What should be my 1st mods
Discussion in '1st Gen Tundras (2000-2006)' started by ThatSR5Tundra, Oct 11, 2021.
  1. Oct 13, 2021 at 3:47 PM
    The purpose of the exhaust isn't more go. It's to make me feeeeel like I'm driving a V8. It's that sound.....
    bmf4069, shifty`[QUOTED] and Darkness like this.
  2. Oct 13, 2021 at 4:09 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    Nice. That doesn't show up on mobile, at least not for me.
    Tunes cost way too much for the gains on these trucks. I have a unichip and the canned tunes are hardly noticeable, maybe even just placebo.
    All that aside, OP should browse around and see what he likes, then start mods.
    Tundra2 and shifty`[QUOTED] like this.
  3. Oct 13, 2021 at 5:13 PM
    shifty` We call it “riding the gravy train”
    Meh, the wind dancing across my bald ass head at 80mph does the trick.
  4. Oct 14, 2021 at 4:23 AM
    Sirfive
    Sirfive Socially feral
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
    I bet i wouldnt hate 180* headers on mine.
  5. Dec 29, 2021 at 11:40 AM
    vipe650r
    vipe650r New Member
    Travis
    2000 Tundra Access Cab 4WD
    Military Green Bed liner paint
    I just picked up a 2000 Limited 4x4 Access Cab. What are the timing belt and lower ball joint mods you're mentioning? Could you tell me a bit more about those?
  6. Dec 29, 2021 at 12:32 PM
    the “mod” is being used a little tongue in cheek. It’s maintenance items for potentially catastrophic failure items. Change timing belt and water pump every 90k miles or 7-9 years. Lower ball joints should be inspected and replaced if unknown or suspect.
  7. Dec 29, 2021 at 12:58 PM
    Toyoda Tundra
    Toyoda Tundra Boxing and Tundras
    2WD 2004 AC Tundra. V8 strong
    I’d spend my money on maintenance before I try to do any mods. Timing belt, water pump, lower ball joints, brakes, shocks, inner and outer tie rods, maybe steering rack bushings or steering rack, fluids. A good running solid truck before anything else
  8. Dec 30, 2021 at 9:24 PM
    nickrick78
    nickrick78 New Member
    Nick
    Pittsburgh PA
    2004 DC
    First order of business would be to make sure it's in top mechanical shape, go thru everything, brakes suspension etc, also do the maintenance like timing belt etc.
  9. Dec 31, 2021 at 7:23 AM
    Riverdale21
    Riverdale21 Speed seeker
    OTP ATL
    06 DC SR5 Tundra TRD Off Road
    Dirt Deeds injectors, Addco rear sway, AEM dry flow air filter, last ever set of Stan's Try-Y headers, Borla full custom exhaust, front level, wheel spacers, and lots of electronics.
    Timing belt, water pump, thermostat, LBJ's, brakes, spark plugs, and o2 sensors.
    After maintenance items: Addco rear sway bar. Greatly improves the over-all handling and on-road character of the truck.
