What kind of camper do you have???
Discussion in 'Towing & Hauling' started by Muleycrazy13, Feb 12, 2017.
  1. Aug 17, 2022 at 6:17 PM
    #691
    RovingMedics
    RovingMedics New Member
    2022 Army Green Tundra Limited
    Yep! You sure can! There's a setting for the Xantrex inverter for "AC in amperage" or something like that (in the config file it's called AcInBreakerAmp: 30) and you can dial that back down to as low as 5. Set it at 15, plug it into a wall outlet, and you should be fine. We set ours back to 5 amps because someone else on the same circuit had an old school bus with a clunky ass wall AC unit that drew more power, and our battery kept charging and we could use the AC. Worked quite well.
  2. Aug 17, 2022 at 6:20 PM
    #692
    RovingMedics
    This is generally true but on the Micro Minnie FLX, you can get pretty close. :) That's the fun thing about it. The Trump AC unit is pretty efficient. maybe 1100w power draw when the compressor is on. we cooked up some nachos while the AC was running and did ok.
    JDR76[QUOTED] likes this.
  3. Aug 17, 2022 at 6:46 PM
    #693
    Downytide
    Downytide New Member
    GTA
    Lunar Rock that whines
    That's freaking sweet, I wonder how cold can this camper withstand.
  4. Aug 17, 2022 at 6:51 PM
    #694
    RovingMedics
    now that I am not sure about but we are definitely going to find out here in a couple months. ;-) we do some river trips into the middle of November.
  5. Aug 17, 2022 at 7:17 PM
    #695
    Downytide
    GTA
    What cold do you expect to see? We are told it'll be bearable at freezing but won't suggest us try it with Canadian winter.
  6. Aug 17, 2022 at 8:01 PM
    #696
    RovingMedics
    oh boy. we'll be up in the eastern Sierra Nevada mountains but nowhere NEAR as cold as winter in Canada. lol. we'll probably winterize it anyway just to be safe but only when we know we're done for a couple cold months.
  7. Aug 20, 2022 at 1:53 PM
    #697
    Downytide
    GTA
    Got her today, we are already in love with it, it's a hot day today so just parked it outside while giving it a clean up with AC blasting, the xandrex app states the correct battery, but I can't seem to get the go power app to read the controller, it just takes forever, is that normal?
    And I can't believe how off the xantrex app is, it would shows 25% while lithionic says 75%.
    Tows like a champ, still thinking swap to bags.
  8. Aug 20, 2022 at 3:27 PM
    #698
    RovingMedics
    Once I paired it, the GoPower app should be fairly quick. Did you see the posts by SactoSteve on the Winnie owners forum? He got a LOT of great information out of GoPower/Xantrex. Although more dealers are getting this info now too and are configuring things appropriately.
    Yeah, the Xantrex app is WAY off of what the Lithionics one is, which is kind of annoying especially since Xantrex also makes/sells LiFoPo4 batteries too. But that app is handy. Did you see the setting I was talking about that lets you fill back what the inverter is connected to? Usually it's 30 amps at an RV park but if you're at home or on a generator, you can bump it back to 15 amps or even lower if you so desire. That's been a really handy feature.
    As I'm sure you'll find out, you can't run the AC blasting all day and still have battery, but that's a given. acclimatize accordingly. :) The vent fan setting helps out too. ShowerMiser is also awesome. You'll love it.
    Have fun with it! As more of them are sold, we'll collectively learn more about them too.
    edit: we have the Tundra Limited, didn't think about bags yet. but we got a fastway e2 WDH. it worked great with the Tacoma and should be great with the Tundra too.
  9. Aug 20, 2022 at 3:41 PM
    #699
    Downytide
    GTA
    Yes, I saw the post and trying to follow with it, unfortunately my dealer is volume based, so when brought up batteries the exchanges were rather short, having a hell of a time to get gopower app to work, gonna try more of it through the week.
    I can't wait til someoen figure out how to add a battery, I see xantrex box has one more battery slot
    RovingMedics likes this.
