What little thing is annoying thing about your Tundra?
Discussion in 'General Tundra Discussion' started by Mdnitedrftr, Jul 12, 2025.
  1. Jul 14, 2025 at 6:09 AM
    Corndog123
    Corndog123 New Member
    Sam
    Tennessee
    2014 SR5 Tundra Crewmax 4wheel drive 5.7
    Rough Country suspension, 305s, ARB bumper, light bar, Smittybuilt 10k winch. XD Buck 25 rims
    SCbuckeye[QUOTED] likes this.
  2. Jul 14, 2025 at 6:33 AM
    Retired...finally
    So does mine. I agree having sensors in the middle of the front bumper would be nice. I installed a front camera that gets used often. Not just for pulling in to a parking spot but to make sure there's nothing in front of my truck before pulling forward. Think bicycle, pet, kid....
    Corndog123 likes this.
  3. Jul 14, 2025 at 7:04 AM
    Heyyo_Friday
    Heyyo_Friday Circle driving enthusiast
    Derek
    2020 tundra 1794
    Rays valve stem caps
    I think they standard on 1794 and the platinum. Limited and sr5s get them as options with blind spot monitoring and rear cross traffic assist im fairly sure
  4. Jul 14, 2025 at 7:11 AM
    SD Surfer
    Bruce
    So Cal
    My wife's Mazda CX-5 sounds like a squadron of Blackhawks are landing in the back seat with the back windows open!
  5. Jul 14, 2025 at 8:46 AM
    2mchfun
    Yeah, some vehicles are worse than others for sure. I really should test drive vehicles before I buy the damn things and add this to my "tryout list".
  6. Jul 19, 2025 at 6:20 AM
    ChattanoogaPhil
    ChattanoogaPhil New Member
    2000 4.7 AC SR5 4wd
    2000 4.7 4wd. The one HUGE annoyance from when the truck was new was front brakes. After 5-10k miles when applying the brakes the front began to shake like the rotors were warped. Toyota replaced brakes under warranty two or three times. Same thing. I just learned to live with it. At about 200k miles I took it to an outside mechanic for new brakes. He replaced the passenger side caliper and a new set of pads. No shakes for the last 80k miles.
    Having read about the issue over the years I've seen things like upgraded larger calipers and all that. In my case, I wonder if it wasn't the caliper that kept the brake pads slightly engaged resulting in heating up and warping the rotor on that side? Who knows...
  7. Jul 19, 2025 at 6:37 AM
    Xcumminsguy
    Xcumminsguy New Member
    NY
    2021 Tundra TRD Pro Crew Max
    Stock, with a few cosmetic mods.
    This, by far for me.
  8. Jul 23, 2025 at 6:17 PM
    BrandonL812
    BrandonL812 New Member
    Brandon
    2021 Tundra Platinum
    Definitely look into compustar system. Better range also when you get the long range remote option. Like the 2 way remote. Stock fob is finicky on my '21. New battery in it and still sucks on the range. Just terrible. Plus no more engine shut off when door handle is pull from the outside.
  9. Jul 23, 2025 at 7:09 PM
    Xcumminsguy
    NY
    Expensive?
  10. Jul 23, 2025 at 7:36 PM
    BrandonL812
    Brandon
    Not really considering i did the install myself.
    Idatalink have a great write up on how to install it using t-harness.
    You gotta use a pc to program the brain. Other than that, pretty simple.
    I'll put a list together so you can have an idea.
    1.https://www.amazon.com/dp/B079NGGNYG
    2. https://www.amazon.com/dp/B081ZFH11W
    3.idatastart tl7. If you have PTS. None PTS uses a different t-harness. See idatalink website for specific harness for your truck year..
    https://ebay.us/m/mTBlKK
    This if you want mobile start, subscription is $50 a yr for the basic plan. See dronemobile.com for more plan.. i have the cheapest plan..
    Or
    Any 2way long range remote kit from cumpustar. I have the 2wg15r-fm 2way remote and you will need the long range antenna. Hence the remote "kit".
    4. Weblink app from idatalink website so you can flash your module.
    $58 - t-harness
    Module dc3 - $140
    Remote and drone - $138
    Total: $336 before tax
    Plus couple hours of your time. Flashing the module takes like 30 mins less.
    Most of the time is just pulling lower dash and steering cover to access plugs for the t-harness. Then run the cable for the long range antenna.
    That's about it. It's a weekend project.
  11. Jul 24, 2025 at 5:44 AM
    Xcumminsguy
    NY
    @BrandonL812 thanks so much for the detailed installation breakdown. I’ll look into it for certain.
    BrandonL812 likes this.
