What size 20" tires for my truck?????
Discussion in 'Wheels & Tires' started by mattyd170, Oct 29, 2018.
  1. Oct 29, 2018 at 3:02 PM
    mattyd170
    mattyd170 [OP] New Member
    Rio Rancho, NM
    2020 Tundra Limited Crewmax with Leer shell. Calvary Blue
    Stock for now, but have TRD Rear Sway bar for it.
    So I went through 44 pages of posts on the tire and wheel guide and couldn't come up with an answer, however I saw tons of bad ass trucks, wheels and tires.
    I have a 2012 Platinum with a new 5100 lift (middle). I have 20" wheels and think I just wanna get new tires, not wheels and tires. Have 275/55r20 Bridgestone's now. So I am thinking either 275/60r20 or maybe 275/65r20. I am thinking 33's will be great, but maybe 34's better.
    What is the best size tire for all around use for this truck on 20" wheels. Thank you.
  2. Oct 29, 2018 at 3:06 PM
    jewsNbrews
    Jewiston Idaho
    2019 TRD PRO
    Bolt on
    Depends how much lift the middle setting got you. I don't think the 34's will fit without trimming unless you put on top setting.
    Toyotoholic likes this.
  3. Oct 29, 2018 at 3:09 PM
    mattyd170
    Rio Rancho, NM
    Front is 38 1/2 ground to bottom of wheel well. I got 2 1/2 inches of lift. I am thinking 275/60R20's, but wanna be sure is all.
    jewsNbrews likes this.
  4. Nov 19, 2018 at 7:19 PM
    Papa's Country
    Papa's Country New Member
    '15 White Tundra Platinum Crew
    Did you end up picking a tire? What mods did you do to get it to fit?
  5. Nov 19, 2018 at 7:29 PM
    mattyd170
    Rio Rancho, NM
    I have not. Well, I have not purchased a tire yet, but I am leaning towards 275/65R20's most likely in BFG KO2's. I am also interested in the Falken, Cooper and Atturo, but haven't pulled the trigger yet. The Bridgestone Dueler's that are on my truck have worn very well, although I am not sure of the mileage on them.
  6. Nov 19, 2018 at 7:36 PM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    I have 275/60/20 Michelin defenders on zero lift. They are 33" and fit no problem. From the looks I could maybe have fit the 65 Michelin defender but who knows. The 33s look good but 34 would look better. Issue is the side lug aggressiveness of the bfgs. I would think they would rub somewhere, where as my tires are not aggressive so they seem to not be as wide if that makes sense
  7. Nov 19, 2018 at 8:03 PM
    mattyd170
    Rio Rancho, NM
    I'm afraid if I do 33's, I will be disappointed and mad I didn't do 34's. I am not going wider for the exact reason you say. I was thinking 285/60R20's, but they are almost $100 a tire more expensive. My neighbor works at Discount so I am hoping he will hook me up a little.
    Toyotoholic and Pudge like this.
  8. Nov 20, 2018 at 4:46 AM
    LT75
    LT75 Seasoned Pro
    Saint Charles, IL
    No mods yet
    You need a bit more lift to fit the 65’s. With a 3/2 I still had to trim the front wheel well piece behind the fogs. But that was it. I have 285/65/20’s though, not 275’s.
  9. Nov 20, 2018 at 4:58 AM
    Toyotoholic
    Toyotoholic -4Life-
    Jmz
    17' MGM
    Pro suspension, sways
    I have 275/65 and I'm running +3/2 lift. My wheels have +25 offset and I still needed to trim the plastic and lose the mud flaps up front... very minor shop work, and I have no rubbing. You will not regret the 34" look. If you are on stock wheels, you will probably not need as much trimming, but you will need to be at the highest lift setting. IMG_20180123_093332~3.jpg
    r1-superstar likes this.
  10. Nov 20, 2018 at 7:02 AM
    Trikerider
    Trikerider New Member
    2015 Limited CM
    Biggest issue I've found is the 275/65r20 tires are about $100 more a tire than the 275/60r20. If you put the miles on that can add up.
