What is this, and how do I fix it?
Discussion in 'Detailing' started by War Machine, Aug 3, 2018.
  1. Aug 3, 2018 at 6:04 AM
    War Machine
    War Machine [OP] SSEM # 5 3MW
    My brother in law has this spotting all over his hood, and asked me if I had anything that would fix it. He says he thinks it’s from being parked under a tree all the time, like it’s from sap. I’m not sure. Anyone seen this, and know the best route? I didn’t want to just start buffing on it without a second opinion.
    111ECB14-BAAF-4027-9301-97940C22B414.jpg 6FB9D371-B9B8-4F40-9DB2-A05D97386609.jpg
  2. Aug 3, 2018 at 6:29 AM
    aRabidLunatic
    aRabidLunatic Professional Hobo
    Central Texas
    2015 Tundra SR5 Black
    Actually looks kinda cool, like a picture from the Hubble
    Ostrich, ecm209, TheBeast and 5 others like this.
  3. Aug 3, 2018 at 6:30 AM
    Does he have Pecan trees? I kinda have same problem
  4. Aug 3, 2018 at 6:44 AM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    What does it feel like? Raised bumps depressed chips? Sticky?
  5. Aug 3, 2018 at 6:50 AM
    sprtbkr
    sprtbkr Average Member
    Scott
    Denver, CO
    2018 Tundra SR5 4x4 Double Cab - Inferno
    TRD Wheels & Tires, Double Cab Fold-down Back Seat mod, LED Interior Lighting, Turned Off Seat Belt Chime, Franken-key (Flip Key), Duraliner Bed Liner, Bed Rails, Hood Wind Deflector, Console Gun Safe, iBoard 5" Running Boards, TRD Sport Bed Vinyl, Fortin Evo One Remote Start with Mycar Cellular Module, Plasti-dipped Badges and Bumper End Caps, Tinted front windows, Extang Solid Fold 2.0, Pop-N-Lock, TUNDRA tailgate inserts, RCI Powder Coated Skid Plate - coming soon - 12” android radio, oemaudio+ Reference 500Q, under dash/seat lighting.
    How does it respond to soap and water?
  6. Aug 3, 2018 at 7:15 AM
    Pressure wash it off, light scrub, if it's from the house cut back on the tree, if it's up from work park somewhere else
    HighDesertSurfer likes this.
  7. Aug 3, 2018 at 7:18 AM
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    if it's raised sap, what about hitting it with some tar or bug remover?
    Maybe just try it on a small area
  8. Aug 3, 2018 at 7:20 AM
    MotoTundra
    MotoTundra The Ocho
    Don
    No clue. Good luck, let us know what does the trick.
    Is it on the roof too?
  9. Aug 3, 2018 at 7:22 AM
    Here's my culprit, Pecan tree, even if I park close to house that sap crap still gets on, and I've cut back on that tree a lot, don't get me wrong it puts out good shade n good crop of pecans, but that sap crap I hate and it's a messy tree
    Les7311, Sunnier and 4x4_Angel like this.
  10. Aug 3, 2018 at 7:22 AM
  11. Aug 3, 2018 at 7:32 AM
    jstrenn
    jstrenn New Member
    2017 Toyota Tundra Double Cab 4X4 TRD Off Road
    If it's sap stuck on the paint you could try a good wash then hit it with a clay bar.
  12. Aug 3, 2018 at 7:38 AM
    sprtbkr
    Scott
    Denver, CO
    I'd wash it first, and then use tar and bug remover. Tar and bug remover will be the most effective on sap. Then another good wash and wax.
  13. Aug 3, 2018 at 8:14 AM
    WrigglingWilly
    WrigglingWilly Well used Member
    2018 Tundra 4x4 5.7 8.1bed
    LineX
    :oldglory:Cover the whole truck in Sap, now its armor plated, like natures LineX, Bam.
    Ostrich, Sunnier, 4x4_Angel and 6 others like this.
  14. Aug 3, 2018 at 8:42 AM
    War Machine
    He says it doesn’t come off when he washes it. They feel bumpy, tried my fingernail, and it didn’t do anything.
    I’ll try a clay bar and some iron x and see what happens.
    4x4_Angel likes this.
  15. Aug 3, 2018 at 8:43 AM
    War Machine
    It’s not a pecan tree. I think it’s a sweetgum.
  16. Aug 3, 2018 at 8:57 AM
    Try that bug and tar remover
  17. Aug 3, 2018 at 9:36 AM
    HecticEnergy
    HecticEnergy New Member
    TJ
    SE Texas
    2017 MGM Tundra SR5
    Winjet Rear brake lights, leather seats, BackFlip tonneau cover, Spyder headlights, Pro Grille, pop&lock
    I agree with Adam... I dont think Iron X is going to have much of an affect.
