What mods do i need/want to tow?
Discussion in 'Towing & Hauling' started by Polished Rock, Oct 5, 2020.
  1. Oct 7, 2020 at 8:40 AM
    SpooledReel
    SpooledReel Insufficient Funds
    RickyP
    Spanish Fort, AL
    2015 Tundra CM Limited 4x4
    I tow a 26’ Sonic trailer. I have added Sway bars, sumo springs (black) and tow mirrors (gigantic help). I have a E2 WDH and factory brake controller (2015 was wired but didn’t have one). All have made improvements.24ACEE02-844D-4924-BA23-5AD6A8F4B92A.jpg
    johnnyv5 and buetang like this.
  2. Oct 7, 2020 at 8:44 AM
    buetang
    buetang New Member
    Thats a n awesome looking set-up! Since it pertains to the OP's thread, what tow mirror set-up are you using? I went with Dometic clamp ons, and they've actually been really nice.
  3. Oct 7, 2020 at 8:44 AM
    SpooledReel
    RickyP
    Spanish Fort, AL
    Take this for what it’s worth, but I have noticed that with Chevron premium the truck feels like it tows better.
    buetang likes this.
  4. Oct 7, 2020 at 8:46 AM
    SpooledReel
    RickyP
    Spanish Fort, AL
    I put on the factory mirrors and love them
  5. Oct 7, 2020 at 9:28 AM
    Ruggybuggy
    Ruggybuggy Seasoned Veteran
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Add a convex mirror to them and you will love them even more. Eliminates the blind spot on the passenger side.
    SpooledReel[QUOTED] likes this.
  6. Oct 7, 2020 at 9:29 AM
    timsp8
    NY
    They have one on the bottom. I like it better than the bsm light.
    BGoodiE likes this.
  7. Oct 7, 2020 at 9:34 AM
    RitcheyRch
    RitcheyRch New Member
    Richard
    Star, Idaho
    TRD Lowered and Supercharged
    Supercharger is the best mod for towing. :)
    AZBoatHauler and Cpl_Punishment like this.
  8. Oct 7, 2020 at 12:03 PM
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Ya I have the same mirrors. The bottom mirror is convex but it doesn't show much and it's easy to lose a car on the passenger side. I found my original mirrors worked better. Adding the convex mirror shows everything and feel better about changing lanes to the right in heavy traffic.
  9. Oct 7, 2020 at 3:57 PM
    Not sure why people focus on the bold so much, when the pink is where the answer is.
    -When do you use engine braking? Down long downhill grades.
    -Why would you use engine braking on downhill grades? To assist in control, less wear on service/trailer brakes, and keep the charging system at the most effective output.
    -When is the highest use of your electrical system when towing? If you left the truck in drive and tow haul mode, even if the transmission did downshift a little, the RPM would still be below 2000 rpm. The electric brakes on most trailers draw a lot of energy from your system. If the RPM is not higher in the most opportune spot to generate power and recharge the battery.
    This is the reason for this specific statement.
    Drive and tow/haul is where the truck should be most of the time unless you are going down a steep grade. When you put the truck in manual mode, you lose some features like grade braking for the smaller hills.
    Try it out sometime on a daily commute. Put your truck in tow/haul and watch when coming to a stop. The next day use manual mode in S6 and watch the RPM. It doesn't downshift to assist in stopping.
  10. Oct 7, 2020 at 4:01 PM
    You are losing ~30% of your crank HP at 10K ft of elevation. So 267 HP at the crank, and after driveline loss, you will probably be down around 220 hp, going uphill, with 5000 lbs. You will definitely feel it. Part of towing with a naturally aspirated V-8 power plant.
  11. Oct 7, 2020 at 4:06 PM
    Rakso
    Rakso Tundra + Tacoma=Winner
    Oskar
    18 CM Super White 4X4
    TRD sway bar, TRD filter
    Need: nothing
    Want: look in your wallet
    JLS in WA likes this.
  12. Oct 7, 2020 at 4:19 PM
    BravoDeltaRomeo
    Bruce
    MB Canada
    2019 Cavalry Blue Tundra CM
    Interesting
    Almost every post I've seen here by people say S4 and TowHaul when towing.
  13. Oct 7, 2020 at 4:30 PM
    Doesn't make it correct. ;) It also doesn't make me correct either. :thumbsup:
    When in TH mode and drive, I was rarely out of 4th gear anyway, and in 3rd a lot. When in manual mode, you cancel out some TH mode features.
    The long downhill grades I was always in manual and likely in 3rd or 2nd to control speed.
  14. Oct 7, 2020 at 4:39 PM
    Kanobi13
    Kanobi13 New Member
    There are lots of members claiming this. Whenever i ask where the manual. Its always pasted the section about s4 in downhill braking. Individuals will claim this until blue in the face. Its your vehicle drive as you please
  15. Oct 7, 2020 at 4:40 PM
    Catmann1972
    Catmann1972 New Member
    Greg
    Rhode Island
    2020 TRD Sport
    I was thinking on adding the convex mirror to my tow mirrors also. Where did you mount the convex mirror (pic)
  16. Oct 7, 2020 at 4:45 PM
    BravoDeltaRomeo
    Bruce
    MB Canada
    No hills in MB...I started towing with it this year, S4 on first trip then S5 on way back and second trip.
