What Tire PSI are you running?
Discussion in 'Wheels & Tires' started by georgiey22, Jan 27, 2019.
  1. Jan 27, 2019 at 5:21 PM
    georgiey22
    georgiey22 [OP] Moving to Idaho
    2019 Tundra | TRD Sport | Cavalry Blue | Crew Max
    With the truck in my signature I’m running 35 PSI all the way around. What PSI are you running on your trucks with similar tire size?
  2. Jan 27, 2019 at 5:26 PM
    15whtrd
    15whtrd Mr. Blonde
    Stock tires running 36-38 front and 28-32 rear unloaded. My tires are wearing very evenly and they respond in the corners nicely. I air them down when I Offroad and air them up when I haul. Results may very depending on brand size and rating of tire.
    Grumpy Uncle and Prostar 190 like this.
  3. Jan 27, 2019 at 5:29 PM
    Fishman57
    Fishman57 New Member
    Wayne
    Bucks County, PA
    I’m interested in opinions on this also as, hopefully, a little MPG improvement. Right now I’m running the psi’s recommended on the door jamb (30 and 32 psi’s).
  4. Jan 27, 2019 at 5:36 PM
    marlin39a
    marlin39a I’m a dumbass.
    I run 34 - 35 on my stock tires. I'm big on my tire maintenance.
    georgiey22[OP] and 15whtrd like this.
  5. Jan 27, 2019 at 5:36 PM
    Grumpy Uncle
    Pat
    CO
    42 front
    40 rear
    35x12x18 BFG KO2s
    Donkeypunch, Prostar 190 and 15whtrd like this.
  6. Jan 27, 2019 at 5:37 PM
    15whtrd
    15whtrd Mr. Blonde
    That makes for a nice cushy ride but it negatively affects MPG’s bump it up!
    Fishman57[QUOTED] likes this.
  7. Jan 27, 2019 at 5:56 PM
    Fishman57
    Wayne
    Bucks County, PA
    Thanks @15whtrd. I have to fuel up tomorrow. I think I’ll bump them up to 35 before then and go from there.
    15whtrd[QUOTED] likes this.
  8. Jan 27, 2019 at 5:59 PM
    44 psi all the way around 35x12.50x20
  9. Jan 27, 2019 at 6:01 PM
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    35x12.5x17s load range D on 8.5 wide wheels, 33 to 35 for daily driving
  10. Jan 27, 2019 at 6:13 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    My 2002 calls for 26 front and 29 rear. WTF was Toyota thinking? That seems way too low. I run at least 30 all around.
    georgiey22[OP] likes this.
  11. Jan 27, 2019 at 6:16 PM
    ardnutoz
    ardnutoz
    OZ
    SE-PA
    2018 Black TRD OR CM Limited
    35-40
    40 mainly in the winter as they drop off quicker than in the summer with the variable temps we have here
    Grumpy Uncle likes this.
  12. Jan 27, 2019 at 6:20 PM
    tundracap
    tundracap New Member
    NC
    2017 CM Limited 4x4 Silver Sky Metallic
    I like 35 all round, minimum 32.
    My 06 DC door sticker stated to run 29 in the fronts. Terrible tire life. Bumped it up to min 32 and got a whole lot more life out of a set of tires. That, and cross rotating them every 5k miles. Fonts to the back, rear tires cross over to the front.
    Same now for the '17 CM.
    15whtrd and Grumpy Uncle like this.
  13. Jan 27, 2019 at 6:34 PM
    Donkeypunch
    Donkeypunch New Member
    45 up front and 40 in the rear
    BFG KO2 275/60/20
  14. Jan 27, 2019 at 6:41 PM
    15whtrd
    15whtrd Mr. Blonde
    Does it feel like a donkeypunch when you hit a pothole? LOL JK
    joonbug, Marty McFly and Grumpy Uncle like this.
  15. Jan 27, 2019 at 6:45 PM
    Donkeypunch
    It did when I had them at 50psi which is what BFG recommended. LOL
  16. Jan 27, 2019 at 6:51 PM
    duece292
    duece292 Appalachian American
    Greg
    Green Bay, WI
    275/65/18's, I run 37lbs on all four corners. That seems to be the sweet spot.
