  1. Jul 28, 2019 at 12:53 PM
    #1471
    :eek::eek::eek::eek::eek::anonymous:
    1UPPER[QUOTED] likes this.
  2. Jul 28, 2019 at 1:39 PM
    #1472
    Squatting Pigeon
    Holden
    North Texas
    4Runner | GR Corolla
    Army green pro?
    :spending:
    aperezsh likes this.
  3. Jul 28, 2019 at 1:55 PM
    #1473
    1UPPER
    1UPPER Not A New Member
    TEXAS
    Flux capacitor!
    Not a green color fan. I’ve got some other plans in mind.
  4. Jul 28, 2019 at 2:29 PM
    #1474
    Omohundro
    Omohundro 2018 Not a Pro
    Jody
    McMinnville TN
    2018 Tundra Platinum
    I’m going to use the back side of the tongue and grove that I put on my front and back porches. Should look something like this only darker. EE9A1A91-8955-41DA-BD30-87F4BBAE783D.jpg
  5. Jul 28, 2019 at 3:07 PM
    #1475
    Squatting Pigeon
    Holden
    North Texas
    Understood! Are you going to stick with blue accents or even main color on the next one?
  6. Jul 28, 2019 at 3:14 PM
    #1476
    1UPPER
    TEXAS
    Flux capacitor!
  7. Jul 29, 2019 at 5:00 AM
    #1477
    SnrDisregardo
    SnrDisregardo New Member
    Wade
    IL
    2018 Platinum CrewMax 4x4
    TRD Sport Suspension, TRD Front & Rear Sway bar, TRD Pro Shift knob, Charcoal Filter Delete, aFe Pro Dry S w/SABM, LineX bed, Remote Start, OEM tonneau cover, DIY pop'n lock, DIY TRD cold air intake, TRD skid plate, DD SS3 amber fogs, HotShot Offroad Hot Tails, 2020 OE radio with tech12v amp and sub.
    Replacement. Not sure, maybe 6/12 or 7/12. Asphalt.
  8. Jul 29, 2019 at 5:18 AM
    #1478
    1UPPER
    TEXAS
    Flux capacitor!
    Do you know if you have 3 tab or dimensional shingles currently? If you go back with asphalt shingles, I would make sure they don’t install the new shingles over the first layer. Some roofers will do this to save on cost and time but it adds a lot more weight on your roof. Do you get snow in your area?
    SunTundra413 and NewImprovedRon like this.
  9. Jul 29, 2019 at 5:22 AM
    #1479
    SnrDisregardo
    Wade
    IL
    I believe they are 3 tab. This is the original roof too. I would want them to do a tear off and put down an snow guard of some sort as we do get snow. I also need them to take a look as a leak has developed in my garage, but I think that is because the way the roof is made, the gutter is overwhelmed.
  10. Jul 29, 2019 at 6:08 AM
    #1480
    1UPPER
    TEXAS
    Flux capacitor!
    I would recommend you have ice and water shield installed. This helps when snow and ice form around your gutters. Here are a few photos for illustration.
    Ice and water shield can be run along the edges of the roof and the valleys.
  11. Jul 29, 2019 at 6:55 AM
    #1481
    SnrDisregardo
    Wade
    IL
    And I think I have that happening with rain. In heavy downpours, it has been leaking. I thing the gutter flow is crappy. I has like 4 surfaces going into 1 down spout. Part of the garage main roof and garage eave, front porch, upper story roof, all going into a 6' long gutter to a downspout that has a drain tile under my sidewalk next to the driveway. I was thinking about disconnecting that and letting it water my panting bed, but that is still a shit ton of water and its too close to the house.
  12. Jul 29, 2019 at 7:04 AM
    #1482
    1UPPER
    TEXAS
    Flux capacitor!
    Measure your downspouts. You may benefit from having oversized downspouts. You can also add additional downspouts to your existing gutters. Most builders will do standard size downspouts for to save on cost.
    NUDRAT and NewImprovedRon like this.
  13. Jul 29, 2019 at 7:06 AM
    #1483
    SnrDisregardo
    Wade
    IL
    @1UPPER thanks for all the advice.
    ColoradoTJ and 1UPPER like this.
  14. Jul 29, 2019 at 7:24 AM
    #1484
    Trooper2
    JR
    Houston, TX (Suburban South)
    Looks great!!! I prefer mulch for moisture and fertilizing properties, (no dyed mulches). Rock beds also accumulate Mowed grass, leaves and other natural debris that is hard to keep clean after a while. I also worry about the additional heat for the sun (conductive and radiated) that the rocks will add to the plants. Some plants can handle this heat, except those from more desert like climates. I have used the weed block material before but have learned that it really is not needed. Most of your new weeds will be airborne generated.
    I would suggest a combination, mulch and line the sidewalk edge with a decorative rock; maybe Flagstone or a Bull-rock.
    Omohundro[QUOTED] likes this.
  15. Jul 29, 2019 at 10:00 AM
    #1485
    Trooper2
    JR
    Mulch does have to be replenished from time to time, the nature of it, damn nature & decomposition........
    NewImprovedRon likes this.
  16. Jul 29, 2019 at 10:06 AM
    #1486
    fairclothr1
    fairclothr1 Here and There Member
    Ryan
    2009 Sand Mica Tundra TRD
    Plasti Dipped grill and badges. Shorty antenna.
    Got our shed built finally. Had the plans approved over a month ago, but life's been too busy. Cheap, pre-cut shed from Lowe's. Basically re-landscaped the corner, prepped ground, laid rock, built the thing by myself. My wife helped a little when I needed an extra set of hands and with the trim. Still have to get it painted to match the house, but, that's more of my wife's department.
