What is this light for in 2007?
Discussion in '2nd Gen Tundras (2007-2013)' started by Trooper2, Apr 19, 2018.
  1. Apr 20, 2018 at 8:07 AM
    Trooper2
    Trooper2 [OP] Premium Lone Star Member / SSEM #13
    JR
    Houston, TX (Suburban South)
    I will never tell. I know all about you and what you did............
    TXMiamiFan[QUOTED] likes this.
  2. Apr 20, 2018 at 8:27 AM
    TXMiamiFan
    Jose
    2016 White Crew Max TRD
    Trooper2[QUOTED][OP] likes this.
  3. Apr 20, 2018 at 5:35 PM
    DalTee
    DalTee New Member
    Dal
    2011 SuperWhite CrewMax Limited
    Extang Folding Tonneau, 20 percent tint, TRD dual exhaust, BedMat, Stubby antennae, Bully Hitch Step, AVS Window Shades
    Headlight fluid indicator. When the headlights need lubricant it lights uo
  4. Apr 20, 2018 at 7:22 PM
    Les7311
    Les7311 Look up, what do you see
    2008 Blue Tundra TRD 4x4
    It’s a map light. Same type bulb that is by your accelerator.
    To get to it, loosen panel under AC controls
    Then unscrew shift lever
    Then pop out from the lines where the armrest open and closes
    BINGO!!!!! Bulb exposed.
    Mountun Goat likes this.
  5. Apr 20, 2018 at 8:06 PM
    Trooper2
    JR
    Thanks, Guess that makes sense. Why would it be an amber colored bulb? Doesnt seem like the best color, unless it has been changed.......
  6. Apr 20, 2018 at 8:08 PM
    Les7311
    They prob changed it as mine is clear. I have the LED by the accelerator and they bright a faaakkk!!! Expect the same results when I change this one
    Trooper2[OP] likes this.