  11. Nov 20, 2018 at 7:05 AM
    Papa's Country
    So if I'm reading the past few posts right, using 2015 stock platinum wheels (-60 offset), 275x65r20, and minimally a 3/1 lift, everything should fit fine with exception of minor trimming? Even after market UCA's won't cause issues? Really like the look of toyotoholic setup!
    Toyotoholic[QUOTED] likes this.
  12. Nov 20, 2018 at 8:23 AM
    mattyd170
    Rio Rancho, NM
    That's sounding right to me. I removed both front mudflaps already and the plastic front inner bumper liner too. I have seen other posts where people are running them without a lift or a very minimal lift. I think I should be okay, if not I will add another coachbuilder shim to each side. I don't wanna move the spring to the highest position on the 5100's, too much compression.
  13. Nov 20, 2018 at 9:19 AM
    Toyotoholic
    Toyotoholic -4Life-
    Jmz
    17' MGM
    Yes, and Thanks!
  14. Nov 23, 2018 at 8:19 PM
    Papa's Country
    @Toyotoholic, would you mind sharing your height measurements at your fenders? Also, we're you not able to use a heat gun to mold the plastic vs trim?
  15. Nov 23, 2018 at 10:20 PM
    32vsnake
    32vsnake New Member
    david
    British Columbia
    2008 DC Limited
    275/65R20 BFG k02's on stock 08 Limited rims. Roughly 2" lift in the front, a TRD pro skid plate and the front flaps removed = no clearance issues
  16. Nov 24, 2018 at 2:36 AM
    YTThao530
    YTThao530 New Member
    What bed cover do you have ? Looks nice
  17. Nov 24, 2018 at 3:44 AM
    LT75
    LT75 Seasoned Pro
    Saint Charles, IL
    No mods yet
    Yes, the wider you go then the control arms come into play. My wheels are a +18 wth the 285’s. You will most likely be good with the stock wheels and the OEM 275 size.
  18. Nov 24, 2018 at 4:40 AM
    Toyotoholic
    Toyotoholic -4Life-
    Jmz
    17' MGM
    Revolver X2... It is a thing of beauty.
    YTThao530[QUOTED] likes this.
  19. Nov 24, 2018 at 4:56 AM
    Papa's Country
    Awesome! Really like the utilitarian look and function! No issues with drastic approach angles in forward or reverse (IE steep driveway from flat road)?
  20. Nov 24, 2018 at 7:39 AM
    fuguchan
    fuguchan New Member
    Jeff
    St. Mary's County, MD
    2018 Tundra 1794 Edition Smoked Mesquite
    ARE-Z Cap, Bed Rugs, Husky Mats
    I know I'm late on this but instead of removing both front mud flaps and plastic front inner bumper liner / minor trimming .... see this youtube vid at: https://www.youtube.com/watch?v=mnNK4gy9B_4 you could skip to 16:45. This guy installed 3/4" spacers to move the bumper forward and kept from removing anything. Looks like a good idea. Thoughts? Note, with 33's your MPG won't change much but with 34's MPG and braking will change a bit.
  21. Nov 24, 2018 at 8:15 AM
    32vsnake
    32vsnake New Member
    david
    British Columbia
    2008 DC Limited
    zero issues
  22. Nov 24, 2018 at 9:28 AM
    Toyotoholic
    Toyotoholic -4Life-
    Jmz
    17' MGM
    I used CB bumper spacers as well... 1/2" makes a lot of room.
  23. Nov 24, 2018 at 9:36 AM
    Toyotoholic
    Toyotoholic -4Life-
    Jmz
    17' MGM
    I have a great shop in the area that does all the aftermarket mods for the local dealerships. They put 4" lifts and 35s on all day, so their master "yota" tech has super clean, trim and heat mold technique that literally takes about 30min to do that part of the mod. You would think nothing was done and there's plenty of room. I'll try and get the #'s for the tire-to-fender measurement for you too.
  24. Nov 24, 2018 at 1:07 PM
    YTThao530
    Thank you so much.
