What is the largest size tire I can fit where the spare tire rest?
Discussion in 'Wheels & Tires' started by jgraphix73, Feb 27, 2019.
  1. Feb 27, 2019 at 9:02 AM
    jgraphix73
    jgraphix73 [OP] New Member
    Richard
    2010 Tundra Crewmax
    Sorry if this is a dumb question...but I wanted to ask the community, what is the largest size tire I can fit in the spare location? I have oversized tires (305/70/18) and wanted to know if I can fit one in the spare location and if not, I will have to find another way to carry the spare.
    Thank you!
  2. Feb 27, 2019 at 9:05 AM
    Berdine
    Berdine Voodoo Sport
    Binghamton, NY
    2020 VooDoo Blue Trd Sport
    Interested as well, run same size. There's a few posts on people fitting 35s
    jgraphix73[OP] likes this.
  3. Feb 27, 2019 at 9:08 AM
    I have a 35” tucked under mine. Just took a hammer to bend back a bracket. Good to go
    Pinay and Berdine like this.
  4. Feb 27, 2019 at 9:08 AM
    mrflyinghigh
    mrflyinghigh New Member
    Jared
    2018 Blazing Blue Tundra Platinum
    I would also like a clear answer on this. I posted something like this months ago and saw someone fit a 35” with “some trimming.” But without trimming, I’m not sure.
  5. Feb 27, 2019 at 9:09 AM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Depends on the brand, but that size should make it in. Removing the 2 guides will help it sit flush.
  6. Feb 27, 2019 at 9:10 AM
    Berdine
    Binghamton, NY
    I thought I saw someone do 305 70 18 on a stock spare rim and it fit
    831Tun likes this.
  7. Feb 27, 2019 at 9:13 AM
    jgraphix73
    Richard
    2010 Tundra Crewmax
    The tire I have is a STT Pro (305/70/18).
    Would anyone know if I bought a different tire in the same size be OK to run in case I need to swap temporarily? Or is it recommended that I have a exact same spare tire?
  8. Feb 27, 2019 at 9:15 AM
    Pinay
    Pinay New Member
    Monet
    Mahal kita Kuya
    Sean, what kind of rim do you have on your spare? I have my old Fuel Assault rims and I tried to fit it on the brace that holds the spare and it won't stay on, can't get a good grip. Know of anyone who has changed that bracket?
  9. Feb 27, 2019 at 9:16 AM
    Pinay
    Pinay New Member
    Monet
    Mahal kita Kuya
    Others have posted in threads if the tabs get cut off or bent a tire size 35" will fit.
  10. Feb 27, 2019 at 9:17 AM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    I have a 305 70 (measures 34.8" x 12.4", bigger than most 35s) under the bed. The guides need to be removed for it to fit, I drilled out the spot welds for a clean removal.
    joonbug and Berdine[QUOTED] like this.
  11. Feb 27, 2019 at 9:17 AM
    Berdine
    Binghamton, NY
    For another site, same size but 17"
  12. Feb 27, 2019 at 9:19 AM
    TheBeast The Beach
    depends on other parts too especially if running larger shackles like coachbuilder or aftermarket exhaust..etc...
    I have a 295/70/18 there but we had to cut the brackets to make space. YMMV
    jgraphix73[OP] and joonbug like this.
  13. Feb 27, 2019 at 10:20 AM
    Factory wheel spare. I should probably change it
    Berdine and joonbug like this.
  14. Feb 27, 2019 at 10:22 AM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    LOL! Name confused me!
  15. Mar 5, 2019 at 2:57 PM
    DividedSky
    DividedSky New Member
    Jeff
    '18 Crewmax - ADS Mid Travel
    ADS 2.5's (rear bypass) U748 Leaf Springs
    That's weird... I fit my 295/70R18 with no modifications.
  16. Mar 5, 2019 at 3:07 PM
    iamsmokey
    iamsmokey Smokey the Tundra
    Oahu, HI
    2018 Cement SR5 Off-Road 4x4 Crewmax
    I’ve heard that you put your two regular sizes on the front and run the spare in the rear if this is the case. Also trying to figure this out, especially here on Oahu where one side of the island to the other is an hour trip at most haha.
  17. Mar 5, 2019 at 5:58 PM
    TheBeast The Beach
    the thing is you have to swap 2 wheels now instead of one if you have a flat on the front. with one jack it's getting complicated. Best is to have a full size spare.
