What is this?
Discussion in '1st Gen Tundras (2000-2006)' started by 01tunder, May 16, 2021.
  1. May 16, 2021 at 7:27 PM
    01tunder
    01tunder [OP] New Member
    Ca
    2010 4x4 trd tundra
    This little sensor that seems to be connected to transmission?
  2. May 16, 2021 at 7:28 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    I believe that’s the speed sensor for the speedometer
    N84434 and Wynnded like this.
  3. May 16, 2021 at 7:31 PM
    01tunder
    Ca
    2010 4x4 trd tundra
    OK cool thanks
  4. May 16, 2021 at 7:56 PM
    ScenicRoute
    ScenicRoute New Member
    2021 Tundra CM Nightshade
    Eibach stage 2, SmartCap, Ride Rite, Bora spacers, 35” rugged ridge tires.
    Did you light it on fire?
    Jack McCarthy and 1lowlife like this.
  5. May 16, 2021 at 7:58 PM
    ZappBrannigan
    Canada, by way of Hawaii
    2018 1794 MGM
    NVS light bar
    It’s toast is what it is.
    Desrat, hagrid and GIN•OKUMA like this.
  6. May 16, 2021 at 8:28 PM
    jimf909
    jimf909 Battery almost dead...
    Washington or Idaho
    '03 Tundra SR5 AC 4.7 TRD w/LSD
    Dead stock with oem 16" starfish wheels. We'll see how long that lasts. :) Topper of unknown origin.
    Didn't get the speed sensor heat shield when he installed the flux capacitor. Never cheap out when installing the flux capacitor.
    Darkness, KarmaKannon, hagrid and 2 others like this.
  7. May 16, 2021 at 8:44 PM
    01tunder
    Ca
    2010 4x4 trd tundra
    No it was like that when I got the truck. The speedometer works
  8. May 16, 2021 at 8:49 PM
    GIN•OKUMA
    GIN•OKUMA Can’t get to SSEM from there. RGBA1
    Fish
    26.57°
    Noun; a machine, usually with wheels and an engine, used for transporting people or goods, especially on land
    Until you hit 88 :burnrubber:
  9. May 17, 2021 at 3:54 AM
    Professional Hand Model
    Hand Protectors
    Wonder why its cooked/burnt?
  10. May 17, 2021 at 4:22 AM
    BubbaW
    BubbaW Been Real
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    As others have said, speed sensor. The reason speedometer is possibly working is because the one that's toast in pic on a A340E transmission is the # 2 sensor and the other is # 1 sensor. "If the No.2 vehicle speed sensor malfunctions, the ECM uses input signals from the No. 1 vehicle speed sensor as a back–up signal" according to FSM(@empty_lord) ?....but you should have a code(P1700) unless that sucker is actually operable.
  11. May 17, 2021 at 1:39 PM
    empty_lord
    05 rollover special
    Looking at the wire, I bet it does work
  12. May 17, 2021 at 1:47 PM
    01tunder
    Ca
    2010 4x4 trd tundra
    No codes. Only code is p430 but I I switched the back of o2 sensors , I cleared the code now and waiting to see if the code pop back up
  13. May 17, 2021 at 2:08 PM
    BubbaW
    BubbaW Been Real
    Bubba
    Where Eagles Nest
    T150 Lover
    If I was betting man....NFL :eek2:
    bmf4069 and Darkness like this.
  14. May 17, 2021 at 2:22 PM
    empty_lord
    05 rollover special
    I’ve seen worse still work through literally just a strand of wire
  15. May 17, 2021 at 3:00 PM
    BubbaW
    BubbaW Been Real
    Bubba
    Where Eagles Nest
    T150 Lover
    I can believe that considering not much current flow but doesn’t really matter, it’ll work till it don’t. It’s possibly working off of # 1 sensor anyway.
    empty_lord likes this.
