What trans filter is recommended?
Discussion in '2.5 Gen TRD Pro (2014-2021)' started by Erick, Jun 1, 2023.
  1. Jun 1, 2023 at 10:53 AM
    Erick
    Erick [OP] New Member
    Erick
    Thornton Colorado.
    Bronze 2016 SR5 TRD. CM cab.
    HID lights, Duratracs, Bilstein 5100's, 2" Spacer, Sumo springs.
  2. Jun 1, 2023 at 10:55 AM
    2mchfun
    Drain and fill only, maybe two or three times 500 miles apart. There is no reason to drop the pan, you're just asking for trouble with broken bolts and possibly a warped pan that will never seal correctly.
  3. Jun 1, 2023 at 11:02 AM
    gnatehack
    gnatehack New Member
    Middle of Minnesota
    13 SR5 5.7 4x4 Bench
    Up to date maintenance
    Drain and fills FTW!
    Just had to replace a solenoid on a buddy’s truck; 9 out of the 12 pan bolts broke off even after soaking in penetrating lube and using heat…
    chugs, Tripleconpanna and 2mchfun like this.
  4. Jun 1, 2023 at 10:35 PM
    Erick
    Erick
    Thornton Colorado.
    I’d have never known. So, using the same filter is a-ok then?
  5. Jun 2, 2023 at 4:00 AM
    Black
    Black Raised Hands Surround Us. 3 Nails To Protect Us
    2014 Tundra Limited CrewMax
    Falcon Leveling System, Coachbuilder +1s, RCI Skid Plates
    On these trucks it is really just a strainer and not an actual filter.
    No real need to change them out
    2mchfun likes this.
  6. Jun 2, 2023 at 4:17 AM
    2mchfun
    It's all good, nobody knows everything about everything. Yes, there is no need to change the filter strainer. Be certain to pin open the transmission cooler thermostat if your truck has an auxiliary tranny cooler while you service it and measure the fluid removed at the same temperature as the replacement fluid so you are sure to keep the same level. That should get you really close to full. Then verify the pan oil temp is correct 115-125F with a scan tool to do a final check while making sure you are on a level surface. Lots of YouTube videos on the subject.
  7. Jun 2, 2023 at 5:07 AM
    kingsxjt
    kingsxjt New Member
    Josh
    2015 Crewmax SR5
    Just curious, were you using an impact or did they break by hand? Recently did a drain and refill at 87k but I'm contemplating dropping the pan.
  8. Jun 2, 2023 at 5:44 AM
    gnatehack
    Middle of Minnesota
    3/8” ratchet, 10mm and 3/8” sockets. All by hand hoping and praying they’d back out.
    Granted, this is/was a Minnesota truck so I was expecting this. Tried to break the pan bolt removal record I set with our Sequoia, but only tied it…
    kingsxjt[QUOTED] likes this.
  9. Jun 24, 2023 at 11:26 AM
    Tsm503
    Tsm503 Nothing to see here
    2021 DC SR5
    RC leveling kit GCS Transmission Cooler
  10. Jun 24, 2023 at 11:54 AM
    ZappBrannigan
    Canada, by way of Hawaii
    2018 1794 MGM
    NVS light bar
    So this begs the question, what’s the most effective way to remove the broken pan bolts. I imagine that the East-Out’s would work as well as they always do, which is to say they don’t.
    Are you drilling and tapping for a larger bolt or using some Heli-Coils?