    Maybe want to wash it right before to try and soften it up a bit?
    It wasnt tree pitch, but I had some luck removing the sticky stuff left behind from the vinyl tail tags with WD40... Clean the truck, then spray the area with WD40, let it sit for a minute or two, then start working at it with a MF cloth.
  18. Aug 3, 2018 at 9:48 AM
    jewsNbrews
    Jewiston Idaho
    2019 TRD PRO
    Bolt on
    I have used goo gone in the past and it worked well. But I only had small spotting from a tree at work, so not sure if it would work on larger surfaces or not. Those pictures look worse than what mine did.
    I have also heard of people using vinager to get stuff like that off.
  19. Aug 3, 2018 at 9:51 AM
    sr5shark
    sr5shark Shop smart. Shop S-Mart.
    Alan
    Walnut Creek, CA
    2016 SR5
    Fox & ADS | SCS SR8 | Nitto RG
    What ever product you try I would test it first on a small painted part that is not too visible. I used bug and tar remover to try to get off some sap and it started to take the paint off.
    HighDesertSurfer and jewsNbrews like this.
  20. Aug 3, 2018 at 9:56 AM
    HecticEnergy
    TJ
    SE Texas
    2017 MGM Tundra SR5
  21. Aug 3, 2018 at 10:59 AM
    War Machine
    I didn’t mean to say the Iron x would do anything to the sap. I’ll just use it since I’m claying anyway.
    I’ll probably try a few different things I have already, then try the tar remover.
    Pudge and HecticEnergy[QUOTED] like this.
  22. Aug 3, 2018 at 11:02 AM
    DMBfan
    DMBfan 2015 Tundra SR5 CrewMax
    Take it into a detail shop for the day. They'll remove everything, clean the engine bay and the interior. While they do that, you can head to an auto parts store and buy a cover for the truck. Better yet..quit parking under the treeo_O
  23. Aug 3, 2018 at 1:22 PM
    Undertow
    Undertow New Member
    I've had to remove huge blobs of sap from a longleaf pine off of a few hoods.Its a 2 person job how I did it anyway,one with a water hose and one with a small wrag and a can of acetone.Dab the wrag with acetone and apply it to the sap and have them spray it off immediately and I do say Immediately or you will not only remove the sap but your clear coat as well.It works really fast so don't lollygagg around when it comes to spraying it off as soon as you notice the sap dissolving.It worked on really big hardened globs of sap so it should be easier to remove what you have since it looks more like a mist of sap covered your truck.Hope this helps,just be glad it's not a long leaf pine you're parked by.
  24. Aug 3, 2018 at 2:05 PM
    Jack Burton
    Jack Burton New Member
    Little China
    2013 DC 5.7L TRD/OR
    Tires, Diamondback HD Tonneau w/ ATV Carrier
    Back in the day, before washing, I used diesel and a rag to remove crap like this from my dove-grey '77 Cougar and it worked great! It would also strip away any wax, so I'd have to re-do that every time, but it left the paint just fine. I've never tried it on modern paints or anything with clear coat, sooooo...I'm just talking of my ass right now and not making any recommendations!
    4x4_Angel, joonbug and 15whtrd like this.
  25. Aug 3, 2018 at 2:21 PM
    trdprobped17
    trdprobped17 New Member
    It looks like tree sap to me. Where is he parking his vehicle??
  26. Aug 3, 2018 at 2:41 PM
    War Machine
    1) No
    2) Not my truck
    3) Not my truck
  27. Aug 3, 2018 at 2:42 PM
    War Machine
    In his driveway. He has trees overhanging it. It’s an old Ford, he’s not overly concerned about it. He was just asking if I could do anything on it.
    15whtrd likes this.
  28. Aug 3, 2018 at 4:09 PM
    HecticEnergy
    TJ
    SE Texas
    2017 MGM Tundra SR5
    I swear I read that before... like in the OP.... weird...
  29. Aug 3, 2018 at 4:14 PM
    Pudge
    CT
    I think carpro makes something called TarX. And also a combo Tar/IronX. Have him buy that for you Haha. Let it soak, then clean and clay. Tree sap is tough stuff for sure
  30. Aug 3, 2018 at 4:31 PM
    trdprobped17
    Yup, that’s tree sap. My wife had something similar on her suv. So, I told her to stop parking in the tree she usually park under at work. Since then, no more sticky stuff.