  10. Aug 20, 2022 at 6:10 PM
    #700
    RovingMedics
    These are the apps that I have, hopefully you have the same. GoPower, Xantrex, Lithionics. Bottom row is one for the brake controller that I don't need anymore because the Tundra has one, the legit Winnebago app, and then the one for the Lippert TireLinc box for TPMS.
    I've read that some people were talking about a second battery. Lithionics makes a 620aH battery and you could probably put another 320aH one there in series. I think that would work.
    at least here in California, we'll probably be ok with the 320aH one since we're ok with a breeze from a fan most of the time. and if not, we have the Honda generator and additional solar panel. I do kind of wish the Tundra had that inverter/generator feature that one of the Fords has. That sounded pretty slick.
  11. Aug 20, 2022 at 8:50 PM
    #701
    Hotwire
    Hotwire New Member
    Montana
    2008 Tundra SR5 double cab
    2020 4x4 Sprinter
    Wallygator, Warreng, myt1 and 3 others like this.
  12. Aug 28, 2022 at 6:43 PM
    #702
    Downytide
    GTA
    I finally got the gopower app to work before the weekend trip, overall we love the system, but some stuff is going to take some reading or figuring out, like the hot water system.
    On the plus side, overnight got as low as 45ish, about 9c, it was alright without the heater, bit chilly but not bad, we think with heater it'll be ok with freezing.
  13. Sep 7, 2022 at 9:53 PM
    #703
    RovingMedics
    hopefully your Truma panel inside shows you everything it needs to for the hot water system. :)
    apparently more of these are leaving the factory and the factory is forgetting to set parameters for the battery/charge controller. Not sure if you read any of the winnieowners.com threads, but it's definitely an issue. some TX friends of ours that bought a FLX had some quirks with theirs. Their Xantrex was trying to say it was a FreedomX 1200 instead of the FreedomX 3000 that it actually was. lol. (not sure if they've addressed that yet...)
  14. Sep 8, 2022 at 4:29 AM
    #704
    ZPMAN
    Minnesota
    2019 ATC 2816 love all the aluminum and just tip it and power wash after each race.
    Wallygator, Warreng, JDR76 and 2 others like this.
  15. Sep 8, 2022 at 8:20 AM
    #705
    Downytide
    GTA
    Well, dealer never told us how to turn "hot water" on inside, I was told turn it on outside then the temperature was set at like 50c or something, which was true, it'll supply it for 1min then stops, we went north the past long weekend and for the first night I had cold shower while it was 6c/42f outside...........
    Until I read everything there was to read and realize I need to turn it "on" on the truma panel.
    The trailer did stay toasty overnight with the heater, so I think we are going to camp well into Fall as long its not well below freezing, and yes I'm reading Winnie's thread, debating to add another 380w of solar and another lithionic battery, then perhaps Timbren independent suspension, bigger tanks, disc brakes................. the modifying ocd is kicking in hard.
    RovingMedics[QUOTED] likes this.
  16. Sep 8, 2022 at 8:05 PM
    #706
    RovingMedics
    A second battery is awfully tempting. we have the room for it. or just replacing it with a 620aH battery. that would take a heck of a lot longer to charge via solar, but it might be worth it in the long run.
    We need to do a couple minor repairs now too. One of the roads we went down was *really* touch and one of the drawers got damaged. Damn lightweight materials sometimes.
  17. Sep 8, 2022 at 9:24 PM
    #707
    kparrow
    kparrow New Member
    Kevin
    Nampa, ID
    2020 Grand Design Transcend 265BH. Upgraded this year from a 1968 24’ Prowler that I had remodeled inside. We Love it! Looking forward to many more trips!
    CC6509CF-EE71-46AA-8F55-7EF9F8090EFF.jpg 5443A25A-3A2E-4EA3-9DC6-900A773B5B80.jpg CF5D4E4E-AE3A-4B35-AAC7-EE2A0966114E.jpg
  18. Sep 24, 2022 at 3:15 PM
    #708
    Melikeymy beer
    Melikeymy beer No cooler for you!
    Muscogee Nation
    2019 Platypus Tundra
    We survived record heat at Lake Fort Smith State Park last week. The Tundra did a great job towing the trailer in the Boston Mountains.
    Hooked up without the WDH bars the measure from ground to the top of the wheel wells was 37" even front and back, so perfectly level. After attaching the bars it was 37" rear and 36 3/4 front.
