What mods do i need/want to tow?
Discussion in 'Towing & Hauling' started by Polished Rock, Oct 5, 2020.
  1. Oct 9, 2020 at 8:52 AM
    #61
    Ruggybuggy
    Ruggybuggy Seasoned Veteran
    Dave
    NW ON, CANADA
    2016 Tundra OR
    I wouldn't sweat about temps of 235f. Us owners of 2019-20 trucks would see 250f plus climbing hills. 235f for short durations would be fine.
  2. Oct 18, 2020 at 9:51 AM
    #62
    Polished Rock
    Polished Rock [OP] New Member
    Charlie
    Grand Junction, CO
    2018 SR5/TSS Off Road, 285/55/20" KO2s, +Roadmaster AS
    none yet
    ok. We took the camper for it’s first overnighter at a state park 90 minutes away with a 2k elevation gain.
    I have to say the truck performed well. Kept it in T/H and S4/S5 the bulk of the trips and downshifted as needed. Looking forward to a longer run next time.
  3. Oct 18, 2020 at 10:19 AM
    #63
    CrewMaxT
    CrewMaxT New Member
    Alberta
    2018 CrewMax SR5
    I put it in S after getting up to cruising speed. Using a scan gauge I watch trans temps, if they go over 200 I’ll drop it to S4. Typically in S4 or S5 while towing on the hiway. Similar size and weight trailer. Also, you shouldn’t need 80psi in the tires, with a WD hitch you won’t have enough load on them to need it that high.
    Polished Rock[OP] likes this.
  4. Oct 18, 2020 at 11:03 AM
    #64
    kittyhawk
    kittyhawk New Member
    Dave
    Houston/Buffalo Texas!!!!
    2015 Tundra Crewmax SR5 4x4
    6112/5160. Ranchhand rear bumper and Valhallas Shields.
    Wish I’d taken some pictures of my tow this weekend. We left Wednesday AM, Took a 20’ flat bed trailer up to NW Arkansas from Buffalo Tx to pick up a bunch of stuff from my moms place. Trailer empty weights about 2350lbs. Going up I ran it in T/H S5-S4 most of the way over the “mountains” in SE OK, we ran an average of 68mph with 11.5mpg. Loaded up we were around 6700lbs ran in T/H S4 average 58mph, with 9.1mpg. With that weight it really made the Tundra work but the most elevation we saw was 2100’. Climbing up to the Three Sticks Monument I had it down in S2 and still had power. So I can definitely see how being at 4000’ and towing over 10000 will definitely work the tundra more. Also have you added a CAI yet? I think it helps Just a little but dose help with Towing.
  5. Oct 18, 2020 at 2:03 PM
    #65
    Polished Rock
    Charlie
    Grand Junction, CO
    none yet
    OK.... I'm still getting up to speed. What is CAI?
  6. Oct 18, 2020 at 2:03 PM
    #66
    kittyhawk
    Dave
    Cold Air Intake. I’m using a TRD intake and feel it helps with towing.
  7. Oct 18, 2020 at 2:10 PM
    #67
    Polished Rock
    Charlie
    Grand Junction, CO
    none yet
    Ok... Haven't added that. Does yours use the TRD hood bulge/scoop for that?
  8. Oct 18, 2020 at 2:20 PM
    #68
    Durania
    Durania New Member
    Crossville, TN
    2019 Cavalry Blue CM Ltd
    The hood scoops are purely cosmetic, unfortunately.
  9. Oct 18, 2020 at 2:22 PM
    #69
    Polished Rock
    Charlie
    Grand Junction, CO
    none yet
    Ok... I have seen a "light bar" that fits in the scoop and replaces the filler. It has a "Knight Rider / Kit:" feature that scrolls the light back and forth just to be cool too.
  10. Oct 18, 2020 at 3:56 PM
    #70
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    CAI does squat wether you tow or not.
  11. Dec 5, 2020 at 5:14 PM
    #71
    Cortez11
    Cortez11 New Member
    2013 DblCab 5.7 4x4
    Can someone explain to me how downshifting would lower a tranny temp? Wouldn't downshifting raise rpm's thus raising the temp?
  12. Dec 5, 2020 at 5:19 PM
    #72
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    An increase in the rpms increases the transmission pump speed and allows the fluid to flow quicker and exchange more heat through the cooler.
    Cpl_Punishment likes this.
  13. Dec 5, 2020 at 5:45 PM
    #73
    Cortez11
    Cortez11 New Member
    2013 DblCab 5.7 4x4
    Ahhh gotcha, thanks for the quick reply.
    Ruggybuggy[QUOTED] likes this.