    Will be nice to reclaim some of my garage. Been 2 months since we moved into a new house with the hopes of me getting to work in the garage more, but the stuff that was in our old shed was taking up most of the 3rd stall in my new garage. I hope to get the rest cleaned up and get to finally organizing my tools soon. Cheers!
  17. Jul 29, 2019 at 10:15 AM
    #1487
    1UPPER
    TEXAS
    Flux capacitor!
    Or you can get the best of both worlds. This is a new landscaping project I’m almost done with for a client of mine. Stone was done around the perimeter. Then stone borders around the trees and mulch inside the tree rings. 19029779-6474-485B-91DA-D443AF765CBC.jpg
    F6A49E02-E427-45A5-8E89-CB37D43AFA5C.jpg 35422E64-2BA6-4B0F-8CE7-A585A7CFEFC6.jpg
    ColoradoTJ, Randy1794, Vizsla and 4 others like this.
  18. Jul 29, 2019 at 1:25 PM
    #1488
    aRabidLunatic
    aRabidLunatic Professional Hobo
    Central Texas
    2015 Tundra SR5 Black
    You needed a permit?
  19. Jul 29, 2019 at 1:33 PM
    #1489
    fairclothr1
    Ryan
    No, approval of my HOA (home owners association).
  20. Jul 30, 2019 at 12:37 PM
    #1490
    Boosted4runner
    Boosted4runner Join the NRA please.
    WA
    2015 DC MGM TRD Tundra, Kings, 5.7, 2018 front end
    Resi Kings, 35” Trail Grapplers on 18” Methods, ICON Delta Upper Arms, Front-Runner bed rack, Yakima SkyBox16, 2018 honeycomb grill, 2018 LED headlights, plastidipped bumper covers
    I used a 3-way feed blend from some prize winning sheep farmer LOL.
    I’ll have to check the bags for markings.
    The Kubota is a MX5100D - 53hp turbo diesel. I run 7ft wide implements.
    It’s a manual trans, which some think I’m crazy but I prefer.
    What happened in your back yard? Did you ever decide where the shop was going?
    Vizsla and ColoradoTJ[QUOTED] like this.
  21. Jul 30, 2019 at 12:45 PM
    #1491
    I needed to level out some ground in the back and use the extra up front. Doing a bunch of landscaping when I can.
    Your field is amazing. I need that for sure to cover the bare spots.
    You can totally warrant a tractor like that. I just have a little L2501D. Works for us, and mostly for snow removal.
    We will most likely do a shop up front, I’m not screwing up my views. Lol
    Vizsla, JMB, aperezsh and 4 others like this.
  22. Jul 30, 2019 at 4:15 PM
    #1492
    Boosted4runner
    WA
    Gotchya, been there lol :)
    Yea, it was 1,600 lbs of seed and 1,600 lbs of fertilizer :)
    Don’t screw up the view! That’s a kickass view. Def shop up front :thumbsup:
  23. Jul 31, 2019 at 4:58 AM
    #1493
    Twinky
    07 double cab work horse
    Something to consider also is synthetic roofing underlayment, like "tyvec protec".
    It is used in place of traditional felt paper.
    If you are planning on staying in your home for many years to come then the tyvec and water ice shield combination is about as ideal of an underlayment system you can have.
    That said, the tyvec isnt a must have. The water and ice shield, though, is a definite for at least in the valleys.
    Im personally a huge metal roof and radiant barrier fan. Not to sure on how metal roofs hold up to snow loads and such, but they are good in Texas weather.
    1UPPER likes this.
  24. Jul 31, 2019 at 5:13 AM
    #1494
    1UPPER
    TEXAS
    Flux capacitor!
    All my roofers now use the synthetic membrane systems instead of felt. It doesn’t tear as easy as felt does, it’s lighter to caring the rolls and a better product. Metal roofs can still be done in snow with proper planning. In Texas metal roofs are great!
    aperezsh and Twinky[QUOTED] like this.
  25. Jul 31, 2019 at 8:23 PM
    #1495
    Omohundro
    Jody
    McMinnville TN
    I finally got my garden planted, little late but oh well. 365E2BE7-44B5-407B-8850-CA726733699C.jpg
    No my picture, just thought it was funny.
  26. Aug 1, 2019 at 6:51 AM
    #1496
    lawrenceb
    lawrenceb New Member
    2019 Tundra TRD Pro
    Don't use engineered hardwood, its not meant to be outside..
    Use this https://www.synergywood.com/ for the grade 2 stuff its about $3.79 a sqft.
    We used the grade two which will have knots, the grade one will be few or no knots but the cost is double.
    Highly recommend the ebony color, we thought it would be black but its not.. more of a brownish black.. great color.
    We considered beadboard but it was more than the synergy product..
  27. Aug 1, 2019 at 7:44 AM
    #1497
    Omohundro
    Jody
    McMinnville TN
    My stuff is not going outside, it’s going in a climate controlled garage.
    What you have looks great but 3.79 a sq is out for me. By the time it’s all said and done I need 900sq.
  28. Aug 1, 2019 at 6:16 PM
    #1498
    Vizsla
    Vizsla 2 = 2.5
    Closed on new house today.:D
  29. Aug 1, 2019 at 6:18 PM
    #1499
    Congratulations!
    Vizsla[QUOTED] likes this.
  30. Aug 1, 2019 at 7:15 PM
    #1500
    @1UPPER build?:D
    ColoradoTJ, NewImprovedRon and 1UPPER like this.
