What's the best air compressor for off-road use
Discussion in '2.5 Gen Tundras (2014-2021)' started by vanthesupreme, Mar 27, 2019.
  1. Apr 9, 2021 at 5:28 PM
    GravityGear
    GravityGear Parking Lot Prerunner
    Aurora, CO
    2014 Black DC TSS Off Road 4x4 5.7
    Transfer Flow tank, Pinstripe Suit
    Oasis Mfg.
  2. Apr 9, 2021 at 5:50 PM
    Safar85
    Safar85 New Member
    Ed
    Corona, Ca
    2021 SR5 CM
    More than a few.....
    Wow. 1800. I think a power tank is the way to go at 500 bucks....
    AggiePhil likes this.
  3. Apr 9, 2021 at 6:39 PM
    GravityGear
    Aurora, CO
    It's a good one. An XD4000 can probably fill a 10 gallon tank to 200psi in under 30 seconds. The last 12v compressor you will ever buy.
  4. Apr 9, 2021 at 6:45 PM
    Team4M
    Team4M New Member
    Anthony
    2016 - Tundra - 1794 - Black
    Bilstein 6112 / 5160 lift
    Big fan.
    Just got it and have only used it twice but it’s way better than I expected.
    If I planned to air up and air Down frequently I would go with an ARB but for my needs this works great and you can’t beat it for the price. It’s now called the super flow MV-50...
    https://superflowair.com/products/mv-50-air-compressor-1
  5. Apr 9, 2021 at 9:44 PM
    bmcdds
    bmcdds New Member
    CA
    2019 Barcelona Platinum
    I’ve had one of these for light use for more than 15 years.
  6. Apr 9, 2021 at 10:50 PM
    newemi
    newemi New Member
    2020 Tundra CM Ltd CB
    I have had the Smittybilt for several years now and have really liked it. I didn’t have it mounted though. It is damn quick, maybe 2-3minutes per tire, pumping up six 33” tires from 15lbs to 45lbs. (Used on my 4runner and overland trailer). It did get damn hot, so I hated putting it away afterwards.
    Personally, considering the heat in the engine bay, I plan to spend the extra dollars and get the arb mounted up for the tundra.
  7. Apr 10, 2021 at 3:52 PM
    Safar85
    Safar85 New Member
    Ed
    Corona, Ca
    2021 SR5 CM
    I bit the bullet and went with a barely used Powertank kit I found on craigslist this morning. 2 5lb tanks and bunch of accessories for 5 bills. Dont have to worry about power, time, overheating or breaking!
  8. Apr 10, 2021 at 4:53 PM
    AggiePhil
    AggiePhil Texas Chapter President
    College Station, TX
    2020 Smoked Mesquite Platinum 4x4
    Smart choice.
  9. Apr 10, 2021 at 4:56 PM
    Safar85
    Safar85 New Member
    Ed
    Corona, Ca
    2021 SR5 CM
    Plan to use it next weekend, will let everyone know how it works out.
    AggiePhil[QUOTED] likes this.
  10. Apr 10, 2021 at 6:11 PM
    GravityGear
    Aurora, CO
    Right now, CO2 is probably your best bet for inflation, granted you have a place that can fill it. You're in Corona, so there's no shortage of stores that can fill that. You will not be disappointed.
    The Oasis compressors are VERY high quality and support is superb; the price reflects both.
  11. Apr 10, 2021 at 6:34 PM
    Safar85
    Safar85 New Member
    Ed
    Corona, Ca
    2021 SR5 CM
    True on all points. The powertank won me over with the portability and versatility. The speed is huge too as I have little kids that tend to get impatient. The oasis was nice but I dont think I'm at the level yet to warrant the cost, plus mounting and such. I plan on eventually getting deeper into overlanding so at that point I think it would make more sense. Plus as you stated, theres a ton of places near me that refill.
  12. Apr 10, 2021 at 6:48 PM
    GravityGear
    Aurora, CO
    I'm planning on going DIY C02 myself. I would buy PowerTank, but I have a Twitch channel to run, so I like extended projects that have a lot of talking. You'll love the PowerTank. There's no electrical systems that can fail, no oil to monitor, no filters to change. Aside from a regulator, 100% reliability on your air source. Just mind those accessories like hoses, chucks and, connectors.
    Will you be running lines for hands free inflation? That's my plan. Run a line from the tank to a manifold under the truck, then from the manifold to a QDC at each tire. A whip will go from the QDCs to a locking chuck. A regulator set to the desired tire pressure before the manifold should allow for hands free inflation. Probably gotta be quick about connecting and disconnecting everything though.
  13. Apr 10, 2021 at 6:58 PM
    Safar85
    Safar85 New Member
    Ed
    Corona, Ca
    2021 SR5 CM
    Initially no manifold. Just gonna play around with it manually for a bit and get a feel for it and figure out what/how I wanna do it. I will eventually go that route I assume. The reliability is definitely one of the big draws to this. Only need to monitor the fluid levels of the tanks.
