What lift do I have?
Discussion in 'Suspension' started by Rancid13, Feb 6, 2017.
  1. Feb 6, 2017 at 2:31 PM
    Rancid13
    Rancid13 [OP] New Member
    Jax Beach, FL
    2011 4x4 DC SR5
    OME Dakar/Bilstein rear Rough Country leveling spacer front
    ok guys, forgive my ignorance but the lift was on the truck when I bought it. It's a spacer lift front and back. I thought it was a 3/1 but I measured the block in the back and it measures 1.5" exactly. The truck sits perfectly level, so much that it almost looks like the front is higher. I'm trying to get a slight rake maybe 1" higher in the rear overall and at the same time reduce sag when I have weight in the back or when towing. So the goal is to raise the rear 1" more than it is now, by whatever means. My thoughts are an add a leaf. If I get one that adds 1" ride height can I still use the block with it? I'm not interested in airbags or timbrens as the goal is to increase the height as well as provide less sag. Here are some pics of the current setup. Thanks in advance for your help
  2. Feb 6, 2017 at 2:33 PM
    J4RR3N4
    J4RR3N4 New Member
    South east Texas
    14 Tundra
    3” lift on 35’s
    If you plan on towing. You should ditch that block in the rear. It's de arching your leaf springs. Coachbuilder has some nice lift shackles.
    Tracker likes this.
  3. Feb 6, 2017 at 2:35 PM
    Rancid13
    Jax Beach, FL
    2011 4x4 DC SR5
    Thanks for the quick response. I definitely thought that they looked flatter than they should be. I came from a 4Runner so not used to leafs. Should I be replacing them considering how flat they are? I'll look into the coach builders
  4. Feb 6, 2017 at 2:37 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    Hard to tell what brand but it looks like a 3/1 spacer lift. How's the ride with those flat rear springs? A new Icon mini leaf pack might make you really happy.
    TheBeast likes this.
  5. Feb 6, 2017 at 2:37 PM
    J4RR3N4
    J4RR3N4 New Member
    South east Texas
    14 Tundra
    3” lift on 35’s
    I'm no towing expert maybe @ColoradoTJ can help. But depending on how much weight your hauling around, addressing them sagging leafs might be an option as well. Nice looking rig btw!
    831Tun likes this.
  6. Feb 6, 2017 at 2:44 PM
    Rancid13
    Jax Beach, FL
    2011 4x4 DC SR5
    Ride is squishy. I'll check out the icons. Might be a dumb question but I'm assuming a whole new leaf pack (any brand) that gives say 2" lift from stock would put me where I'm looking to be? If so, can anyone recommend one that has additional stiffness over stock to prevent sagging? Thanks
  7. Feb 6, 2017 at 3:04 PM
    sdhq_offroad
    sdhq_offroad New Member
    GILBERT, AZ
    The Dakar pack is heavier than stock which would be a full replacement pack. I wouldn't go with deavers since you are towing. I believe either way, you will need new rear shocks. The rears on the truck are rated for 0-1" lift. Icon add-a-packs are 1.5" of lift and utilize the factory overload and main leaf. The Dakar pack lifts the rear 2.5"
    MotoTundra likes this.
  8. Feb 6, 2017 at 3:30 PM
    Rancid13
    Jax Beach, FL
    2011 4x4 DC SR5
    Thanks for the reply. I saw the Dakars on wheelers off-road. I'll keep that in mind. Also planning to replace the shocks with bilstein 5100's front and back. Had them on my 4Runner and was very happy with them. I might go ahead and replace the front springs at the same time and ditch the spacers altogether. Any recommendation on front springs to keep the front slightly lower than the rear with the dakars?
  9. Feb 6, 2017 at 7:59 PM
    bobeast
    bobeast really old member
    Bob
    Hollister, CA
    2008 DC
    That looks like a Rough Country 3/1
  10. Feb 7, 2017 at 3:21 AM
    Rancid13
    Jax Beach, FL
    2011 4x4 DC SR5
  11. Feb 7, 2017 at 5:21 AM
    Rancid13
    Jax Beach, FL
    2011 4x4 DC SR5
    Looks like rough country makes a 3/1.5 that would explain the 1.5" block in the rear. I'm going to start from scratch. New shocks all around, new front springs for 3" lift. New rear heavy duty leafs that give 2" of lift or so. I think I'll have to piece this together. Time to do some research
    J4RR3N4 likes this.
  12. Feb 7, 2017 at 9:03 AM
    [​IMG]ToyTec (on sale) They are massive compared to OEM shackles.
    T-Rex266 and J4RR3N4 like this.
  13. Feb 7, 2017 at 2:48 PM
    xtyfighterx
    xtyfighterx New Member
    Ty
    North Idaho
    2015 Black Crewmax Mid Travel
    May be wrong but by your pics your leaf pack looks worn out not. I'd go ahead and take the block off and get a Dakar leaf pack
  14. Feb 7, 2017 at 3:08 PM
    Rancid13
    Jax Beach, FL
    2011 4x4 DC SR5
    Yup, they are. I'm considering the Dakar for the added strength. Now looking for front springs to pair with them for a slight rake. Going to ditch the spacers. Dakars giving approx 2.5" lift I'd want a 3" lift in the front. Any suggestions on a good match?