    Seemed to tow fine. Maybe I'll try D next year. I know for our Sienna, I always put it in 4 instead of D.
    New truck, lots to take in and learn. No matter what it's in, I'm guessing it'll tow like a champ
  17. Oct 7, 2020 at 4:52 PM
    JLS in WA
    JLS in WA New Member
    2008 White DC Limited 4x4
    Drahthaar Transport Unit
    I put mine in D/tow haul mode and go. Long downhills I may shift into S4. Depends on the grade and the heat.
    buetang likes this.
  18. Oct 7, 2020 at 5:37 PM
    GiantWinston
    GiantWinston New Member
    Justin
    2016 MGM SR5 5.7l 4x4 Crewmax
    Toytec Boss Lift (3.5" front / 2.5" rear) 295/65/R20 Nitro Ridge Grapplers 2018 LED Headlight Conversion Pioneer AVH-W4400NEX Headunit
    For me towing my 5,500lb trailer, I like to keep it in manual mode, but between S4 and S5 depending on the speed and whether it's hilly. If the transmission is constantly changing in S5, I switch to S4. Less shifting, more control. If I'm on a long flat section (typical in SE Texas), sometimes S5 works great.
    Polished Rock[OP] likes this.
  19. Oct 7, 2020 at 8:48 PM
    #49
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Here ya go.
    TOYOTARIG likes this.
  20. Oct 7, 2020 at 10:52 PM
    #50
    Polished Rock
    Polished Rock [OP] New Member
    Charlie
    Grand Junction, CO
    2018 SR5/TSS Off Road, 285/55/20" KO2s, +Roadmaster AS
    none yet
    I used Chevron a lot when i was in Texas. But nary a Chevron to be found in CO or any of the other states I’ve been in recently. I’m using Shell Premium (with nitro) when I tow here now.
  21. Oct 7, 2020 at 11:02 PM
    #51
    Polished Rock
    Charlie
    Grand Junction, CO
    none yet
    I’m taking it out next week for the first two night trip with the trailer. Only 90 minutes away but i will have some elevation gain going out and then give it back on the return. I’ll come back and give a report on what i found with D or S using T/H.
  22. Oct 8, 2020 at 5:34 AM
    #52
    buetang
    buetang New Member
    Same, I switch it up like this... I'm not towing much anyway, my trailer is a little over 3k lbs. I just like to pretend I'm in a big rig and down shift from time to time. :D
  23. Oct 8, 2020 at 5:35 AM
    #53
    GreatBigAbyss
    GreatBigAbyss New Member
    2018 Tundra CrewMAX SR5 TRD Off-Road
    Done lots of towing with my truck, also in Manitoba and Northern Ontario. Always in D. I let the truck figure it out. That's what Tow/Haul is for.
  24. Oct 8, 2020 at 5:45 AM
    #54
    10TundraSR5
    10TundraSR5 Happy Tundra owner
    Tennessee
    2010 Black Tundra SR5
    Curse you Perry the Platypus!
    I believe @dirtydeeds is still having a REALLY nice sale on their exhaust systems. Go ahead and get you one if you're still running the stock exhaust. You won't regret it.
  25. Oct 8, 2020 at 4:30 PM
    #55
    Catmann1972
    Greg
    Rhode Island
    2020 TRD Sport
    Perfect, are they from Amazon or e-bay?
  26. Oct 8, 2020 at 6:49 PM
    #56
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Im in Canada so I bought them at Canadian Tire but I'm sure Autozone, Walmart or any aftermarket parts store would have them.
  27. Oct 8, 2020 at 7:02 PM
    #57
    Dorks68
    Dorks68 New Member
    Derek
    2010 Rock Warrior
    Sluggish? Strange. I have a 5.7CM towing a 29’ Jayco (6500ish) and was thoroughly impressed in the gas guzzling power while towing.
    johnnyv5 likes this.
  28. Oct 8, 2020 at 7:57 PM
    #58
    ATHiker
    ATHiker New Member
    Tom
    2015 DC SR5TRD 5.7L 4X4
    [QUOTE="ColoradoTJ,
    Try it out sometime on a daily commute. Put your truck in tow/haul and watch when coming to a stop. The next day use manual mode in S6 and watch the RPM. It doesn't downshift to assist in stopping.[/QUOTE]
    I understand your comments about losing features when using tow/haul in manual. However, the issue that I have is transmission temp. My transmission temps spike quickly going up hills. If I use manual, I can down shift and quickly drop the temp. I tow a camper that weighs 4,500 lbs.
  29. Oct 9, 2020 at 5:51 AM
    #59
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    I understand your comments about losing features when using tow/haul in manual. However, the issue that I have is transmission temp. My transmission temps spike quickly going up hills. If I use manual, I can down shift and quickly drop the temp. I tow a camper that weighs 4,500 lbs.[/QUOTE]
    Use both. Drive in D on the flats and down hill and use 4S only when climbing. Curious, what temps where you spilling too?
  30. Oct 9, 2020 at 8:37 AM
    #60
    ATHiker
    ATHiker New Member
    Tom
    My transmission temps will quickly climb to 235 on the rolling hills of East TN, unless I manually select a lower gear. Wish I understood Toyota's logic to block tow/haul features when in manual.