  14. Dec 26, 2021 at 8:15 AM
    clarkritchie
    clarkritchie New Member
  15. Dec 26, 2021 at 8:59 AM
    Ronster
    Ronster New Member
    Ron
    2017 Tundra Crewmax
    The high output ARB is under 400 and it’s an awesome compressor. Have one on my wrangler for 6 years with zero issues.
  16. Dec 27, 2021 at 8:29 AM
    coTony
    Tony
    Montrose, CO
    Love my Magnum!
  17. Dec 27, 2021 at 8:35 AM
    beaver6713
    beaver6713 2015 CM
    Kleve
    Safford Arizona
    2015 Tundra CM
    6 inch Pro Comp lift. OME rear springs with Coach Builder +3 shackles. Coach Builder tie rod ends. ICON 2.5 front and rear shocks with remote res. ICON Hyd bump stops. 35" Nitto Trail Grapplers on 18" fuel rims. Kenwood DNX 892 head unit with JL audio and RF amp pushing 2 Image Dynamics idq10 subs. SABM, S POD switches for 42" in bumper and 32" behind grille LED light bars. Full interior and exterior LED conversion. LED flush mount back up lights in rear bumper. Valentine one radar detector. V Leds under dash and seats foot well lighting. TRD pro head lights and grille. Full AJT dash kit
  18. Dec 28, 2021 at 9:28 AM
    Fallingblock
    Fallingblock New Member
    Southern MD
    2017 SR5 DC Tundra
  19. Dec 28, 2021 at 9:46 AM
    #49
    pvn.beluga
    pvn.beluga New Member
    Phuc (Phooc)
    Connecticut
    This :thumbsup:
    badmotofing3r likes this.
  20. Jan 18, 2022 at 8:32 PM
    #50
    joe557
    joe557 New Member
    Joe
    2014 Crewmax SR5 4x4 TRD
    Bilstein 6112/5160s, durobumps, 1" CB shackles, RCI skids
    What size tank is that and do you have a link to those brackets?
  21. Jan 19, 2022 at 4:09 AM
    #51
    pvn.beluga
    Phuc (Phooc)
    Connecticut
    It’s a 10# tank from Preece Precision on Amazon.
    Brackets are actually Rago Fabrication mounting board brackets I got from a forum member here. The holes fit the PowerTank bracket so I used it to mount my tank.
  22. Jan 19, 2022 at 6:42 AM
    #52
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    I use the ARB single compressor that comes in the box. Its nice since you can put all the hoses and attachments and such in the box with it. It was cheaper than the twin compressor and I really didnt want to mount it in the engine bay as its already quite busy in there with the switch pro and plus, the constant vibration with the driving just didnt sit well with me and the longevity of a 600 dollar compressor plus mounting. With the box, i can simply take it out when im not really out of the city and everything stays together.
    I also use a powertank setup as well for speed mostly and hot days when the compressor would take a long time to cool off.
    pvn.beluga likes this.
  23. Jan 19, 2022 at 9:03 AM
    #53
    Uturn09
    Uturn09 New Member
    Roscoe
    2017 Grey Tundra SR5 TRD
    None to day....that’s why I’m here.
    I am looking at a hard mount option and have narrowed it down between the ARB single and the TMJ vehicle mount one. Viair 400h-a was more money for less cfm then the other two. TMJ is the cheapest by a little ($30-40).
    Any experience with the TMJ hard mount or arb high performance? Which would you get and why?
  24. Jan 19, 2022 at 10:05 AM
    #54
    shawn474
    shawn474 Lego connoisseur
    MoCo, Maryland
    Mater likes this.
  25. Jan 19, 2022 at 10:25 AM
    #55
    helidave
    helidave Hellacopter
    flagstaff
    2015 DC 4x4
    I use a 10lb CO2 tank with a fixed 150 psi regulator. Under $200 for everything from Amazon and $20 to fill at the local scuba shop. Fills four 35's plus two 31" trailer tires in under 5 minutes. Gets 6+ fill ups per tank. High pressure is nice for blowing dust off of gear with an air chuck too. Mounted it in the bed with some jumbo quick fists and can reach all 6 tires without removing it. Carry a cheap viair for backup.
  26. Jan 19, 2022 at 10:34 AM
    #56
    Mater
    Mater New Member
    Nick
    SD
    2016 MGM Platinum
    Anyone know if there is a company that makes a miniature rotary screw compressor? I’ve been looking and can’t find one
  27. Jan 19, 2022 at 5:03 PM
    #57
    GravityGear
    Aurora, CO
    VMAC, but that's service truck level stuff. I don't even think they make anything for the Tundra.
    Mater[QUOTED] likes this.
