What next
Discussion in '2nd Gen Tundras (2007-2013)' started by cartommy, Dec 18, 2016.
  1. Dec 18, 2016 at 3:38 AM
    cartommy
    cartommy [OP] New Member
    Indiana
    11 Tundra SR5 Crew Max 4x4
    Hi I am new here but I have recently put some AMP Mud Terrain Attack 285 65 18s on a set of XD Holeshot 18x9 +25 offset and have no lift. Currently no rubbing issues at all. Was wondering if I could go to a 305 70 18 on these wheels without lifting? I know I might have to trim a little. Looking for some expertise/experience for guidance. Thanks
  2. Dec 18, 2016 at 3:53 AM
    chphilo
    chphilo Tundra addict
    Western PA
    That's almost 35 inch tire. How much do you enjoying chopping your truck?
    I have 3 & 1/2 inch OME lift and I have 295/70/18 and I still had to do wheel well liner mod and I feel I am stuffed. I have to frequently clear the ice that builds in the wheel well during winter.
    Law323 likes this.
  3. Dec 18, 2016 at 4:54 AM
    Zharris
    Zharris Merica!
    2016 Super White 4x4 Crewmax
    Yeah man, I've spent the last couple weeks looking and trying to figure out what I can fit under my truck with no mods. I'm about 99.9% certain that's the biggest tire with that offset that you can get. Going up to that 305/70 is going to need liner trimming, mud flap removal, and possible body mount and skid plate modifications.
    cartommy[OP] likes this.
  4. Dec 18, 2016 at 9:35 AM
    cartommy
    Indiana
    What about a 305/60? W/the +25 offset
  5. Dec 18, 2016 at 9:44 AM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 Long Travel DC
    The 305/60 is smaller than the 285/65, just a little wider. What are you trying to accomplish?
  6. Dec 18, 2016 at 9:50 AM
    209TRDPRO
    209TRDPRO New Member
    2016 Tundra TRD PRO
    Just lights for now
    All the thinking and money spent on tire change you could have been done with a 4" lift and fit 35's no problem
  7. Dec 18, 2016 at 10:34 AM
    Zharris
    Zharris Merica!
    That's probably going to fit, but you'll have to do the front liner mod where you loosen the screws, shove it forward, and drill new holes in the liner. Should still have clearance on the control arm and I don't think the skid plate would come into play either.
  8. Dec 18, 2016 at 10:56 AM
    cartommy
    Indiana
    My thought is to do a 3/1 lift and put 305/65 on my current rims which are the +25 offset with the hopes of little to no trimming. I have 285/65 currently and no issues but would like a little wider tire look.
  9. Dec 18, 2016 at 11:04 AM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 Long Travel DC
    With a 3/1 the 305/65 should fit with minor trimming. But you should clear the cab mount.
    Law323 and Zharris like this.
  10. Dec 18, 2016 at 11:26 AM
    Zharris
    Zharris Merica!
    Joon is right. The widest tire you're going to be able to work with that offset is 11.2" on stock. You might could squeeze a 11.6" with the 3/1 lift. But with the 3/1 the 305/65 you want will just need a little. I think that would give you a good look.
  11. Dec 18, 2016 at 1:04 PM
    cartommy
    Indiana
    Awesome! I get mixed up on the offsets. Is it the negative offset that will move the wheel more to the outside?
  12. Dec 18, 2016 at 3:03 PM
    Zharris
    Zharris Merica!
    Correct. It doesn't have to be negative though. On our trucks, around a +35 offset puts you about even with the edge of the truck. So anything below that is going to push the wheel further out. I tried a set of spacers that made me go out to essentially a 0 offset. Super aggressive look, but rubbed.
  13. Dec 18, 2016 at 3:50 PM
    cartommy
    Indiana
    Ok thanks yeah my 25 offset puts my tires out just a little and has an aggressive look especially without out lift makes it look a little fuller. But was wanting a little wider tire hence the wonder if 305 would work with little trimming. If I may ask where do you buy all your accessories?
  14. Dec 18, 2016 at 6:00 PM
    Zharris
    Zharris Merica!
    I gotcha. I know what you mean. I like the aggressive look as well. But I buy my stuff from four wheel parts. It's a local place for me that can get just about anything you want and they do install as well.