  17. Jan 27, 2019 at 6:53 PM
    JeremyGSU
    JeremyGSU New Member
    Jeremy
    2016 Tundra
    stock 18's.
    35 psi all the way around
    georgiey22[OP] and Fishman57 like this.
  18. Jan 27, 2019 at 6:58 PM
    Boerseun
    Boerseun MGM XP-Series
    Ferdie
    Sarasota Florida
    My truck was delivered by the dealer with 28 psi. Front tires wore badly on outside edges the first 5000 miles. I increased it to 38 and it seems like it has been wearing even since then. I am at 30,000 miles now.
    15whtrd and georgiey22[OP] like this.
  19. Jan 27, 2019 at 7:00 PM
    Fishman57
    Wayne
    Bucks County, PA
    I just jacked my stock 20’s up to 35psi all around. We’ll see how it goes.
  20. Jan 28, 2019 at 4:39 AM
    Slayer
    Slayer Member
    Slayer
    roll resistance effects mileage
    pump it up
    15whtrd likes this.
  21. Jan 28, 2019 at 4:45 AM
    Adriver71x
    Adriver71x New Member
    Gerald
    2015 Tundra SR5
    Tow Mirrors
    55lbs. On 18 inch 10 ply
  22. Jan 28, 2019 at 4:59 AM
    myt1
    myt1 New Member
    Richard
    Scottsdale, AZ
    2010 Tundra DC TRD SR5 Desert Sand Mica
    OME Lift, 275/70R 18
    40 lbs.
    BFG KO2's 75/70/18
    I'm pretty sure this is the pressure recommended by Discount Tire.
    I'm at 57K miles, have gotten the tires rotated every 5K miles and I'll make 60k with no problem.
    Most of my driving is normal city, but have done plenty of four wheel drive roads when camping, but no real towing.
  23. Jan 28, 2019 at 5:15 AM
    Hondoman
    Hondoman New Member
    Jeff
    Dfw Texas
    2015 SR5 CM 4x4
    40 psi f & r.
    10 ply toyo rt 295/55-20
  24. Jan 28, 2019 at 5:27 AM
    14burrito
    2014 SR5 CM 4x4 5.7
    At the expense of accelerated/poor wear. Usually the $ saved in mpg does not equal the cost of tires.
    PLC721 likes this.
  25. Jan 28, 2019 at 5:34 AM
    PLC721
    PLC721 New Member
    Patrick
    Chandler, AZ
    2018 Ram 2500 Cummins Laramie
    IG: PLC721
    35psi 35x12.5r18 Toyo MT
    14burrito and georgiey22[OP] like this.
  26. Jan 28, 2019 at 6:06 AM
    15whtrd
    15whtrd Mr. Blonde
    True. Overinflated can negatively affect the tire wear the same as under inflated. Gotta find the right spot.
    14burrito[QUOTED] likes this.
  27. Jan 28, 2019 at 6:12 AM
    10TundraSR5
    10TundraSR5 Happy Tundra owner
    Tennessee
    2010 Black Tundra SR5
    Curse you Perry the Platypus!
    I aired up mine the other day to the mfg spec's (30 up front and 32 in the rear). I thought that was a little low and might try 35 all the way around. Glad I'm not the only person thinking this...
  28. Jan 28, 2019 at 6:19 AM
    phabej
    phabej New Member
    NO LONGER HAVE A TUNDRA... Waiting
    stock tires, 32psi, was at 35psi when I bought it but the door jam sticker says it should be 32 so I lowered it. Any reason to run it higher?
  29. Jan 28, 2019 at 6:27 AM
    15whtrd
    15whtrd Mr. Blonde
    How is your tire wear on the outside fronts? Mine were getting choppy at the door jamb specs. I added a rear sway and jacked up the pressure a bit, now they wear nicely.
  30. Jan 28, 2019 at 6:34 AM
    phabej
    phabej New Member
    They're wearing normal, at least i haven't noticed any uneven wearing. I have stock sway bars for rear/front with the TRD Sport package.
    BTW, my truck has only 4,600 miles so I doubt i'll notice any weird tread wear.
