen that, most of the time right where a road coming from a feedlot turns onto a paved road.
  13. Oct 8, 2017 at 7:58 PM
    MotoTundra
    MotoTundra The Ocho
    Don
    It is something you don't think much about in a car though. I never thought about it until I was on my motorcycle behind a truck hauling livestock. Noticed a mist on my windscreen and my helmet shield, then a smell.
    Never made that mistake again. Pass, turn, or huge gap between haha, never behind!
  14. Oct 8, 2017 at 8:03 PM
    Wynnded
    Rockies
    Souped up truck
    Right! Never behind. I notice it all the time, I see it as one of endless road hazards no matter my conveyance of the day.
    MotoTundra[QUOTED] likes this.
  15. Oct 8, 2017 at 8:14 PM
    Ericsopa
    Ericsopa Old man and the sea
    Those trailers have a tank below the bottom floor. When they get full, it doesn't take much of a turn to spill 20-30 gallons.
    Wynnded[OP] likes this.
  16. Oct 8, 2017 at 8:18 PM
    Wynnded
    Rockies
    Souped up truck
    I was just thinking to myself, "Someone here knows the answer to this...". There it is! Learn something new every day, doesn't matter if it's shit or not.
    zcarpenter92 likes this.
  17. Oct 9, 2017 at 9:17 AM
    MotoTundra
    MotoTundra The Ocho
    Don
    You are the man Gino!
    Wynnded[OP] and GNTundra like this.
  18. Oct 9, 2017 at 9:36 AM
    Y0TA PR0
    Y0TA PR0 Oil & Gas
    Rafael
    2017 TRD PRO
    To bad I can’t push the like button more than once! Well said amigo!
  19. Oct 9, 2017 at 9:38 AM
    ubserved
    ubserved New Member
    Michael
    2017 Toytota Tundra Platinum Crewmax
    Grillguard, front LED light bar, Leer Tonneau cover, rear LED bars
    Shit happens.
    Wynnded[QUOTED][OP] and Y0TA PR0 like this.
  20. Oct 9, 2017 at 10:51 AM
    duece292
    duece292 Appalachian American
    Greg
    Green Bay, WI
    Here in Wisconsin, land of the 1500+ head mega dairy farms, there's shit all over the roads. I don't know if it's ever caused an accident but it wouldn't surprise me if it had. Manure gets pumped into a pit, liquefied and put into a tank truck. The trucks go out and spray the stuff on the fields where it covers the tank trailers and tires and in turn gets splattered all over the roads. When it's fresh it stinks way worse than running over a skunk, its all but unavoidable and you better get it washed off quick because it stains everything and dries like cement.
    Wynnded[OP] and AxelsHumanDad like this.