    Very confident handling on Interstate 40 and the Muskogee Turnpike (80 mph speed limit) with vehicles passing while dialed in at 65mph. Very little sway.
  19. Sep 27, 2022 at 12:08 PM
    #709
    Retired...finally
    Left this morning at 08:00 EDT and spending the first night of a 7 month trip in Beckley WV. 10.8 MPG at 60-65 MPH. Relaxing drive Calculated MPG so far has been 11.1, 11.2, 11.4 & 11.6.20220927_125816.jpg
  20. Oct 2, 2022 at 12:16 PM
    #710
    froghill
    froghill New Member
    White 5.7 trd sport
    Fresh off the line
    762900AE-B0D2-45EF-B524-BCF6F39D77E0.jpg Left Syracuse NY last Friday, and took two days to get to key west just before the hurricane hit. Tuesday night was tough! But out 19’ Jayco handled it well. Towing that thing is a breeze, even loaded with two weeks worth of provisions! 762900AE-B0D2-45EF-B524-BCF6F39D77E0.jpg
  21. Oct 2, 2022 at 1:30 PM
    #711
    LukeS
    LukeS New Member
    Luke
    Northeast PA
    Army Green Limited TRD OR
    Jayfeather 17xfd we've had for about 5 years. Had to stay under the 5k limit on our previous Explorer, but looking to upgrade to something bigger now that we have the truck. Might stick with something similar to the Jayfeather, just longer. Less wind resistance and no need for tow mirrors when the camper is only 7ft wide.
  22. Oct 2, 2022 at 2:41 PM
    #712
    mountaingroan
    mountaingroan New Member
    North Idaho
    2020 SR5 DC VooDoo 4WD Bench!
    Headed to the Columbia in Northern Washington for Walleye..
  23. Oct 2, 2022 at 5:48 PM
    #713
    Petit Jean State Park, Arkansas for the weekend. Outaback 292URL
  24. Oct 2, 2022 at 6:13 PM
    #714
    Retroboy1989
    Northern Utah
    2012 SR5 TRD OR (prev) 2025 SR5 TRD Rally (now)
    I've posted my trailer before, but making another appearance is the '17 Jayco 267bhsw. 30ft. The Tundra pulled it from 2200ft to 9700ft today. Pulled like a beast.
    PXL_20220930_155918970.jpgPXL_20221001_162534517.jpg PXL_20221002_160153020.jpg
    I am sold on the aux trans cooler. Pan temps peaked at 212°. After 30 minutes of 2nd and 3rd gear climbs to 9700ft, we stopped at an overlook. I popped the hood and felt the hoses. Trans out was hot, factory cooler out was warm, aux cooler out was cold! I was shocked that out hose/filter were cold! Ambient temps were in the 50s at that elevation and apparently kept the trans totally under control.
  25. Oct 2, 2022 at 6:48 PM
    #715
    WVI
    WVI New Member
    @008 Tundra Limited
  26. Oct 2, 2022 at 6:57 PM
    #716
    Wallygator
    Looks like he has 2012, it was factory on that year up until 2019 if I'm not mistaken.
    EDIT: looks like I was mistaken:notsure::D
  27. Oct 3, 2022 at 6:47 AM
    #717
    Retroboy1989
    Northern Utah
  28. Oct 3, 2022 at 12:52 PM
    #718
    Specs on this as requested in another thread.
    Camper weight unloaded: 7140lbs
    Camper length bumper to bumper: 33’4”
    Weight distribution hitch: Reese Equalizer style with 12,000# trunion bars.
    Haven’t been on the scale loaded but assuming another 1000# or so in the camper. (2nd air conditioner, battery, propane, clothes and food)
    Jorts and Retroboy1989 like this.
  29. Oct 3, 2022 at 5:15 PM
    #719
    Retroboy1989
    Northern Utah
    It looks huge in your other picture from the town thread. I was thinking 36ft.
    Edit: TOW thread
    Cpl_Punishment likes this.
  30. Oct 3, 2022 at 5:32 PM
    #720
    29’2” box. Rear living floor plan. Double slides in the back.
