csuviper's Rock Warrior Build
Discussion in '2nd Gen Builds (2007-2013)' started by csuviper, Jan 6, 2014.
  1. Jan 6, 2014 at 9:55 PM
    csuviper
    csuviper [OP] Moderator Staff Member
    Broomfield, CO
    2012 Rock Warrior 5.7L 4X4
    As she sits today 8/30/17
    9/06/16
    As of 11:20am on January 18, 2014 I became the proud owner of a Black 2012 Toyota Tundra Crewmax Rock Warrior. The truck was purchased stock with only 24,290 miles. The truck was in excellent mechanical condition with only minor cosmetic items. The interior was immaculate in my opinion. Almost smelled new.
    List of current mods:
    1. Weathertec floor liners (on when purchased)
    2. Tinted windows 27% or 20% (on when purchased)
    3. Toytec front leveling spacers (on when purchased but removed with 3" lift)
    4. AntennaX Euro 13" Shorty Antenna - 1/22/14
    5. Removed horn baffles - 1/27/14
    6. Debagged - 1/27/14
    7. Mag light mounted in center console - 1/27/14
    8. Grillcraft black grill insert - 2/2/14
    9. Ultra Gauge Install - 2/17/14
    10. Fumoto F-103N Engine Oil Drain Valve - 2/23/14
    11. Toyota "Raptor" style lettering on grill painted flat black fab'd by BAMF - 2/26/14
    12. Toytec Ultimate 3" Bilstein Lift with front 3" Bilstein 5100 CO's and rear 1" block with rear Bilstein 5100 shocks - 3/16/14 (removed and replaced with Toytec Boss kit)
    13. Wheeler’s Front and Rear SuperBump Bumpstops - 3/16/14
    14. Goodyear Wrangler Duratrac 315/70R17 Tires - 3/17/14
    15. Fog Light Mod - 3/20/14
    16. Plastidipped RW Wheel Rings and center caps - 3/25/14
    17. Spidertrax 1.25" Wheel Spacers - 3/25/14
    18. Installed Tundras.com Vinyl Window Sticker - 3/25/14
    19. Tinted tail lights - 4/15/14
    20. Hypertech Speedo Calibrator - 4/17/14
    21. Paracord wrapped "Oh S#!t" handles - 5/12/14
    22. Hypertech Interceptor - 6/12/14
    23. Drop-in AFE Pro Dry Air Filter - 7/13/14
    24. Additional Bed Tie-Down Rings - 09/01/14
    25. Washable In-cab air filter Mod - 11/11/14
    26. Front and Rear Foot-well LED's - 11/29/14
    27. BA Mufflers 6" Catback Exhaust - 12/29/14
    28. Power fold Limited side mirror - 3/7/15 (Still need to wire up the power fold function)
    29. OEM Bed Rails on the side and Unistrut on the front of the bed - 3/15/15
    30. Ammo Can Bed Storage - 3/15/15 (removed when tonneau cover was installed)
    31. Amp and Sub install in a custom DIY box - 5/30/15
    32. Eagle Eyes Headlight Housing - 6/21/15
    33. DDM Tuning HID Front Headlights - 6/21/15
    34. Interior LEDs (Map and Dome) - 8/27/15
    35. Exterior LEDs (License Plate) - 8/27/15
    36. Truxedo Low Pro QT Roll-Up Tonneau Cover - 9/02/15
    37. Tailgate Anti Theft Protection - 9/12/15
    38. Rockymounts Clutch SD bike mounts - 9/27/15
    39. Additional bed/cargo LED light - 9/27/15
    40. Napier Backroadz Truck Bed Tent 13890 - 10/12/15
    41. Salex Center Console Organizer - 11/26/15
    42. Undercover Swing Case - 12/26/15
    43. 800 lumen LEDs for bed/cargo lights 1/31/16
    44. LEDs for reverse lights - 3/4/16
    45. LED DTRLs - Amber only from csjumper2003 on Tacomaworld.com - 3/6/16
    46. Total Chaos Upper Control Arms - 4/15/16
    47. Toytec Boss 2.0 3.25"/1" lift kit - 4/15/16
    48. Rear diff breather mod - 4/15/16
    49. Rear Toytec Shackles set at 1.0" - 4/20/16
    50. Vinyl hood and bedside decals - 5/28/16
    51. Baja Design's LED Fog light kit with Squadron Sport, LED Driving/Combo - 9/27/16