    On my 4Runner I had OME springs front and OME heavy duty springs in the back with bilstein shocks all around and I loved that setup.
    Thanks
  15. Feb 7, 2017 at 6:30 PM
    xtyfighterx
    Ty
    North Idaho
    I had the bilstien/ome setup on my Tacoma it was a great combo.
  16. Feb 8, 2017 at 5:45 AM
    Rancid13
    Jax Beach, FL
    2011 4x4 DC SR5
    Yeah great setup. I think I'm going to stick with what I know and go with the full OME lift. Dakar leaf pack, Bilsteins in the rear. OME 614 with the nitro shocks in the front. This should net me 3-3.25" front and 2.5" rear. Talked to Dan at Wheelers Off-road yesterday and this will fit the bill perfectly. I have to say Wheelers has been very helpful and patient answering my questions on my 4Runner and now my Tundra.
    xtyfighterx[QUOTED] likes this.
  17. Feb 10, 2017 at 11:49 AM
    Rancid13
    Jax Beach, FL
    2011 4x4 DC SR5
    OME Dakar springs, shackles, and Bilstein shocks shipped yesterday. I'm going to install the rear stuff first and see how it sits, then deal with the front. I'll post pics after the install. Thanks to everyone that helped out.
    xtyfighterx likes this.
  18. Feb 14, 2017 at 2:45 PM
    Rancid13
    Jax Beach, FL
    2011 4x4 DC SR5
    These are more like it.
    Pudge, J4RR3N4 and Voyagermike like this.
  19. Feb 14, 2017 at 3:59 PM
    Rancid13
    Jax Beach, FL
    2011 4x4 DC SR5
    So some of these plastic things were cracked. Is that an issue?
  20. Feb 14, 2017 at 4:04 PM
    BillE
    BillE New Member
    Billy
    2017 White Tundra Platinum
    None so far
    I just got the same pack delivered to my porch yesterday but didn't notice that part in your picture, now I'm going to go home and look.
  21. Feb 14, 2017 at 4:21 PM
    Rancid13
    Jax Beach, FL
    2011 4x4 DC SR5
  22. Feb 15, 2017 at 4:55 PM
    Rancid13
    Jax Beach, FL
    2011 4x4 DC SR5
    Talked to Dan at Wheelers they said those things break all the time. They are there to prevent squeaking and don't really work all that well anyway. He said he just takes them off if they break. He also said it won't hurt anything to leave them as is
  23. Feb 16, 2017 at 4:05 PM
    Rancid13
    Jax Beach, FL
    2011 4x4 DC SR5
    The rest of the rear stuff came today. I'll try to get these all installed over the weekend and post some pics
    J4RR3N4 likes this.
  24. Feb 20, 2017 at 7:26 PM
    Rancid13
    Jax Beach, FL
    2011 4x4 DC SR5
    Got the Dakar springs and Bilsteins installed in the rear today. I'll post pics of how it sits tomorrow. Looks just as expected, about an inch higher in the rear. I love the new stance and it rides amazing over the previous setup. Here are some shots of the install
  25. Feb 20, 2017 at 7:29 PM
    Rancid13
    Jax Beach, FL
    2011 4x4 DC SR5
    And the shackles
  26. Feb 20, 2017 at 8:06 PM
    J4RR3N4
    J4RR3N4 New Member
    South east Texas
    14 Tundra
    3” lift on 35’s
    Looking sick! Very nice
  27. Feb 24, 2017 at 12:25 PM
    Rancid13
    Jax Beach, FL
    2011 4x4 DC SR5
    Ok so I didn't remember to get a pic with just the truck. But this should give everyone an idea of how the springs prevent sag. I think it dropped half an inch once I hooked up. This rear setup is great
    SouthBoundSteve likes this.
  28. Jun 20, 2017 at 3:41 PM
    Rancid13
    Jax Beach, FL
    2011 4x4 DC SR5
    Anyone know if they make a front spacer that will net about 4" of lift? After letting the truck sit for a while I just can't get used to how much higher the rear is. It sits about 2" higher than the front, giving it some noticeable rake. I'd like to reduce the difference by an inch or so. Currently have a 3" lift spacer in there. Thanks
  29. Jun 20, 2017 at 4:30 PM
    pbryant44
    pbryant44 New Member
    Panama city florida
    2016 tundra 4wd sr5 tss
    If you where to run a 4 inch lift in the front you would need to buy new upper control arms as well.
  30. Jun 20, 2017 at 4:43 PM
    scpete24
    scpete24 Duuuuuuude
    Orange County, CA
    2016 TRD Pro Super White
    Yup, you will definitely be needing some UCA's if you go over 3". How much lift did the new shackles give you? @Coachbuilder1 has different sets of shackles with the smallest providing around 3/4 inches of lift in the rear. If your new shackles provide more, the easy answer may be to let the back end down some instead of trying to push the front up to get more level...
