What upper control arms to go with a 6" RCD lift
Discussion in '1st Gen Tundras (2000-2006)' started by Bfb7985, May 26, 2020.
  1. May 26, 2020 at 1:32 PM
    Bfb7985
    Bfb7985 [OP] New Member
    Looking to install a 6" rcd lift soon. Trying to figure out what upper control arm to go with this setup.
    Any other do's and dont's is welcomed
    Thanks,
    Brandon
    04 tundra limited double cab 4.7
  2. May 26, 2020 at 2:38 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    If the RCD kit comes with spindles then stock arms should be fine. I'm pretty sure that's the lift my neighbor has and he runs stock arms.
    bmf4069 and Bfb7985[OP] like this.
  3. May 27, 2020 at 11:58 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
  4. May 27, 2020 at 12:03 PM
    Bfb7985
    I like what I have read on uniball systems. Im looking at total chaos or camburg uppers. But it looks like they only support 3" or under lifts
  5. May 27, 2020 at 12:05 PM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    It looks like the kit comes with new spindles, so I imagine they're taller to fit the stock uppers.
  6. May 27, 2020 at 12:08 PM
    Bfb7985
    So going with the uniball types can't hurt then?
  7. May 27, 2020 at 8:16 PM
    Brown Bear
    Brown Bear New Member
    Nor cal
    03 TRD offroad
    -6" RCD lift in front. -Custom leaf springs in rear 4" lift. -17" race line, raptor wheels. -35" Goodyear Duratrac. -4.88 gears. -ARB rear air locker. -ARB air compressor and tank. -Custom front sway bar quick disconnect -Custom one piece driveshaft -Black Oak Led 40 watt ditch lights.
    I have the rcd 6 inch lift. It uses stock upper control arms. It comes with longer spindles so no need for UCA's. Mine sit at the same angle that they did stock. Most after market UCA's are made to correct improper angle from a standard 2 to 3 inch lift kit. So it could have a negative effect. Here is how my UCA's look with the truck on flat ground. 20180305_173341.jpg my only suggestion with the rcd lift is don't use the 4 inch blocks that it come with for the rear. I had bad axle wrap with them. I had to get custom leaf springs made to solve my axle wrap problem. Other then that it's a grate lift kit. The dif drop bracket is very beefy and the longer spindles are stronger then the stock ones. I did also have to remove my front mudflaps and do a little trimming on the front bumper to fit the 35s. I also feel like I have a little more travel in the front as well. There is a little more space between the lower control arm and the bump stop.2020-05-27 20.15.47.jpg
  8. Jan 18, 2025 at 12:55 PM
    LatoSud
    LatoSud New Member
    curious how these lifts are holding up in 2025..? Has anyone run into problems with breaking any parts that aren’t available now that it’s discontinued?
    Dustbox likes this.
  9. Jan 19, 2025 at 3:36 PM
    Brown Bear
    Nor cal
    03 TRD offroad
    I haven't had any issues with the lift kit. Everything is still going strong. I did change out the bilstein's for icons. Much better ride now.Screenshot_20241024_094925_Gallery.jpg 20240801_122957.jpg 20240801_122753.jpg
  10. Feb 1, 2025 at 2:38 PM
    LatoSud
    LatoSud New Member
    Curious what the lifted spring cost.? Definitely seems like the way to go!
