What tire size should i go with?
Discussion in 'Wheels & Tires' started by rockwarrior609, Nov 13, 2014.
  1. Nov 13, 2014 at 11:15 AM
    rockwarrior609
    rockwarrior609 [OP] New Member
    Eric
    2011 Toyota Tundra Rock Warrior Crewmax
    K+N airfilter, running boards
    I have a 2011 tundra rockwarrior and im planning on using my factory rockwarrior wheels. Im putting on the rough country 3" leveling kit with nothing in the back. I see people running 315/70/17 on them with minor rubbing if i go with the nitto trail grapplers over the bfgoodrick all terrain will i still have minor rubbing or is the more aggressive tread gonna cause more issues.
  2. Nov 13, 2014 at 10:51 PM
    TruckyTruck
    TruckyTruck Dumbest Username
    Gary
    You need them to do well on wet roads? Toyo has a new tire, R/T. Its in between the a/t and m/t as far as looks and is supposed to do really well on wet roads unlike the m/t. Whatever you go with, you can fit a 33 or 35. But with the 35s you may need to do some trimming. Check out csuviper's build. He has a 3 inch lift, rock warrior wheels and 35s.
  3. Nov 13, 2014 at 10:52 PM
    TruckyTruck
    Gary
  4. Nov 17, 2014 at 6:07 PM
    rockwarrior609
    Eric
    Yea i read his thread i wasnt sure about the diff in overall tire dimensions on the diff tire brands and if he had the 3 in leveling kit like me
  5. Nov 17, 2014 at 6:20 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Here is what i have installed
    1. Toytec Ultimate 3" Lift with front 3" Bilstein 5100 CO's and rear 1"block with rear Bilstein 5100 shocks
    2. Goodyear Wrangler Duratrac 315/70R17 Tires
    3. Spidertrax 1.25" Wheel Spacers
    The tire diameter for the Duratrac's i roughly 34.5". Each brand will be slightly different. I had to remove the front mud flaps and slightly trim the front plastic without the wheel spacers added. When i added the wheel spacers the rubbing on the front plastic was greater so i had to trim off a little more. I decided on the wheel spacers to give the truck a better stance and pull the tire away from the upper control arms.
