What is a cab mount chop
Discussion in 'Wheels & Tires' started by Dustydirt19, Sep 22, 2016.
  1. Sep 22, 2016 at 9:13 AM
    Dustydirt19
    Dustydirt19 [OP] Hoghead
    Dustin
    Duluth, MN
    2015 Blue Ribbon Metallic 5.7L 4WD SR5 TRD DC
    ProComp 6" stage 2 lift 18x9 Fuel Vapor -12 offset 35x12.5 Nitto Ridge Grapplers BullyDog Tuner Gibson Metal Mulisha cat-back exhaust, S&B cold air intake, Color matched TRD PRO Grille, Compustar Remote Start N-Fab Hooped Nerf Bars, AMI Big stick antenna, Salex organizer and tray, Weathertech laser cut floor mats, Weathertech window deflectors Black out badge Black out front and rear bumper Black out flags 24/7 black out TRD Off-road decals Spray in Line-X Bedliner Scosche phone mount Soft rolling tonneau cover TRD pedals and footrest
    Title pretty much says it all
  2. Sep 22, 2016 at 9:36 AM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    If you're getting bigger wheels and it rubs, you can buy a CMC plate. You grind away a chunk of your inner wheel well and weld the plate in. It creates a little bit more room for your bigger wheels. It's not as scary as it sounds.
  3. Sep 22, 2016 at 10:01 AM
    Netmonkey
    Netmonkey Don't be a Dumbass
    Georgetown, TX
    2016 Texas Edition, 5.7, CM, MGM
    Icon stage 2 lift, 295 60 20 nitto ridge grapplers, fuel kranks, TRD dual exhaust, TRD rear sway bar
    i did this on my Tacoma. its where you trim the cab mount and weld a plate over the cut. for me, it also included trimming plastic. here is a before and after on my Tacoma:
  4. Sep 22, 2016 at 10:03 AM
    equin
    equin Texarican Tundra
    Ed
    DFW, TX
    Some also call it a body mount chop. Anyway, it's a modification to the cab body mount by the front wheel well. Bigger tires can sometimes rub or hit the body mount. To fix the problem, part of the body mount is cut away and a new steel plate is welded in place to create more space and prevent tire rub.
    Like Joonbug says, some vendors sell the steel plate to be welded onto the body mount once it's cut. If you have the cutting and welding tools available, you can do it yourself. Otherwise, a 4x4 shop or a fabricator can probably do it for a fee.
  5. Sep 22, 2016 at 10:17 AM
    Dustydirt19
    Dustin
    Duluth, MN
    Ok thanks what are some places to buy the plates?
  6. Sep 22, 2016 at 10:19 AM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
  7. Sep 22, 2016 at 12:03 PM
    Dirty pic
    Skey44 likes this.
  8. Sep 23, 2016 at 9:16 AM
    olsin6
    olsin6 New Member Vendor
    Joey
    Mesa, AZ
    2010 White DCSB Tundra
    35" Toyo MT w/ 17" Method Standards Body Mount Chop SDHQ Sliders
    I have a few pictures of our body mount chops that I have taken during various stages of the process on a few different vehicles. We typically do 2-3 a week.
    Once they are completed, they are painted with the black epoxy based chassis paint by VHT, it seems to hold up the best.
    This is a pretty common thing with all Toyota's as they don't mind a tall tire, they just don't like a wide tire. We do the body mount chops on any Toyota running 285 or bigger. We plasma cut the mount for a more precise fit and the plate is cut on our CNC plasma table. We also do a couple brakes to get the most clearance possible.
    Skey44, Cat3ILS, equin and 1 other person like this.