  28. Jan 19, 2022 at 8:16 PM
    #58
    joe557
    joe557 New Member
    Joe
    Pics of your setup and Amazon links? I was set on ARB but now I think c02 is way to go. Power tanks are nice but pricey as hell.
  29. Jan 20, 2022 at 3:42 AM
    #59
    Gaston
    Gaston New Member
    Gary
    SE MI
    2021 White Tundra SR5 CM TRD Sport
  30. Jan 20, 2022 at 3:58 AM
    #60
    Tundyfundy
    Bay Area, CA
    Magnetic Grey DC SR5 4x4 2016
    SUSPENSION: Bilstein 6112 coilover (1.9") w/ Powder Coated Springs and Spring Perch (TRD Red), JBA Upper Control Arms, Bilstein 5160's w/Billet Aluminium Reservoir Brackets, +2 Coachbuilder Shackles, Diff Drop Kit, Carrier Bearing Drop Kit, Brakeline Extensions, ABS Extension, Poly Bushings for Leafs, Coachbuilder Shims (2 Each Side), Coachbuilder Bumpstop Extensions, TRD Rear Sway Bar, TRD Front Sway Bar, Air Lift 5000 airbags w jounce bumpers, Daystar Airbag Cradles WHEELS AND TIRES: BF Goodrich KO2's 275/70/r18, BORA wheel spacers 1.25", TRD Wheel Caps,TRD Valve Stem Caps, Spare Tire Lock PERFORMANCE: Bullydog GT Tuner(Performance Tune), TRD Intake, TRD Dual Exhaust (with Modified Exhaust Hangers for Levelling Tail Pipe),TRD Brake Pads, TRD Oil Cap (US), TRD Radiator Cap, TRD Oil Filter, Optima Yellow Top Battery,GP Battery Distribution Blocks, StopTech Slotted Cryo Treated Rotors, Goodridge G-Stop Steel Braided Brake Line Kit PROTECTION: PNP Engineering Type 4 Rock Sliders (With Full Dimple Plate) ,ADD Stealth Fighter Rear Bumper w Red/Blk Shackles and Custom Stomp Pad, TRD Skid Plate with ReadyLift Spacer Kit, Victory 4x4 LCA Skid Plates, JOMAX ABS Sensor Armor, Rear Diff Breather Mod, ARK splash guards INTERIOR: Husky Liners X-Act (Front and Full Coverage Rear and Front Weather Beater Trans Hump), Interior LED Bulbs, WheelSkins Genuine Leather Steering Wheel Cover(EuroPerf), Clazzio Genuine Leather Seat Covers(BLK/DRK GRYwith custom stitching and embroidered headrests), Clazzio Seat Heaters (Front and Rear), Entune Startup Screen MOD, Entune Off Screen Mod, Tinted Windows with Windshield Visor, AJT Key Fobs,Eagle Claws Floor Mat Clips, Bodyglove Visor Organizer,Custom Door Cup Inserts, Glass Break Sensor,AJT Radio Knobs, Custom Dior Cup Inserts EXTERIOR: Full Debadge, LED Brake Light Bulbs, LED Rear Turns, LED Reverse, LED Plate Lights, LED Cargo Lights, LED Third Brake Lights, LED Front Marker Lights, LED Fog Light Bulbs, Lamin-X Fog Light Covers (Amber),2018 OEM LED Headlights, iHacker harness, VLED Universal Puddle Lights, VLED Interior Footwell Lighting (Front and Rear),VLED Extreme Amber Fornt Turns, NSV Knight Rider Light bar, Baja Designs Sport Squadron Pods in Rear Bumper (Driving/wide), Painted Red Tow-hooks, Bed Rail System, Blind Spot Mirrors, Hitch-safe, Tail-gate lock, EAG Raptor Grille, Custom Grille Badge,Full Vinyl Wrap (Matte Black/Matte Pine Green Mettalic), Charvonia Designs Tie Bed Tie-Downs, Bull Ring Bed Rail Anchors, Line-X, Tundra Bed Mat, Bakflip F1 Bed Cover SOUND: Noico 80Mil Sound Deadening and Noico 170 Mil Thermal Insulation (All 4 Doors, Roof, Floors, Rear Panel, Dash). Hertz Uno K170's Component Speakers (Front Doors with Upgraded Sail Panels), Hertz Uno K170 Coaxial Speakers (Rear Doors), JBL C1-075ct Tweeters (Total 4) in Side Dash and Center Speaker, JBL Stadium 5 Amp w/Remote Bass Adjustment Knob and Amp Rack, 12" Infinity Reference Subwoofer in Custom Enclosure w/ “TUNDRA” Logo, Fast Rings Foam Speaker Rings System(4 Doors), Fix 86 DSP
    I have one of these as well. I love it. Only complaint is it gets real
    Hot and one of the feet snapped off. Other than that been using the same one for two years no issues. I got the largest one and it was about 100 dollars. Also came with a nice bag to store everything.
