What kind of camper do you have???
Discussion in 'Towing & Hauling' started by Muleycrazy13, Feb 12, 2017.
  1. Apr 24, 2024 at 11:29 AM
    #1051
    Azblue
    The Dirty T ( ^_^)_且
    I run the Equalizer and it's a really nice hitch, works well. Technically 5k is when a WDH is required, but I would run one even slightly under that. My trailer is 4800 unloaded, 7200 GVWR and I wouldn't even think of towing it without the hitch, even completely unloaded.
    Cpl_Punishment likes this.
  2. Apr 24, 2024 at 11:30 AM
    #1052
    SnrDisregardo
    SnrDisregardo New Member
    Wade
    IL
    2018 Platinum CrewMax 4x4
    TRD Sport Suspension, TRD Front & Rear Sway bar, TRD Pro Shift knob, Charcoal Filter Delete, aFe Pro Dry S w/SABM, LineX bed, Remote Start, OEM tonneau cover, DIY pop'n lock, DIY TRD cold air intake, TRD skid plate, DD SS3 amber fogs, HotShot Offroad Hot Tails, 2020 OE radio with tech12v amp and sub.
    That's why I'm thinking the 600/6000# one from them would be sufficient, but maybe the 800/8000# for wiggle room. I just don't want to damage the a-frame.
  3. Apr 24, 2024 at 2:28 PM
    #1053
    bflooks
    bflooks New Member
    Metrowest MA
    the 800s on that light of a trailer is going to be harsh on the ride and the trailer.
    Mattedfred likes this.
  4. Apr 24, 2024 at 3:27 PM
    #1054
    SnrDisregardo
    Wade
    IL
    That’s my thought too. It came with 800#’s from the guy I bought it from and seemed like a rougher ride than I was expecting
  5. Apr 24, 2024 at 3:30 PM
    #1055
    bflooks
    bflooks New Member
    Metrowest MA
    Yup. Some people think more is better. And in some areas, it is. On a WDH bar, not usually. I actually found my maxed out 800s gave a much better ride (and marginally less performance) than the 1ks Im.currently running. I read it on this site that the tundras like a softer setup, and my experience matches.
  6. Apr 24, 2024 at 3:43 PM
    #1056
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    If you're not sure, might be worthwhile seeing if you can weigh it to get a realistic hitch weight. It will definitely be more than 370 lbs but it's hard to say how much more.
  7. Apr 25, 2024 at 5:48 AM
    #1057
    SnrDisregardo
    Wade
    IL
    Oh I agree. Just waiting to do some repairs on it before we load it. I know I won't get a true weight but if I can get it relatively close to travel weight, I think that would work.
  8. May 2, 2024 at 7:43 PM
    #1058
    MoPops
    MoPops New Member
    Jeff
    2012 Dbl cab, 4x4, 2023 SR5 TRD 4x4 Dbl cab
    Bilsteins all around, RAS, E tires.. All on the 2012
    I pull a 25’ Airstream. Have for years. I switched to Bilstein shocks, E rated tires, and added a Roadmaster Active Suspension. I know these modifications do not increase the door sticker number. They just make pulling the trailer easier.
    koditten and Retroboy1989 like this.
  9. May 2, 2024 at 8:48 PM
    #1059
    Retroboy1989
    Northern Utah
    2012 SR5 TRD OR (prev) 2025 SR5 TRD Rally (now)
    My 2012 does not like heavy tires. I've battled steering wheels shakes with D and E rated tires. That said, with trd sway bar, sumo springs, good quality P-rated tires, proper air pressure and a good wdh, it pulls my 30ft Jayco well.
    MoPops[QUOTED], koditten and j-utah like this.
  10. May 3, 2024 at 6:40 AM
    #1060
    MoPops
    MoPops New Member
    Jeff
    Interesting. I’m almost done with the Cooper Discoverer E rated 20” tires. No steering shake, but a noticeable drop in mpg. I’ve been contemplating going back to Michelin tires, and away from E rating. I did add a TRD sway bar also. I pretty much did everything at once, tires, shocks, sway bar, and RAS. So, I’m not sure what made the most impact on reducing the porpoising we were experiencing when we switched trailers, from 23’ 500# tongue weight to 25’ 900# tongue weight.
    j-utah, PBNB and g6t9ed like this.
  11. May 3, 2024 at 6:53 AM
    #1061
    Retroboy1989
    Northern Utah
    I've liked my Yokohamas G015s in P275/60R20. I run 40lbs in the rear when towing and it doesn't feel squishy to me at all. The WDH does a lot of the work. I have a Husky centerline hitch.
    MoPops[QUOTED] likes this.
  12. May 3, 2024 at 9:51 AM
    #1062
    MoPops
    MoPops New Member
    Jeff
    I ran Yokohamas on my 4Runner for years. Good tires. I’m not familiar with the Husky Centerline hitch. We’ve been using a BlueOx SwayPro hitch with our 25’ trailer for four years now. 25’ airstreams are notoriously nose heavy, so very little chance of sway. I usually stay around 65-70 mph. That way I can at least get 200 miles out of a tank of gas. Ha! Also slower is better for reducing sway also, at least from what I’ve read.
  13. May 3, 2024 at 2:09 PM
    #1063
    Retroboy1989
    Northern Utah
    Slower is always better for towing. I always roll my eyes a people doing 80+ mph pulling a trailer with a half ton pickup. Trailer tires are commonly rated for speeds much lower than car and truck tires.
