What other ATF can I use besides WS?
Discussion in 'Off-Topic Discussion' started by alexusw, Jun 13, 2022.
  1. Jun 13, 2022 at 11:38 AM
    alexusw
    alexusw [OP] New Member
    2007 Desert Sand Mica Tundra LTD
    I know most people believe that it’s best to stick with OEM stuff, but I would rather use different transmission fluid. The World Standard Fluid doesn’t seem to hold up as good. I’ve been researching different fluids and thought about getting a fluid exchange using Amsoil Signature Series Fuel Efficient Fluid. I want a atf that can handle extreme temperatures and flows better in the cold and with less hanging with shifts. When I drive in the morning it tends to hold gears long and hunt for a gear. Is it ok to use Amsoil in place of WS? I’m also open to other fluids that might be good.
    AZBoatHauler likes this.
  2. Jun 13, 2022 at 11:42 AM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    Calling @Sumo91
    I run the amsoil with no issues
  3. Jun 13, 2022 at 11:45 AM
    mass-hole
    mass-hole New Member
    Valvoline MaxLife is what I am running in my Lexus GX460 and a lot of the GX folks online recommend. it's been in there probably 2 years now and is just fine.
    omgboost and YardBird like this.
  4. Jun 13, 2022 at 12:20 PM
    Sumo91
    Sumo91 Busy with projects
    TN
    2014 MGM Tundra Platinum 4x4
    The amsoil will be just fine. Lots of people run it on this forum. I've ran Schaeffers 204SAT, which is thicker than recommended but worked just fine, especially in the heat of the south. And I switched over to Schaeffers 205A, which is exactly the same as the 204SAT, but thinner in viscosity to meet WS specs.
    I'd run
    Amsoil
    Schaeffers 205A
    HPL
    I'm switching over to HPL when it's time for a fluid change.
  5. Jun 13, 2022 at 12:23 PM
    Jmccracken1214
    Jmccracken1214 New Member
    2015 Tundra CM
    I switch out the factory stuff on my 2015 at 63k to maxlife, truck shifts and drives just as it did before.
    I’ve used it in my last 2 Nissan trucks with no issues.
    If you go this route, get it at Walmart, it’s about $18 cheaper a jug than the auto stores
    omgboost, alexusw[OP] and YardBird like this.
  6. Jun 13, 2022 at 12:41 PM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    S/C'd 2020 White 1794 Tundra
    this
    and walmart has it cheap.
  7. Jun 13, 2022 at 2:10 PM
    Jmccracken1214
    2015 Tundra CM
    I was at advance auto getting some grease and the guy in front of me got a gallon of maxlife, I thought I heard the total, but we went out at the same time and I asked what it cost, after tax $38. I was like sorry to ruin your day man but walmart is $20 cheaper. He looked devastated lol
  8. Jun 13, 2022 at 2:47 PM
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    If WalMart has what I need I never buy fluids at auto parts stores.
    Retroboy1989 and YardBird like this.
  9. Jun 13, 2022 at 2:52 PM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    And if Walmart don’t have it, then Amazon
  10. Jun 14, 2022 at 6:53 AM
    Retroboy1989
    Northern Utah
    2012 SR5 TRD OR (prev) 2025 SR5 TRD Rally (now)
    What about mixing? If I switched over to max-life 4 quarts are a time, does it mix well with WS? It could possibly be a couple years before all traces of WS have been purged.
  11. Jun 14, 2022 at 6:54 AM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    I've mixed it with all my toyota's.
    I'm about to do a drain & flush on my 2020.
  12. Jun 14, 2022 at 6:55 AM
    alexusw
    I’ve been debating about doing another fluid exchange, I had 3 prior fluid exchanges and feel like it should be safe (hopefully)
  13. Jun 14, 2022 at 7:04 AM
    Retroboy1989
    Northern Utah
    Thanks. My trans is 100% WS and most of it is new. I let my trans sit for a few days, pulled the plug, and let it sit for another 24 hours. The result was a 7.5qt drain. I then had another 1.5qt flush with my trans cooler install.
    What is the advantage of max-life over WS?
    Cost? Durability?
  14. Jun 14, 2022 at 7:06 AM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    it's WS compliant. so, it's WS too.
    it's available & affordable.
    it's red like the others & stinks like the others.
    YardBird likes this.
  15. Jun 14, 2022 at 8:31 AM
    Jmccracken1214
    2015 Tundra CM
    I drained my pan, filled it up, drove 10 miles, repeat. Did that 3 times I believe. That was 3-4 quarts each time.
  16. Jun 14, 2022 at 8:33 AM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    Taking off the Valhalla Cat plates is causing severe procrastination on my part.....
    Giskk and AZBoatHauler like this.
  17. Jun 15, 2022 at 10:14 AM
    mass-hole
    I believe there are ASTM standards that ensure the different fluids won't react to each other in a negative way. I know for sure there is one for motor oil, not sure specifically for trans fluid.
