What psi should I be running 35"
Discussion in 'Wheels & Tires' started by jokerftn1018, Feb 9, 2017.
  1. Feb 9, 2017 at 1:46 PM
    jokerftn1018
    jokerftn1018 [OP] New Member
    Daniel
    Virginia Beach
    2016 mgm sr5
    I just got a set of 35's on my 18 in methods with an E load rating what psi should i be running on these bad boys every tire place i goto sets them at the casual 35 psi but i ran my old 33's at 42ish psi.
    lukedias00 likes this.
  2. Feb 9, 2017 at 1:52 PM
    Do the chalk test. Then again, I also don't run LR E under 50 psi either.
    BMP and J4RR3N4 like this.
  3. Feb 9, 2017 at 2:22 PM
    I typically run 32 on my Coopers. No issues
    14burrito likes this.
  4. Feb 9, 2017 at 3:28 PM
    jokerftn1018
    Daniel
    Virginia Beach
    2016 mgm sr5
    What size tires are your coopers. At 32 they dont feel squishy or anything.
  5. Feb 9, 2017 at 3:37 PM
    J4RR3N4
    J4RR3N4 New Member
    South east Texas
    14 Tundra
    3” lift on 35’s
    Do the chalk test
  6. Feb 9, 2017 at 3:41 PM
    xtyfighterx
    xtyfighterx New Member
    Ty
    North Idaho
    2015 Black Crewmax Mid Travel
    I'm at 40 psi with mine
  7. Feb 9, 2017 at 4:03 PM
    jokerftn1018
    Daniel
    Virginia Beach
    2016 mgm sr5
    Well the concensus is the chalk test is the goto decision. Ill be posting aome picks of these new wheels and tires by this weekend something i havent seent a white tundra run yet.
  8. Feb 9, 2017 at 4:23 PM
    CaptTyler
    CaptTyler Life’s too short to have an ugly boat.
    Tyler
    2018 Ram 2500 Cummins
    40PSI on my Toyo's
  9. Feb 9, 2017 at 4:44 PM
  10. Feb 9, 2017 at 5:33 PM
    jokerftn1018
    Daniel
    Virginia Beach
    2016 mgm sr5
    lol yeah i am going to put them at 40 and then run a chalk test from there.
  11. Feb 9, 2017 at 5:37 PM
    U guys are crazy @50 for normal usage. Those will ware down quickly o_O
  12. Feb 9, 2017 at 5:45 PM
    If you have the proper wheel size, I ran 50psi at least in my last set and was at 50k with 4-5/32 left.
  13. Feb 9, 2017 at 5:54 PM
    TheBeast, Krezz, CaptTyler and 3 others like this.
  14. Feb 9, 2017 at 5:57 PM
    Lol. Well I also didn't have 35" tires either....and towed a lot.
    T-Rex266[QUOTED] likes this.
  15. Feb 9, 2017 at 6:22 PM
    Joeshaker
    Joeshaker New Member
    Amado
    Evergreen, Co
    13 dcsb trd4x4
    Bilstein 6112/5160 trd sway bar and ride rite bags. Black and burnt orange wet okole seat covers.
    I just dropped my LR E exo grapplers down from 40 to 35 to see if it would help with the trac going off, it didn't make a difference. But the truck drove way better at 40 psi and the tires didn't look low like they do at 35. I'll be airing them back up. Then the chalk test.
    ColoradoTJ likes this.
  16. Feb 9, 2017 at 6:27 PM
    40 psi on my Cooper STT Pro. Even wear so far.
  17. Feb 9, 2017 at 6:33 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
  18. Feb 9, 2017 at 6:58 PM
    chphilo
    chphilo Tundra addict
    Western PA
    What is the max psi on your tires? If yours is 35x12.5, your max probably is 65. If it's narrower, it's probably 80 psi. The pressure you want to run will depend on what your max psi is. I run mine (Nitto Trail Grappler, max 80) at 45 psi. During the season when the pressure could drop quite noticeably, I bump it up to 55.
  19. Feb 9, 2017 at 8:00 PM
    jokerftn1018
    Daniel
    Virginia Beach
    2016 mgm sr5
    yeah mine at 80 psi yeah i will be putting my initially at 40 then working up from there if need be.
  20. Feb 9, 2017 at 8:21 PM
    tat2ude39
    tat2ude39 MYota
    Robert
    San Tan Valley, AZ
    2021 Tundra SR5 Crewmax ~ ARMY GREEN
    I had had my Cooper ST Max @ 41psi since new. I've been told recently that 32psi is better. I was getting inside wear on fronts. The lower psi I was told would be better for gas mileage too. Helps for better cornering traction too.
    T-Rex266 likes this.
  21. Feb 9, 2017 at 8:35 PM
    Fly'n Family
    Fly'n Family New Member
    TX / CO
    2014 CM Limited
    My KO2's were initially set by the tire joint at 35psi. It's the first tire I've owned rated to 80psi - so I was real curious. Busted out the chalk and 35 looked ok, but still low. Bumped it up to 50 as a curiosity - and to much. Took it down to 40 and the chalk was spot on. I run mine at 40...
    Note: my tires are only 32.6" - so significantly smaller.
  22. Feb 9, 2017 at 9:56 PM
    Bannock452
    Bannock452 New Member
    Brandon
    Murrieta, CA
    2016 White Crewmax 4x4 SR5
    King coilovers 35x12.50-18
    I been running 40psi here also. So far been working out good.
    :burnrubber:
    Jsena and dcsleeper408 like this.
  23. Feb 9, 2017 at 10:07 PM
    jokerftn1018
    Daniel
    Virginia Beach
    2016 mgm sr5
    what size are those beasts
  24. Feb 9, 2017 at 10:51 PM
    I run 65 front and 65-80 psi rear. I'm weird.
  25. Feb 10, 2017 at 12:53 AM
    Toyos AT II 35x12.50x20s L/R E 60psi
    :eek:
  26. Feb 10, 2017 at 5:59 AM
    Lol, usually 65 psi. No need for more. I have yet to use the overloads springs.
  27. Feb 10, 2017 at 6:41 AM
    Bannock452
    Brandon
    Murrieta, CA
    35x12.5-18 :thumbsup:
  28. Mar 3, 2017 at 7:41 AM
    kicnit
    kicnit New Member
    14 Tundra TRD DC
    De-badged
    I want your wheels....
    Kyle
    Voyagermike likes this.
  29. Mar 3, 2017 at 7:42 AM
    kicnit
    kicnit New Member
    14 Tundra TRD DC
    De-badged
    And tires ....
  30. Mar 3, 2017 at 10:19 AM
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    And wear unevenly would be my guess, center tread would wear quicker id imagine.
