What is the metal part on the other end pcv valve hose ?
Discussion in '1st Gen Tundras (2000-2006)' started by Leafy1975, Mar 17, 2023.
  1. Mar 17, 2023 at 5:11 PM
    Leafy1975
    Leafy1975 [OP] New Member
    Eric
    2004 Grey Double Cab Tundra Sr5
    4.7.jpg I replaced pcv valve and putting in a dorman catch can in as found some pretty gnarly deposits changing oil in oil filler tube on Patrick . I'm going clean out throttle body and sea foam it once or twice as well. Taking hose off throttle body and removing this part the gasket broke apart and I need a replacement. Any help what it is called and where find one(or just the name be plenty). Your all Rad and appreciate the help. This just screw in throttle body and breather hose hooks into it and pcv valve other end.
  2. Mar 17, 2023 at 7:20 PM
    JasonC.
    JasonC. ¯\_(ツ)_/¯
    TX
    2001 4x4 4.7L “Best Cab”/AC Limited 52k mi
    happy feast day
  3. Mar 17, 2023 at 7:32 PM
    shifty` All my rowdy friends have settled down
    I'm not recognizing this part, else I'd help. If I could see where it goes, and understand where the gasket is, I'm happy to help using this knowledge.
    Leafy1975[OP] likes this.
  4. Mar 17, 2023 at 7:32 PM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    Friyay!!!!
  5. Mar 17, 2023 at 7:39 PM
    I made a 3lb slab of corned beef w/potatoes tonight for us, the kids, and two of our closest friends.
    Many carbombs were consumed.
    I need to sleep this off.
  6. Mar 17, 2023 at 7:43 PM
    FrenchToasty
    Mo
    Bone stock
    Damn that sounds good! I didn’t have any carbombs, but I did have a Guinness and some tasty CB my mom made, with carrots, onion discs and potatoes. And cabbage of course. The meat was sooooo damn tender and she got it sliced nice and thin!
    I was just telling my buddy, I like smoking it for 4 hours or so, then crock with butter and beer for another 4 hours or so.
    shifty`[QUOTED] likes this.
  7. Mar 17, 2023 at 7:44 PM
    Pastrami!!!
  8. Mar 17, 2023 at 7:50 PM
    FrenchToasty
    Mo
    Bone stock
    We still ate it like corn beef…… I also like making it before camping and eating it like pastrami! I’ve got a pork butt in the midst right now that’s given me troubles tonight, and two spatchcocks need to go on the smoker soon(big extravaganza tomorrow)
  9. Mar 17, 2023 at 7:52 PM
    FrenchToasty
    Mo
    Bone stock
    This butt had a bigger bone or it was the picnic? Buttttttt it’s taken longer than expected then I tried to hurry it, hahah then had to turn it down to go to dinner, only to come back to a lower internal then when we left!!! I don’t wanna dry it out but I’ve got a water bath and im at 194…… now
  10. Mar 17, 2023 at 8:00 PM
    Staaaaaaaaaall time! Just make sure you keep a water bath in the general vicinity. General tactic is, if you keep higher humidity in the air around the meat, there's no reason for the meat to give up the moisture it's holding. Is it scientifically sound? IDK! Not a scientist. :rofl:
  11. Mar 17, 2023 at 8:03 PM
    FrenchToasty
    Mo
    Bone stock
    Oh it’s solid, except we hit the stall this morning before I left work!!!! Probably 200-220tops I’m thinking over night, but I didn’t want it to finish early, so I left it low while I went to work. It was 157 when I left for work! It will be fine, I’m now at 198, so we’re almost there
  12. Mar 17, 2023 at 8:05 PM
    198 ... I give it 30, maybe 45 minutes. Usually when I finally break a couple of degrees between 195-199, you're 30-60 mins out, tops.
    Lucky you, it's still early enough for a couple more beers over there :D
  13. Mar 17, 2023 at 8:07 PM
    FrenchToasty
    Mo
    Bone stock
    Hahah it’s gonna be a long night and a long day tomorrow. Someone’s turning 4!