    70 max for me. I usually keep it just below 3K rpm in 4th gear. Whatever speed that is....67mph?
  14. May 3, 2024 at 2:13 PM
    #1064
    koditten
    Kirk
    Midland of the Mitten
    Not many RVs are built with enough quality to run above 65 mph. They built so shitty they in danger of coming apart north of 65.
    Most trailer tires are rated for 65 mph as well.
    I'm never impressed with the goods running 80 dragging the RV.
    Wallygator and MoPops like this.
  15. May 4, 2024 at 11:17 AM
    #1065
    Retroboy1989
    Northern Utah
    Interestingly, my Carlisle trailer tires from Discount are rated for 81 mph. I feel like 70 is top speed for any towing.
    koditten likes this.
  16. May 5, 2024 at 4:15 AM
    #1066
    MoPops
    MoPops New Member
    Jeff
    I have Goodyear Endurance trailer tires on our camper. They are rated to 87 mph. I haven’t tested them at that speed. I do run them below the listed max pressure. (65 psi vs 85). I also watch pressures and temp with a TPMS.
    koditten and bflooks like this.
  17. May 5, 2024 at 6:14 AM
    #1067
    JMGmanAZ
    JMGmanAZ New Member
    Jerry
    Belly of the Beast
    I have those on my Lance and will drive 75 as conditions permit.
  18. May 6, 2024 at 11:57 AM
    #1068
    j-utah
    j-utah performance warrantied member
    Utah
    Fortress of Solitude, CO
    2024 Tundra SR5
    Dice valve stem caps (black)
    Upping my game to deal with the extreme wind. And for using the Sherline scale and sites with side slopes. Wind coming off of Horsetooth reservoir can be biblical :(
  19. May 13, 2024 at 7:23 AM
    #1069
    SnrDisregardo
    Wade
    IL
    Retired...finally likes this.
  20. May 13, 2024 at 9:06 AM
    #1070
    Retired...finally
    They don't show it fully extended. It might have a little fore and aft play even fully extended with weight on it.
  21. May 13, 2024 at 9:24 AM
    #1071
    JMGmanAZ
    JMGmanAZ New Member
    Jerry
    Belly of the Beast
    Are you needing additional height from your tongue jack?
  22. May 13, 2024 at 9:29 AM
    #1072
    SnrDisregardo
    Wade
    IL
    Not necessarily. Just looking for other options aside from carrying extra weight in the form of a 4x4 with a 2x4 stacked on top of it for when it's needed.
    KNABORES likes this.
  23. May 13, 2024 at 9:35 AM
    #1073
    PBNB
    PBNB Needy
    Peter
    Vancouver, BC
    2023 Z71 3500 HD
    Lots of stuff!
    I carry a 4x6 block of wood and slip that under the jack. Not very high tech but it works and saves me the cranking time with the manual jack!
    It does look like an interesting add on that could replace the wood block. my trailer has 500 lbs of tongue weight so the static weight wouldn't be an issue, I do think that there would be some slop in the connection which might be felt in the trailer when moving around inside it (sort of along the lines of @Retired...finally).
    j-utah and bflooks like this.
  24. May 13, 2024 at 9:41 AM
    #1074
    JMGmanAZ
    JMGmanAZ New Member
    Jerry
    Belly of the Beast
  25. May 13, 2024 at 9:46 AM
    #1075
    bflooks
    bflooks New Member
    Metrowest MA
    I have found the drum style blocks are all the height I need. I appreciate the intended purpose, but I wouldn't be able to use that just because I already don't like how much movement is in the tongue jack when extended over 50% and that with a slide on/pin in foot.
    JMGmanAZ likes this.
  26. May 13, 2024 at 9:50 AM
    #1076
    Retired...finally
  27. May 13, 2024 at 10:33 AM
    #1077
    SnrDisregardo
    Wade
    IL
    That was my reasoning. I read that the jack and stab's are at their best when not extended past 50%. Parked in my driveway, I have it up 6" before the foot. I guess I'll give it a whirl. Worst thing is I would have to take it off.
    j-utah likes this.
  28. May 13, 2024 at 10:34 AM
    #1078
    bflooks
    bflooks New Member
    Metrowest MA
    Report back with your results. Concerns could be unfounded and it may be a fantastic solution.
    SnrDisregardo likes this.
  29. May 21, 2024 at 6:44 AM
    #1079
    j-utah
    Utah
    2024 Tundra SR5
    Probably I shouldn’t post all of this here. I just found a camper mods thread down in the thread queue. The square blocks I purchased — for my needs, the thought is these will be multipurpose. I can use them under the corner scissor jack supports, they are just wide enough for that. This helps me deal with cross slopes. I can use them in the front, one or maybe more if necessary. The front jack on my ORV is pretty long, but I like to keep a significant amount in the sleeve. I like the 50% rule-of-thumb mentioned. The last thing is I can use them to help with is to weigh the trailer tongue. Also I like that they’re black.
  30. May 21, 2024 at 8:41 AM
    #1080
    JMGmanAZ
    JMGmanAZ New Member
    Jerry
    Belly of the Beast
    A bucket over your jack is also a good way to keep it protected and keep chains out of the way...