    52. NorthStar Ultra High Performance AGM 27F Battery - 1/27/17
    53. Battery Hold Down by @Coupe - 1/27/17
    54. Battery Terminals by GPcaraudio.com - 1/27/17
    55. American Flag Vinyl Decals - 1/28/17
    56. Baja Design's Squadron Sport Wide Cornering Lens Kit
    57. Addictive Desert Designs Venom Side Steps - 2/9/17
    58. SDHQ Off-Road ABS Guards - 3/7/17
    59. Center Console Rear dual USB replacement CIG outlet - 3/7/17
    60. Toytec BOSS Rear Remote Reservoir Shocks - 4/15/17
    61. Toytec/Radflo 2.5" Front Coilovers - 4/15/17
    62. SDHQ Off-Road Hidden Bedside Supports - 5/1/17
    63. Toytec shifter knob - 06/25/17
    64. Nitto Ridge Grapplers - 35x12.5R17 - 8/30/17
    65. Icon Six speed Wheels - 17x8.5" 25mm offset - 8/30/17
    66. Relentless Fab Cab Mount Chop (CMC) - not installed yet
    67. SDHQ Secondary Air Intake Pump Relocation Kit - not installed yet
    68. StopTech Sport Slotted Rotors and Pads - not installed yet
    Future Mods:
    1. New Windshield
    2. Install the wide angle lenses on the fog lights
    3. Re-tint the rear tail lights
    4. Add the hemoltz resonator to the exhaust , paint exhaust and finalize the shortened exhaust look
    5. Wireup the power fold function for side mirrors
    6. Trailer Harness Relocation
    7. Bed Bottle Opener
    8. Dash Cam
    9. Front Offroad Bumper
    10. Rear Offroad Bumper
    11. LED Light Bar or Cubes
    12. Rino lined bed
    13. Raam mat sound deadened
    14. Auto locking tailgate
    15. Anytime backup cam mod
    16. Remote Start
    17. Leather Seat covers
    18. Better Skid Plate
    19. True Limited Slip Rear
    20. Supercharger *In my dreams*
    Maintenance Record:
    25k: Oil change (this is when i got the truck)
    30k: Oil change, lubed propeller shaft, rotated tires, changed engine air filter with cleanable one.
    35k: Oil change, changed in-cab air filter with cleanable one.
    40k: Oil change, cleaned engine air filter
    45k: Oil change, lubed propeller shaft, rotated tires
    50k: Oil change, front and rear differential oil change, transfer case oil change, alignment, clean in-cab air filter, clean engine filter, alignment, lube propeller shaft
    55k: Oil change, lubed UCA, rotated tires, cleaned air filter, lubed propeller shaft, checked fluid levels.
    60k:
    Problems/Damage/Fixes Performed:
    100. Parking garage clearance barrior hit roof 6/1/14: Link to damage
    101. Fuse blown and map light switch burned out 9/11/15: DIY Fix click here
    102. P0101 Trouble code 1/24/15: Thread click here
    103. TPMS broke apart in tire 4/11/16: Link
    104. Clicking Rock Warrior Wheels 4/26/16: Thread click here
    105. Roof Drip Molding 5/24/16: Link to part
    106. Steering Rack Replacement 6/28/16: Thread click here
    107. Battery replacement 1/20/17: Thread click here
    CJ21, TundraDan723, jfrd30 and 9 others like this.
  2. Jan 6, 2014 at 9:56 PM
    csuviper
    Broomfield, CO
    Ultra Gauge Install
    ToyTec Ultimate 3" Bilstein Lift
    Wheeler’s Rear SuperBump Bumpstops - 3/16/14
    Fog Light Mod
    Tinted tail lights
    Map and Dome LEDs
    License plate LEDs
    Truxedo Lo Pro Tonneau Cover
    Bike mounts installed
    Bed cargo light (under Tonneau cover) installed
    Bed Cargo light replacement with LEDs 800lumen
    LED DTRLs
    Mall Crawling Fun
    CJ21, jfrd30, JoshJones1980 and 10 others like this.
