What tire will fit w/ bilstein 5100 on middle setting
Discussion in '2.5 Gen Tundras (2014-2021)' started by Tifford, Dec 2, 2019.
  1. Dec 2, 2019 at 10:25 AM
    Tifford
    Tifford [OP] New Member
    Central New York
    2024 Tundra Double Cab (stock for now)
    I'm looking to get (if possible) a taller tire with the stock rims.
    Up front I have the bilstein 5100 shocks set on the middle setting. In the back I still have the stock shocks but will replace them soonish with something similar to stock.
    Base 2014 4.6 double cab 4wd with stock rims.
    Suggestions on taller tires?
  2. Dec 2, 2019 at 10:31 AM
    AZBoatHauler
    So.Arizona
    275/70 18 (approx 33" x 10.5") is probably the tallest you can go if you don't want to cut, heat & reshape, etc. Be prepared for the truck will feel sluggish with those heavier tires and you'll take a 1-2 MPG hit.
  3. Dec 2, 2019 at 10:42 AM
    Tifford
    Central New York
    Thanks for the reply and the heads up on it feeling sluggish & the MPG hit.
  4. Dec 2, 2019 at 10:52 AM
    DMB4x4
    DMB4x4 New Member
    2014 Tundra SR5 CM 4x4
    I stuffed 34” 285/75/17
    Minor plastic trimming needed for passenger side fender well
    Skey44 and TundraDude18 like this.
  5. Dec 2, 2019 at 10:58 AM
    TundraDude18
    TundraDude18 Deus vult
    'Merica
    '21 Limited CM
    Silver Bullet Express
    Nice rims.:thumbsup:
    DMB4x4 likes this.
  6. Dec 2, 2019 at 11:16 AM
    LogCabins
    LogCabins Professional Procrastinator
    'Merica
    2017 TRD Pro
  7. Dec 2, 2019 at 11:34 AM
    Tifford
    Central New York
    DMB nice rims
    LogCabins thanks for the information. Lots to comsider.
    LogCabins likes this.
  8. Dec 14, 2019 at 9:04 PM
    Tifford
    Central New York
    I went with the stock size of 255/70R18. I had them put on a AT type tire with an aggressive tread. Maybe when all four tires need replacing I'll go with a taller tire but for now these new back tires work rather well for the snow in central New York.