  3. Jan 6, 2014 at 9:58 PM
    Sean266
    Sean266 Mr. Clean Staff Member
    Sub'd
    Brian is a very knowledgable member, and is a true asset to have here.
    Welcome!
  4. Jan 17, 2014 at 9:57 AM
    csuviper
    Broomfield, CO
    Checking out a 2012 Toyota Tundra CrewMax SR5 Rock Warrior (stock) tomorrow. Might be the one I pull the trigger on...........(edit 1/18/14): AND DID!!
    MrTuRDPro and mike.D1Esel like this.
  5. Jan 17, 2014 at 10:25 AM
    Bob
    Bob Member Staff Member
    Bob
    07 Tacoma PreRunner Black
    :popcorn:
  6. Jan 17, 2014 at 4:22 PM
    Sean266
    Hopefully it looks the way the pix show and is mechanically sound...then again with the low mileage and warranty, it shouldn't be an issue
  7. Jan 18, 2014 at 1:43 AM
    PcBuilder14
    PcBuilder14 New Member
    Brent
    Maud, TX / Whiteman AFB, MO
    2003 Tacoma SR5/TRD 4x4
    Suspension: Front - Bilstein 5100's/Eibach coils Rear - Procomp AAL & 5100's Wheels & Tires: - 33x12.50x15 KM2's - Summit Racing 85 Black 8 Series Wheels/15x8/3.75" Backspacing Armor: - Relentless Fabrication Front Bumper - 4XInnovations HREW Kickout Sliders Exterior: - BetterBuilt Lowpro black tool box - Satoshi'd Grille (Made by 03tacoman) with M1 Homertaco mesh - 15% window tint Interior: - Weathertech floormats - Locking Glove Box Latch from a 4Runner - JVC-KDR840BT stereo - Orion C0700.1M2 amp - 10" Kicker CompVT10 subwoofer Lighting: - Philips Crystal Vision Ultra Headlight Bulbs - LED Reverse Bulbs - LED interior lights Other: - Rustoleum Bedlined Bed Rails - Grey Wire Mod - Rustoleum Bedlined Fender Flares - B.A.M.F. BPV Bracket - 14" Magnaflow Muffler Dumped - 1" Diff. Drop Kit - UltraGauge - 20lb CO2 Tank - Trailhead Auto Tire Deflators - Uniden 520XL PRO CB - Diff. Breather Mod
    Excited to see what you do with the Tundra. Sad you're leaving the Tacoma though... :(
  8. Jan 18, 2014 at 1:48 AM
    650h1
    650h1 New Member
    2013 Rock Warrior C/M
    you'll love the Tundra. I had a bit of buyer remorse when driving off the lot, and looking at my lowly taco as I left it. But, then I left all 5.7 liters and 405 foot pounds on the road, and quickly forgot about the taco :
  9. Jan 18, 2014 at 10:45 AM
    csuviper
    Broomfield, CO
    I am now the proud owner of a 2012 Toyota tundra crew Max rock warrior
    MrTuRDPro, Bob and jim65wagon like this.
  10. Jan 18, 2014 at 10:49 AM
    Sean266
    Congrats!!
  11. Jan 18, 2014 at 1:14 PM
    csuviper
    Broomfield, CO
    I am debating getting a 3" lift and swapping the 35" Duratracs onto the rock warrior wheels for now or putting on the 33" terra grapplers and keeping with just the Toytec level kit it currently has on it.
  12. Jan 18, 2014 at 2:02 PM
    650h1
    650h1 New Member
    nice truck man!
  13. Jan 18, 2014 at 3:28 PM
    Sean266
    Do u need to see my rig again so I can convince you to do 35"s?
  14. Jan 18, 2014 at 3:56 PM
    csuviper
    Broomfield, CO
    Lol. I think 35s are the way to go. Just trying to figure out the quick plan for now with limited funds. Need to look at my wheel and tire thread and research a little more on if I can put theses tires on the RW rims without wheel spacers. Also trying to figure the best route to get the most out of my tacoma when I sell it.
  15. Jan 18, 2014 at 4:09 PM
    Sean266
    U parting out some of the Taco? I will help ya if needed...
    You should be able to stuff 33"a in there ...if not pick up some spacers from Toytec
  16. Jan 18, 2014 at 5:20 PM
    csuviper
    Broomfield, CO
    1. Leave the Tundra suspension as is. Install my 33" (50% remaining) Nitto Trail Grapplers on the RW wheels. Leave the 35" (40% remaining) Duratracs on the Tacoma for sale. 3" lift, new wheels and 35s would come later down the road, probably after the 33s die.
    2. Install a 3" lift now and swap the 35" Duratracs on the RW wheels. Swap the 33" Trail Grapplers on the Tacoma for sale. Added cost of pulling the 35s off the tacoma and swapping with 33s. Potential of new wheels down the road but wouldn't be as high on the list if the 35s fit.
    3. Install 3" lift now with the 33" Trail Grapplers until they need to be replaced then upgrade to 35" new tires. Tacoma keeps the Duratracs for sale.
    4. New 3" lift, new 20" wheels, new 35" tires now. $$$$
  17. Jan 18, 2014 at 5:36 PM
    Sean266
    I vote number 2
    Lift and put the 35"'s on the Tundra
  18. Jan 18, 2014 at 5:38 PM
    csuviper
    Broomfield, CO
    That's what I'm thinking. Get the lift on quick with the tire size I want.
    dandailey likes this.
  19. Jan 20, 2014 at 12:49 PM
    csuviper
    Broomfield, CO
    I just pulled the trigger on a Grillcraft Grill so that I can get the look that I really like. Similar to the Satoshi I did to my Tacoma but this one will sit flush with the front of the grill. The grillcraft will also not require the added fiberglass and bondo work that the satoshi did. It should be as easy as cutting out the inside plastic and screwing the grill on. It will look like this on my Tundra:
    I will post install pics and final product when I get around to installing.
  20. Jan 20, 2014 at 9:00 PM
    MotoTundra
    MotoTundra The Ocho
    14' Black TRD CM
    TRS Mini D2S Retrofit on TRD Pro Headlights (Apollo 2.0 Shrouds, 35w XB Ballasts, 5500k Bulbs) TRD Pro Grill BakFlip VP Tonneau w/BakBox Dipped wheels & bumpers Undercover Swingcase SunTek Paint Protection film Yellow Lamin-X Fog Overlays Tint Bedmat
    Congrats man!!!
  21. Jan 21, 2014 at 12:25 PM
    csuviper
    Broomfield, CO
    Driving my truck home. Woot, woot!!!!!
    :woot:
    MIG and MotoTundra like this.
  22. Jan 21, 2014 at 3:13 PM
    Sean266
  23. Jan 21, 2014 at 4:48 PM
    MotoTundra
    MotoTundra The Ocho
    14' Black TRD CM
    Such a nice truck man, you're going to love it!
  24. Jan 21, 2014 at 9:01 PM
    csuviper
    Broomfield, CO
    I must have been in a tunnel when i got the truck because i didnt realize it has window tint. Looks lighter than the 20% on my Tacoma. Guessing it is the legal 27%.
    Also the tailgate is already de-badged. All i have to take off is the 5.7L tags. Leaving the Rock Warrior stickers for now.
  25. Jan 22, 2014 at 2:01 PM
    Supermoto
    Supermoto New Member
    Leucadia, CA
    2002 Tundra
    Everything
    Congrats on the tundra! I do miss the power of the 5.7
  26. Jan 22, 2014 at 2:31 PM
    csuviper
    Broomfield, CO
    Updated current and future mod list in OP.
  27. Jan 22, 2014 at 2:37 PM
    Sean266
    What's the horn mod? Just moving it over?
  28. Jan 22, 2014 at 3:09 PM
    csuviper
    Broomfield, CO
    Move them over and remove the baffle. May eventually replace with something a little louder and lower tone.
  29. Jan 22, 2014 at 3:51 PM
    Sean266
    Pony up and add on a train horn
  30. Jan 22, 2014 at 3:55 PM
    csuviper
    Broomfield, CO
    Don't want to spend the money on them. Not an essential for me.
